The Juxtaposition of Flashed ECUs and Fuel Controllers - Page 2 - ZX6R Forum
 28Likes
post #16 of 66 Old 12-07-2012, 03:26 PM Thread Starter
Super Moderator
EvilTwin's Avatar
Originally Posted by MasterTurkey View Post
Yes. Relfashing I assume means putting new bios/os on the ECU... so where does the new software/bios/os/rom/whatever come from? That is if you DIY...
Right now reflashing si something you have to send your ECU out to get done. No one offers a DIY reflash kit, at least not that I've seen. Except Triumph kinda; with TuneECU anyone can modify the parameters in their OEM Triumph ECU.
EvilTwin is offline
post #17 of 66 Old 12-07-2012, 03:27 PM
greenmeeny's Avatar
Ahhh…the cable isn't for flashing it's for tuning the kit ecu. Kawasaki charge $600 for one.
Wether you buy kit ecu, Bazz, PC3 you're always better off getting a custom map. Factor that onto the price of your choice and kit ecu's are good value.
greenmeeny is offline
post #18 of 66 Old 12-07-2012, 04:09 PM
Ive been told he kit ecu for '09 up zx6's only allow a rev limit increase of 300 revs, which for us, does us no good for a LOT of money.
grape is offline
post #19 of 66 Old 12-07-2012, 05:47 PM
smokey11's Avatar
I believe it's more than 500, I will be able to confirm that in a few weeks.
__________
Mods
smokey11 is online now
post #20 of 66 Old 12-08-2012, 03:31 AM
greenmeeny's Avatar
Does Kawasaki a lot of good on the track, though.
It ups the rev limit 500rpm.
What zx6 engines you tune grape?
post #21 of 66 Old 12-08-2012, 09:13 AM
Square's Avatar
I Ride: 2012 zx6
i believe bmw does for the s1000 i mean the have an option you can buy comes with a laptop type thing to adjust the race ecu it down loads all the info off the bike after you ride it and shows you what was going on where. i do have a queastion for you Mr. Twin. i went to the service dept to listen to some exhaust and the gentleman there said that ALL this stuff is now illegal in ca. and that the cops are gonna seriously crack down on any after market fuel managment systems exhaust the whole 9. he also said that a bazzaz could only be purchased if you had an ama race licence he also said another accronym just don't remember it. is that true? are the fuel managment systems easy to find? thank you for your time and the info you provided.
07zx6cinci likes this.
Square is offline
post #22 of 66 Old 12-08-2012, 10:33 AM
greenmeeny's Avatar
Say it ain't so ^
post #23 of 66 Old 12-09-2012, 08:02 AM
Cav
Cav's Avatar
I Ride: 2009 ZX6R
Any thread by you is always worth a read !! Spot on stuff mate..
A quick question (hopefully)... What sort of powergains can you expect from flashed ecu, piggyback, kit ecu and the different combinations you can make with these? I hope my question makes sense to you haha
Cav is offline
post #24 of 66 Old 12-09-2012, 10:39 AM
greenmeeny's Avatar
Kit ecu on an 03 ZX6rr with pipe + filter on base/default map you're looking at 10hp. It's on tintrnet. About the same with more torque on an 03 636 with 05-06 636 cams (same as 03 RR kit cams, but, cheaper).
Can't comment on the other stuff.
post #25 of 66 Old 12-10-2012, 07:26 AM Thread Starter
Super Moderator
EvilTwin's Avatar
Well with BMW's PC MOSS system, you can see everything going on in the bike, and a lot of what was going on while riding the bike. And you can pretty much adjust anything you want, but only dealers, and perhaps certified race teams are allowed to have those. It might be a little easier to find their old computer system these days, since they got fazed out, but they're a little harder to use, and not as in depth. BMW has a lot of cool features and toys, it was cool getting trained on them.
What Greenmeany said.
EvilTwin is offline
post #26 of 66 Old 12-10-2012, 07:36 AM Thread Starter
Super Moderator
EvilTwin's Avatar
I got to talk to the founder of ECU Unleashed this weekend at the IMS, and really pick his brain about this topic. He agreed with my 100% that the best way to go it to pair a fuel controller with a flashed or race ECU. Especially when it comes to flashing, he said that the maps that are being put in the flashes are just guesses, with the exception of the R1 and R6 maps, because he worked for Graves for a number of years, and knows exactly what those bikes need. But even on the Yamahas that get a very accurate base map in the re-flash, you'll still need to re-tune every once in a while, and it's way easier to just have a fuel controller, and make the adjustments in that.
EvilTwin is offline
post #27 of 66 Old 12-10-2012, 11:42 AM
Cav
Cav's Avatar
I Ride: 2009 ZX6R
Okay it all makes sense
You say 10hp with stock map, how much can be gained with a custom map?
Thanks by the way !!
Cav is offline
post #28 of 66 Old 12-10-2012, 04:45 PM
ZX6RRECTION's Avatar
Damn ...good thread baby...I'm still not sure there's much to be gained at the 600 level
ZX6RRECTION is offline
post #29 of 66 Old 12-11-2012, 06:02 AM
greenmeeny's Avatar
Custom map anything from 2-5 hp, in my experience, depending on skills of tuner. It's what a custom tune does with delivery and where + how you want it done, for max hp or street etc, that matters.
post #30 of 66 Old 12-11-2012, 02:20 PM
Cav
Cav's Avatar
I Ride: 2009 ZX6R
Bloody hell... Upto 5bhp just from a custom map... ?! So potentially 15bhp increase for maybe £900 (racefit growler, link pipe, gutted headers, flashed ECU, bazzaz Z-Fi, custom map and air filter) plus about 6kg lost from the exhaust... Fair play i want this bike soon.. Maybe a year to modify to that level on an apprentice wage!!
Cav is offline
The Breakdown on Fuel Management Systems EvilTwin Mechanical and Technical 125 12-22-2015 03:16 PM
