Oil advice & recommendations from oilman @ Opie Oils - Page 5 - ZX6R Forum
 30Likes
post #61 of 410 Old 11-10-2012, 08:51 AM
Fletch's Avatar
I Ride: 2003 ZX6R
Originally Posted by davezx6r View Post
12,000 km?! That's 7,000 some odd miles according to Google. That's suicide on mineral oil in a bike.* They are probably assuming your using full synthetic.
Even using fully synthetic 7,000 is pushing it if you ask me haha
I wouldnt chance it no way!
Black double bubble screen, Pro Grips black and green, Shorty levers, Moto gp carbon stubby can "Loud As Hell" Aluminium pegs with ZXR engraved in them, R&G Tail tidy, Green wheel rim tape, Bright white LED side lights, Decals removed, Rear seat cowel, Carbon petrol cap cover, Front and rear tinted lights, ZX6R Monster tank pad, Zip tie mod, Clean air mod
Fletch is offline
post #62 of 410 Old 11-12-2012, 02:26 AM Thread Starter
oilman's Avatar
I Ride: None
They're okay from what I know, but I don't deal with them, so don't have details of their full range. I don't think they make any ester based oils, but I think their normal range is okay, although expensive sometimes.
Cheers
Tim
Use the code ZX6R and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
oilman is offline
post #63 of 410 Old 12-01-2012, 02:24 AM
carlspeed's Avatar
I Ride: '06 ZX6R
Hi!
My bike is an '05 636 with 20k on the clock. Only performance mod is a slip on with mid pipe to save weight. It hasn't been abused until now. Probably 70% aggressive street style riding, and 30% track. What oil would you recommend? It's running Shell Rotella T6 right now. What OCI? Also, I'm in central Florida, so even right now in pretty much winter the LOWEST it gets is about 60°, and I'm not riding in anything under that, unless I'm just starting a ride at 0600 hrs, and I won't romp on it till it warms up... Temp outside, and bike... I'm a wuss! But on the track, I'll redline it every gear. Thanks!
carlspeed is offline
post #64 of 410 Old 12-03-2012, 02:55 AM Thread Starter
oilman's Avatar
I Ride: None
I would probably go for a good synthetic 10w-50 if you're thrashing it on track, but any idea how hot the oil is getting on track?
Cheers
Tim
phone: 01209 202944
oilman is offline
post #65 of 410 Old 12-04-2012, 01:01 PM
carlspeed's Avatar
I Ride: '06 ZX6R
No idea
post #66 of 410 Old 12-04-2012, 02:39 PM
oKayH's Avatar
Dang, I missed this one.
I assume you are well versed with oil requirements for bikes and cars, oilman.
With respect to an '09 zx6r, I have been running Shell Rotella T6 with an OEM filter. Hard street riding and track days. Most of my riding is done above 8k and for at least 100 miles at a time. I change oil about every 2500 miles and the filter every other oil change. Anything you would recommend as far as my servicing here?
And with a '11+ Subaru WRX. Is T6 and an OEM filter also a good combo? Factory specified 3750 mile intervals, too soon or just right? I DD the car and it will be a weekend warrior/TD tow vehicle. Would also like recommendations on tranny and diff oils. I guess just stick with Redline?
CCS EX
More gas, less brake
oKayH is offline
post #67 of 410 Old 12-04-2012, 03:10 PM
smokey11's Avatar
My question is about fork oil, I think you mentioned that you had opinions on fork oil as well. What are your thoughts on upgrading the oil in my stock 09 zx6r BPF fork, I was recommended to upgrade to Ohlins or Maxxima. Your thoughts are greatly appreciated.
__________
Mods
smokey11 is offline
post #68 of 410 Old 12-05-2012, 02:47 AM Thread Starter
oilman's Avatar
I Ride: None
Originally Posted by carlspeed View Post
No idea
In that case, go for a 10w-50 to be on the safe side.
Cheers
Tim
phone: 01209 202944
oilman is offline
post #69 of 410 Old 12-05-2012, 02:58 AM Thread Starter
oilman's Avatar
I Ride: None
Hi
If there is no clutch slip with the Rotella, then stick with it, it seems to be doing a good job. Doing 100+ miles at a time helps the oil as it gives it a chance to burn off any fuel or moisture.
With the Impreza, I would go for a 5w-30 or 5w-40 as you're losing cold start protection with a 10w-40. Unless it's modified, a 5w-30 should be fine, but as it's used for towing, 5w-40 is probably the sensible option. Does it have a DCCD set up?
Cheers
Tim
phone: 01209 202944
oilman is offline
post #70 of 410 Old 12-05-2012, 03:01 AM Thread Starter
oilman's Avatar
I Ride: None
According to my data, you need a 10w fork oil and I would go for something like the Silkolene Pro RSF, Motul Factory Line or Redline Medium as an upgrade.
10w Medium Weight Fork Oil
I don't deal with the fluids that you mentioned, so can't really say much about them.
Cheers
Tim
phone: 01209 202944
oilman is offline
post #71 of 410 Old 12-29-2012, 06:40 PM
t3123's Avatar
I Ride: ZX636
Hey im in NYC so the weather is all over the place but I ride in 50 degree weather an better. I have a 636 03 with about 13k on it. Ride street track an hard some mods slip on commander. Anthing you can recommend?.
t3123 is offline
post #72 of 410 Old 12-31-2012, 04:47 AM Thread Starter
oilman's Avatar
I Ride: None
Normally a 10w-40 synthetic would be fine, but if used hard all the time in hot weather you could try a 10w-50 synthetic, but not sure what is available in NYC?
Cheers
Guy
phone: 01209 202944
oilman is offline
post #73 of 410 Old 12-31-2012, 12:44 PM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Cheers
Tim
Iv been using the Redline in my forks for 4-5 years now & Its good stuff,
I like the feel & performance ( & yeah you will notice the deference immediately) I change it every 2 years.
Used the maxxima before, & it don't compare.
read only one page"
oldninjadude is offline
post #74 of 410 Old 12-31-2012, 03:41 PM
Kurt's Avatar
I Ride: 2007 Zx6r
Hey oilman, iv always wanted to know what is the best oil filter? i jump between k&n and amsoil filters lately. Whats in your opinion is the best for bikes and best for cars?
Also i ride 2007 zx6r 13,000 miles. i ride from 30 degrees up to 100ish in the summer. i currently use amsoil filter and amsoil 10w-40 but i saw that you recommended thicker oil in the summer, i do ride somewhat hard so id like the best i can get. So what do you recommend for oil and filter?? Thank you
Kurt is offline
post #75 of 410 Old 01-01-2013, 06:33 AM
I Ride: 2012 ZX6R RED
Is anyone running syntetic oil.
paumar is offline
2008 kawasaki zx6r oil recommendations
2012 ninja zx6r oil recommendation
2016 kawasaki ninja zx6r oil recommendation
kawasaki 850fx oil recommendation
oil recommendation for kawasaki fh601v
oil temp for 2009 zx6r recommended
recommendedoilfh601v
silkolene oil for 2003 kawasaki zx6r
top up zx6r 10w 40
zx6r 2003 oil change recomendations
zx6r forum oil
zx6r oil recommendation 2013
2009 zx6r first oil change done by myself THUG The ZX6R 35 04-08-2013 05:12 PM
ran the bike without/very low amount of oil (emergency situation) PublicNuBoo The ZX6R 28 02-07-2013 04:14 PM
Hi from oilman @ Opie Oils - New club discounts oilman New Users 6 10-22-2012 10:33 AM
The oil thread!! treelowa Mechanical and Technical 1118 10-18-2012 02:04 PM
Mysterious Oil Leak... advice needed? WhiteTrash Mechanical and Technical 19 07-18-2012 12:58 PM
