The Breakdown on Fuel Management Systems - Page 4 - ZX6R Forum
 40Likes
post #46 of 126 Old 11-19-2012, 12:47 PM Thread Starter
Super Moderator
EvilTwin's Avatar
Originally Posted by Cav View Post
It gains 5bhp (dyno proven) compared to 4bhp from the M4 if that helps? The main thing really is that you wouldn't say its vital to have a Bazzaz just for a slip-on although it is adviseable? At least I don't have to save up a pot of £800+
Thanks bud =)
Correct, you're not going to cause any damage by running your bike with a slip-on and no fuel controller, but you may notice some loss in performance in the low and mid ranges, depends on the pipe.
EvilTwin is offline
post #47 of 126 Old 01-07-2013, 10:06 AM
sparkybp's Avatar
I Ride: 2012 Kawasaki ZX6R
How about running the bike with stock headers and prechamber only? no slip on ? it shouldn't cause damage but i assume i would experience even a greater power loss at low + mid range rpm?
having said that yes I am getting a bazzaz after your write up, before i even get a slip on.
sparkybp is offline
post #48 of 126 Old 01-07-2013, 10:41 AM
Cav
Cav's Avatar
I Ride: 2009 ZX6R
From my understanding running no pipe with standard headers will not cause damage BUT will cause your valves to need more frequent checks. Apart from that most engines sound hideous at idle without exhaust can and are just stupidly loud. Up to you though but there's no immediate damage as far as im aware
Cav is offline
post #49 of 126 Old 01-07-2013, 11:08 AM Thread Starter
Super Moderator
EvilTwin's Avatar
Getting rid of pre-chamber without a slip-on, yeah it'll hurt your low end and maybe some mid. You'll still safe AFR wise, hell Kawis are usually richer than most bikes anyways, so it takes a decent amount of modding to get them into ranges that could be considered dangerous.
No more frequent that what the manual calls for. Putting a full system on a bike doesn't make as lean as people think it does. I'm running an open header set-up on my track bike, and my fuel map takes fuel OUT in some places.
EvilTwin is offline
post #50 of 126 Old 01-18-2013, 06:10 PM
Zxdave's Avatar
Good write up. Dusty (dynojet) i
s a arrogant punk and has terrible customer service.
Zxdave is offline
post #51 of 126 Old 01-18-2013, 10:52 PM
I Ride: 2012 zx6
Sometimes i wish a just got the bazzaz. Oh well still happy with my pc5
2012 ZX6 Black.
PC5 and Quickshifter.
K & N air filter
Akrapovic Slipon in carbon
ASV Levers Hotbodies dark smoke gp screen speigler braided brake lines front and rear driven d3 grips yoshimura bar ends yoshimura fender eliminator and more when i can think of what to buy
jayboy131 is offline
post #52 of 126 Old 01-18-2013, 11:17 PM
fallenangel's Avatar
I Ride: 2011 zx6r
Is it worth the money to get the tc system? Right now I ride the streets pretty hard but I'm gearing up for track riding. Planning on gut the cat have an akra slip with mid pipe and a bmc filter. Also hoping to get a healtech xtre and the like. So I guess I'm asking for a recommended system. Always been a bazzaz fan lol
mods as follows.
debadged, speigler ss black and red lines, red driven spools, solo cowl, double h pads front and back,fp v stacks, bmc filter, gutted air box, full leo system, revalved ohlins damper,db smoked windscreen,hot bodies undertail kit, bazzaz zfi & zfam, iridium spark plugs,sick innovations street cage,de mirrored,painted calipers,fp evo shift star,driven block off plates and kleen air mod, bst carbon fiber wheels with titanium sprocket nuts supersprox -1/stock stealth sprockets in black for bst ad red for stock with vortex rv3 triglide chain.
to come:sato rearsets,annitori gen 2 qs, suspension?
fallenangel is offline
post #53 of 126 Old 02-08-2013, 01:12 PM
IceBreakerG's Avatar
I Ride: 2013 Ninja ZX-6R
My biggest question about the bazzaz (or any fuel controller right now) is for the 2013 zx6r. How does having a fuel controller affect the bike when it has different power modes? If I get a fuel controller on that bike, will I still be able to use the different power modes on the bike or will I lose that functionality?
KakaFace likes this.
IceBreakerG is offline
post #54 of 126 Old 02-11-2013, 09:45 AM Thread Starter
Super Moderator
EvilTwin's Avatar
I love having TC, I crank it up in the mornings when it's cold and wet outside and my tires are cold and slippery. Honestly I don't hardly use it on the track, but I have it set up as a sort of safety net so it only come on when I absolutely need it.
The power modes will continue to function as normal.
KakaFace and IceBreakerG like this.
EvilTwin is offline
post #55 of 126 Old 02-11-2013, 10:02 AM
I Ride: 2011 zx6r
Thanks. Lol still waiting on the write up. Sounds like something I might want. Roads are full of fine gravel where I live. Damn country ppl and their big ass trucks hahaha
mods as follows.
post #56 of 126 Old 03-18-2013, 04:28 PM
TardisBlue6r's Avatar
I Ride: 2011 Zx6R
Great write up. One question that I have. If I get a dyno tune with the bazzaz z-fi, getting the bazzaz afm would be redundant, correct? Would I be able to switch between the tuned map and auto tuning?
TardisBlue6r is offline
post #57 of 126 Old 03-19-2013, 04:06 AM
d1andonlyant's Avatar
I Ride: 04' ZX636
When you get it dyno'd the map is for the conditions on that specific day, when you use the autotune you can set it up to whatever the conditions are there and then which is better. One thing I was wondering (question for eviltwin) is when your bike is on a dyno it isn't moving obviously, but in the real world when you're doing 130 the bike is getting air pretty much shoved down its throat (might be called the ram air effect??), so does that mean the map on the dyno will be less accurate because once you get the bike off the dyno and get on the road the extra air pressure in the airbox will change the AFR?
Thanks
04' ZX636
Ram Air Mod - Kleen Air Mod
Short Stacks Mod - MWR Filter
SP Quickshifter - 2012 Shock
__________________
d1andonlyant is offline
post #58 of 126 Old 03-19-2013, 07:43 AM Thread Starter
Super Moderator
EvilTwin's Avatar
Yes and no. Dyno tuning is much more comprehensive, and it gives you the ability to determine what the exact ideal AFR for your bike is. Using the Z-AFM while riding gives you the most realistic tuning, since your bike is operating under real world circumstances. Our Z-AFM is not an auto tuner, per se, it's a fuel mapper. The Z-AFM operates more like a data acquisition sysytem, it logs data while you ride, then you go back in and review the data before applying the recommended changes. This gives the user absolute control over what goes into their fuel map.
It's not really necessary to continually tune your fuel map, your bike's atmospheric sensors do a fairly adequate job of keeping the fueling consistent with pressure and temperature changes. I can ride all weekend, from sea level, up through the mountains, into the high desert, and then up some more mountains, and I never notice a performance change in my bike. I re-map about 4-5 times a year, seasonally, but only b/c I have the z-afm and I can. The biggest advantage is for track riders and racers, it is much more essential for them to re-map at every track, since they are in the hunt for hundredths of seconds off their lap times. Street riders aren't going to notice the difference most of the time, as long as they have a good base map to start with.
Thanks
You are absolutely correct, and this is something that is often overlooked; ram air effects do change the fueling requirements in a tune. Most dynos either do not have a ram air simulator or it is a fixed speed system, which is still inaccurate. Our dyno has a ram air simulator that can produce wind speeds that mimic up to 170mph of real world ram air effects. This feature combined with our incredibly smart and accurate load cell, which can apply progressive drag that mimics wind drag, gives me the ability to make maps that are damn near spot on to real riding conditions.
EvilTwin is offline
post #59 of 126 Old 03-19-2013, 10:30 AM
Great write-up !!!
I have run PC3usb on my litre twin racebikes (TL1000R and a heavily-modded RC51), and really was not overly impressed.
Last season I started on a modern 600... a 2012 ZX6R... and installed a Bazzaz Z Fi-TC and Z-AFM system (though I never did use the TC part). I did the installation myself and marvelled that Bazzaz made such a complete system that included separate wiring looms to parallel the OEM loom; this is unlike PC where you just have a module that plugs in.
The engine was broken in on the test day before my first race, and I was auto-tuning right from day 1. It was great! Easy to do, and I did that for a few weekends while breaking in the engine. I could even remap when I changed to MR12 race fuel, to get the most benefit.
Mid-season I dyno'd the bike and found it had 114rwhp on a stock engine (no work done) on 91 pump fuel.
Now that I am converting that bike back to street, I will be keeping the Z Fi and Z-AFM systems but not using a QS or TC.
Many thanks, Bazzaz, for making a great system!
Glenn Cauley
GDRacing Canada Motorsports Team
2012 ZX-6R
| Traxxion Dynamics AK-20 forks | Elka shock | GPR V4 Stabilizer | Driven axle block sliders | Woodcraft case covers | Smog block-off plates | Kawasaki race kit clutch | Kawasaki race kit oil catch tank | NGK Iridium IX sparkplugs | Dimple magnetic oil drain plug | BMC air filter | Akrapovič full SS/CF exhaust | Bazzaz Z Fi-TC w/ Autotune | EK 3D 520 chain | Driven sprockets | Pazzo folding levers | Woodcraft rearsets | Driven D-AXIS grips | Spiegler SS brake lines | EBC brake pads | TechSpec C3 grip pads | Rascal Grafix tank pad | Vortex V3 quick-turn fuel cap | Yoshimura fender eliminator | Luimoto seats |
GlennCauley is offline
post #60 of 126 Old 03-19-2013, 10:32 AM
ZXNasty's Avatar
I Ride: 2011 ZX6R
Originally Posted by GlennCauley View Post
Great write-up !!!
I'm also considering switching from PC to Bazzaz for the street. Keep us updated. I follow your pics on FB
GlennCauley likes this.
Originally Posted by rodas6r View Post
1nastyZ and zxnasty, forum a-holes, and heroes
Originally Posted by MonsterZX View Post
lol I am picturing nasty coming rolling off the bike and then just jumping up out of it and goin into a gas station buy a monster and start drinking it like nothing just happened
Originally Posted by iLean2much View Post
you're not the first who comes along wanting to look good. but i'd be the first to point at you and laugh while picking up your poor bike you just dropped in front of everyone.
Originally Posted by kninja View Post
beef curtins
AKA Princess
ZXNasty is offline
bazzaz , dyno jet , pciii , pcv , power commander
active fuel management breakdown
bazzaz afm won't sample below 6000
bazzaz fuel trim
bazzaz z-fi fuel management system
breakdown of fuel manager parts
kawasaki zx6r fi system
pcv sensor voltage high zx6r
tps wire 08 zx6
which bazzaz fuel management system is used for full exhaust systems
www.where takeing apart a fuel system on a ninja zx6r 08?
zx6r fuel control to improve throttle response
zx6r fuel management
WTB looking for fuel management system bigassrevolv Classifieds 4 07-30-2012 07:56 AM
How to: Inspect/Clean 'Fuel Filter' 05-06 ZX6R 636 Get Forked Mechanical and Technical 5 05-23-2012 07:31 AM
How To: Service Fuel Pump and Strainer ZoomSplat Guides 14 04-20-2012 05:40 AM
What is the best fuel management system? d1andonlyant Mechanical and Technical 74 04-12-2012 01:55 PM
Fuel Pump and Fuel Filter!?!? Help! Anonymouszx6 Motorcycle Talk 5 12-03-2011 05:50 PM
