The Breakdown on Fuel Management Systems - Page 9 - ZX6R Forum
 40Likes
post #121 of 126 Old 07-10-2015, 05:24 PM Thread Starter
Super Moderator
EvilTwin's Avatar
Originally Posted by JaWheel View Post
Thank for that hidden Gold... Im impressed; truly. Anything you could share extra about 2003 Zx6r (636) off the top of your head?
If you cut your midpipe off right under your foot peg it'll be loud as fuck and have no power below 6k, but plenty of power above that when running 12.3:1 AFR.
JaWheel likes this.
EvilTwin is offline
post #122 of 126 Old 07-10-2015, 05:46 PM
THUG's Avatar
Subscribed
JAMES 1:12
THUG is offline
post #123 of 126 Old 11-20-2015, 12:25 PM
Colombian JJ's Avatar
I Ride: 2014 ZX6R (Illy Kai)
Hey Evil twin, great write up. I read intro and I love everything that you had to say about it thank you for taking the time to write something like this. My question is, this articles was written a couple years ago. So what's the difference between a new PC5 and the new bazzas like that they change the percentages that you're talking abo? Does the PC 5 change the injector modules like that of the bazzas? And a PC 5 with an auto tune would that be better now or is it pretty much the same. I just don't feel like always having to re tune the bike for different weather conditions or altitudes when I travel to different locations I figured the autotune will be nice Cuz already installed. Thank you again
Colombian JJ is offline
post #124 of 126 Old 11-25-2015, 09:23 PM
SaugaCityZx6's Avatar
I Ride: 2015 Kawasaki Zx6r
Yes Evil twinn ^ please answer this
SaugaCityZx6 is offline
post #125 of 126 Old 12-02-2015, 04:17 PM Thread Starter
Super Moderator
EvilTwin's Avatar
Well I haven't worked for Bazzaz for 2 and a half years now, but to my knowledge not much has changed with either the Z-Fis or the PCVs, which should mean this article is still fairly accurate. Except I think the Z-Fis have Bluetooth connectivity now. If Dyno Jet has made any changes to their Power Commander line since then, I'm not aware of it. At one point it was being considered to allow the Z-AFM (the Bazzaz version of the auto tuner) to either log suggested changes or make active changes like the auto tuner, that way the rider could decide how they'd rather build maps. But idk if that was ever instituted.
EvilTwin is offline
post #126 of 126 Old 12-22-2015, 03:16 PM
honestSquid's Avatar
I Ride: ZX6R (abs)
honestSquid is offline
bazzaz , dyno jet , pciii , pcv , power commander
active fuel management breakdown
bazzaz afm won't sample below 6000
bazzaz fuel trim
bazzaz z-fi fuel management system
breakdown of fuel manager parts
kawasaki zx6r fi system
pcv sensor voltage high zx6r
tps wire 08 zx6
which bazzaz fuel management system is used for full exhaust systems
www.where takeing apart a fuel system on a ninja zx6r 08?
zx6r fuel control to improve throttle response
zx6r fuel management
WTB looking for fuel management system bigassrevolv Classifieds 4 07-30-2012 07:56 AM
How to: Inspect/Clean 'Fuel Filter' 05-06 ZX6R 636 Get Forked Mechanical and Technical 5 05-23-2012 07:31 AM
How To: Service Fuel Pump and Strainer ZoomSplat Guides 14 04-20-2012 05:40 AM
What is the best fuel management system? d1andonlyant Mechanical and Technical 74 04-12-2012 01:55 PM
Fuel Pump and Fuel Filter!?!? Help! Anonymouszx6 Motorcycle Talk 5 12-03-2011 05:50 PM
