Can only shift in higher RPM's - ZX6R Forum
post #1 of 25 Old 09-14-2012, 10:58 AM Thread Starter
Just recently, I havn't been able to shift my bike out of gear, If I am in 5th gear I can only go up to 6th, When I do get going, I can only shift when the bike is at a higher rpm, I would say anything over 5k.
The bike is a 2002, only had about 1000 miles when I picked it up, prob put about 300-400 miles on it.
for more history on my bike, I have an old thread
http://zx6r.com/mechanical-technical...s-about-33129/
I tried asking on there, but not to many answers, wanted to start a new thread for this problem.
ty you everyone that reply's!
elletram is offline
post #2 of 25 Old 09-14-2012, 11:31 AM
Has the oil ever been changed? I'd start there and see what happens.
PowerGroove is offline
post #3 of 25 Old 09-14-2012, 01:07 PM
I Ride: 96 zx600F
Try adjusting the clutch cable.
Slip angle is offline
post #4 of 25 Old 09-14-2012, 01:18 PM Thread Starter
Really... old oil would stop it from shifting all of a sudden?
elletram is offline
post #5 of 25 Old 09-14-2012, 01:19 PM Thread Starter
you mean the one by the handle?
elletram is offline
post #6 of 25 Old 09-14-2012, 02:53 PM
Consider this... the first oil change (per the manual) during the break in period is at 600 miles. It's to get rid of any small shavings or grime from the initial break in period. If it's at 1300 miles and hasn't had an oil change then it's nasty... shitty... poopoo oil and needs to be changed. THis CAN have an ill effect on how the bikes transmission and clutch operate. Because the oil is crap and not lubricating as well.
Handle is for free play... adjusting down at the clutch linkage is where you adjust the clutch itself.
post #7 of 25 Old 09-14-2012, 03:03 PM
6OTM Master of Ceremonies
Youssef636's Avatar
You should have a little bit of free play but not alot.
Look down by the Crankcase cover, If sitting on the bike its on the right side, by where you would pour new oil. You will see the clutch cable. Keep us updated
Winner - 6OTM March 2012
FAQ for new riders
Youssef636 is offline
post #8 of 25 Old 09-14-2012, 07:08 PM Thread Starter
will do, changing the oil tomorrow
elletram is offline
post #9 of 25 Old 09-14-2012, 08:28 PM
davidreaper's Avatar
I Ride: 01 ZX6R, Too many to remember
Thats what I told you, the only thing I could think of before you start tearing it apart.
One Man, One Life, Many Motorcycles
Youtube - CLICK FOR TRACK VIDEOS
The contents of the above post may not be safe for children, expectant mothers, or the elderly. The above post should probably not be taken seriously but should be taken with a quart of whisky. Misuse of the above post may cause rash, infection, joint pain, bleeding gums, car trouble, bad weather, black mold and/or anal seepage.
davidreaper is offline
post #10 of 25 Old 09-14-2012, 08:37 PM Thread Starter
yes i know, but you also said that you never had this problem before, so I wanted to get other thoughts before I did that. ty buddy
elletram is offline
post #11 of 25 Old 09-15-2012, 03:17 PM Thread Starter
So I did the oil change, and now the oil light is staying on, and the bike doesn't sound that good ='(
elletram is offline
post #12 of 25 Old 09-15-2012, 03:25 PM
Are you sure it's got enough oil?
post #13 of 25 Old 09-15-2012, 03:32 PM Thread Starter
yeah, 4qt, its at the top of the line, I found this
Knocking sound after oil change... : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
im gonna try.
PowerGroove likes this.
elletram is offline
post #14 of 25 Old 09-15-2012, 03:35 PM
Yup... The "Burp"
post #15 of 25 Old 09-15-2012, 04:46 PM Thread Starter
Yup... The "Burp"
omg the worst oil changing experience of my life lol, there is a lot of tears behind that lol... So I went back to do the burp, and I put the other filter on too tight, so the filter remover thing I got was just slipping, I could not get it off, so what did I have to do to a brand new filter? screw driver hammer, so I got it in, and I could not keep turning it because of ground clearance, so I had to put the bike down on its side to keep on turning it, had to put the old filter back on. No more oil light, and runs great and shifts fine. Although before I did this it was shifting ok before I did this, more in less I put some seafome to clean it up a bit before I did the oil change. but boy oh boy, what a hassle.
elletram is offline
Dumb Question FullThrottle The ZX6R 28 07-27-2012 06:44 PM
How do you shift?? Josh2011zx6 The ZX6R 43 08-13-2011 09:12 AM
01 zx6r bogs at high speeds and higher rpms? dlstech Mechanical and Technical 11 08-01-2011 08:29 PM
Limp mode? Possible fueling issues at high RPMS... kawasakifreak77 Mechanical and Technical 7 06-09-2011 05:35 PM
Can't get bike to higher RPM's Syn Mechanical and Technical 11 04-10-2011 06:43 PM
