Head gasket?? - ZX6R Forum
post #1 of 5 Old 09-23-2012, 12:10 PM Thread Starter
I Ride: Zx6R G2
Question Head gasket??
hey guys again,
Getting alittle bit of white smoke from exhaust when i start from cold with choke on...as soon as the engine is warm its fine, bike runs and pulls just the same
Is this the head gasket going?
G2Ninjaboy is offline
post #2 of 5 Old 09-23-2012, 02:30 PM
bowhunter11's Avatar
I Ride: 07 ZX6R
its getting colder out, so yer bike is gonna blow some white smoke out.
im not trying to say that you dont have a blown head gasket though.
when its cold out yer bike will sit over night and condensation will gather in the exhaust,so when you start it you will get white smoke. once it clears out you have no more white smoke.
so try running yer bike till you have no smoke them park it in a warmer garage and let it cool off then start it back up to see if you still have white smoke.
usually if you have a blown head gasket you will always have white smoke.
all so you will have loss compression which will result in a loss in power.
also yer bike will over heat.
you can also take yer coolant cap off yer bike and start it, if you see bubbles coming up then you have a blown head gasket or air getting into the coolant somehow.
im guessing its just cold out and yer haveing some white smoke till the bike warms up.
bowhunter11 is offline
post #3 of 5 Old 09-23-2012, 03:14 PM
I Ride: ZX6R B1H 2003
You wont be having H/G problems.Like the previous post states it will just be condensation especially if you keep it in a shed or un insulated garage.My bike also has this white smoke from cold and even has a "milky" look in the oil level spy glass but its definately only condensation.
Most of the other chaps on this site wont have this problem as they are mostly from warm countries!
Dont worry about it just ride it!
colinl is offline
post #4 of 5 Old 09-24-2012, 12:26 AM Thread Starter
I Ride: Zx6R G2
Thanks guys, the white smoke goes within 30 secs and only does it at early hours in
The morning.
I ride my bike everyday rain snow or sun.
Thanks.
post #5 of 5 Old 09-24-2012, 01:08 AM
06BlueDevil's Avatar
I Ride: 06 ZX6R-R.I.P 2008 ZX10R
maybe not actually "smoke" but steam like...??
06BlueDevil is offline
head gasket sizing for 2011 zx6r Valentine The ZX6R 2 08-18-2012 12:54 AM
07 Head Gasket leaking mtbprodigy Mechanical and Technical 2 06-14-2012 07:27 PM
head gasket on ZX6rr AKstunt Mechanical and Technical 14 01-31-2012 02:55 PM
head cam N2O ninja z28 The ZX6R 19 06-01-2011 09:32 PM
Head Gasket Change SuperMac The ZX6R 1 05-12-2009 08:25 AM
