Looking for a new map on my 09 zx6r monster Ed. - ZX6R Forum
post #1 of 12 Old 03-23-2013, 05:51 AM Thread Starter
I Ride: 2009 Zx6r Monster Edition
Hey guys,
Currently I have a modified 09 zx6r monster edition with a TBR juice box pro with the full exhaust preset map ( preloaded for TBR full exhaust n race filter) i wish to go to a better map based on my specific parts. the TBR is compatible with pcv maps btw. So here's my parts list.......
Full akrapovic exhaust (unsilenced), jumper mod, race air filter, Ivan's servo eliminator, 15/43 vortex sprockets, speedohealer v4, Ivan's smog block off plates kit, NGK IX iridium plugs, soon to have XTRE.
Just looking for a more specific map....I will later get the map perfected at a Dyno shop. Any help please .. Thank you
ThedevilTJ87 is offline
post #2 of 12 Old 03-23-2013, 09:18 AM
Kozaru's Avatar
I Ride: 2008 Concours 14
Jumper mod on an '09?
Kozaru is offline
post #3 of 12 Old 03-23-2013, 06:54 PM Thread Starter
Ya it was on this forum that you could do it on 09+.. Anyways I'm looking for a new map based on those mods
post #4 of 12 Old 03-23-2013, 07:21 PM
Lobster's Avatar
I Ride: 2008 ZX6R x2 (Track)
Odd, I've been told that 2009's cannot be jumpered.
Some even speculate that all it does it mess with the butterflies and is only good for 1 hp which is marginal.
I know a buddy who dyno'ed after his "jumper mod" on his 2009. No changes.....at all.
Lobster is offline
post #5 of 12 Old 03-23-2013, 07:27 PM
cwcb08's Avatar
I Ride: 2012 ZX600RCF - 2008 ZX600J8F - 2007 ZX600P7F
Mod doesn't work on the 09+ models
The models that it does work on it adjusts the timing at the top work properly
They have done back to back Dyno runs with and without the mod, it's in a thread around here somewhere there was a gain with it
cwcb08 is offline
post #6 of 12 Old 03-24-2013, 04:48 PM Thread Starter
Ok that's great and all still haven't seen helping with a diff map setup to use
post #7 of 12 Old 03-24-2013, 08:43 PM
Singularity's Avatar
I Ride: 09' ZX-6R Monster edition
does juice box make an auto tune box?
i have a power commander V and there is an auto tune box attached to it. i do not need to mess with maps, it just tunes it on the go based off the air fuel curve. Comes with a wide band O2 sensor that reads the mix and the box does the rest. I think they go for around 300$
Singularity is offline
post #8 of 12 Old 03-25-2013, 05:58 PM Thread Starter
No i don't think it does sadly. I may eventually switch. I do have the o2 sensor spot on my exhaust.
post #9 of 12 Old 03-25-2013, 06:11 PM
sparkybp's Avatar
I Ride: 2012 Kawasaki ZX6R
You have an o2 bung on your stock 09+ zx6r headers? If mine is the same i could run auto tune too, that would be amazing without having to get a shop involved.
sparkybp is offline
post #10 of 12 Old 03-25-2013, 06:32 PM
oKayH's Avatar
The only way you'll get a better map without dyno tuning is by datalogging with a wideband O2 sensor and adjusting your map accordingly if you record the proper parameters. Those premade maps leave A LOT to be desired.
IDK jack about a juicebox pro. Looks about the same as a PC and Bazzaz at a high level. Def better then the basic juicebox...pretty much just some adjustable electronic filters in three ranges...
CCS EX
More gas, less brake
oKayH is offline
post #11 of 12 Old 03-25-2013, 06:43 PM Thread Starter
Yea I contacted power commander. Their top researcher said the 17-003-003 full race akrapovic tune for the 09 zx6r should work nicely. It's better than the tune I run on my juice box now ( set for TBR full exhaust n race filter). I'll just load the akrapovic one then get it Dyno tuned
post #12 of 12 Old 03-25-2013, 06:47 PM Thread Starter
No my stock exhaust didn't have it. My full akrapovic race exhaust has the o2 bung
FS: $250 Shipped PCV from 2009 ZX6R with professional map scottyblumps Classifieds 5 01-07-2013 02:47 PM
HELP Looking for pc3 map for 2006 zx6r 636 with jardine rt1 slip-on/k&n Danielscully Mechanical and Technical 2 07-25-2012 05:29 PM
custom map for 03 04 zx6r tosto1982 Mechanical and Technical 0 08-07-2011 01:37 AM
05 zx6r With yoshi Slip on Power commander Map?? Onetap Mechanical and Technical 31 06-19-2011 07:13 PM
