Bike falls on it's face at 10,000 rpm and above - ZX6R Forum
  • 1 Post By martydmb
  • 1 Post By Anonymous
post #1 of 15 Old 05-11-2013, 01:39 PM Thread Starter
So I got my 08 fired after it's current re-birth. It ran well when I got it. It was stock with a k&n air filter and a muzzy slip on. Now it has the clean air mod done, k&n and full evo akrapovic system. I havn't installed my pc3 yet as I'm still debating between the 3 and 5. I know it will be running lean with the exhaust on but I didn't think it would fall flat on it's face at 10k. It not bad up until you get the rpms up there.
Any thoughts?
Thanks!
innovativems is offline
post #2 of 15 Old 05-11-2013, 01:46 PM
mbrody83's Avatar
I Ride: ZX6R 06
I was expecting a video after the thread title
TEKARBON Carbon Fiber fairings and mirrors, Sportech windscreen, Vortex sprockets, RK red chain, 12k HID's, Akrapovic Slip-on, PC3,NGK iridium plugs, K&N air filter, CNC chinese levers/ bar ends, red quick release gas cap,Coremoto Red braided brake lines, Powder coated red rims, red LED glow kit, servo mod, Blue LED gauge mod, Custom graphics by whocanitBnow and Krazygraphics, Custom seats by Sleepnsix.
mbrody83 is offline
post #3 of 15 Old 05-11-2013, 01:52 PM
martydmb's Avatar
What are you asking for? Thoughts?... install the fuel controller and get a tune done
PowerGroove likes this.
[[11' zx6r green & black]]
martydmb is offline
post #4 of 15 Old 05-11-2013, 01:56 PM Thread Starter
Just asking for thoughts, I was assuming that with a pc and the right map/tune it will correct this, just surpriced at how bad it is in the upper rpms. It literally hits a wall and won't increase speed once it hits those upper rpms
post #5 of 15 Old 05-11-2013, 02:14 PM
martydmb's Avatar
I seen a few theads on here with the same title before.. I'm sure the tune would fix this and if I remember they call this a dead spot. I'd try to type your title or part of it in the search on here or google and I'm sure you will find more info. Ill see if I can find them also.
Check here once
Powerband hole???
martydmb is offline
post #6 of 15 Old 05-11-2013, 06:45 PM
Anonymous's Avatar
I Ride: 07 ZX6R
Re: Bike falls on it's face at 10,000 rpm and above
Its probably because your really lean, your running a stock ecu w/ a full exhaust and air filter? Your getting air in and out of your motor more efficiently but are not adding any additional fuel.
Get it tuned and your problem will be solved
Martydmb, that was an issue w/ some 09-12 bikes I believe, I haven't heard of any issues like that w/ the 07-08 bikes (my 07 doesn't even move until above 10,000 lol)
martydmb likes this.
Anonymous is offline
post #7 of 15 Old 05-12-2013, 09:08 AM Thread Starter
Thanks guys, i think it's the bike starved for fuel. Just wanted to check. I'll get a pc after i get all the bodywork done.
Thanks again!
post #8 of 15 Old 05-12-2013, 09:10 AM
silversurfer's Avatar
Start with the simple stuff, fuel and spark. Go from there.
silversurfer is offline
post #9 of 15 Old 06-16-2013, 04:32 PM Thread Starter
alright got the pc3 on with the right map and did some more troubleshooting. i'm getting error 62 on the bike and the previous owner had removed the upper butterflies. The bike idles fine but when you get to around 8,000 rpm it just falls on it's face. I had the throttle bodies and cables off to replace the cables. Any help to trouble shoot the error would be much appreciated.
Thanks
post #10 of 15 Old 06-17-2013, 03:47 PM
Steel's Avatar
I Ride: 2004 ZX6RR
Warm it up and rev it in neutral for just a second and see if it easily goes near redline. If it does in neutral but not in gear under load, your fuel pump is probably going.
Steel is offline
post #11 of 15 Old 06-17-2013, 06:41 PM
TooGood's Avatar
I Ride: 2013 ZX6R 636 & 05 636
Check the fuel lines to the secondary injectors. They kick in at 8k. If the line is bent it will get sluggish from 8-14k. Check this picture out. Hope this helps a little http://zx6r.com/attachments/mechanic...0430131801.jpg
2005 ZX6R 636
2013 ZX6R 636
I was once told, "I never stopped crashing. I just got better at it!"
TooGood is offline
post #12 of 15 Old 06-17-2013, 07:26 PM Thread Starter
figured it out. When I put the new wire harness in, I had the TPS and secondary butterfly position sensor swapped. I switched them back, fired it up, no more error light and she's pulling perfect now. Amazing how frustrating something so simple as that can be. Thanks everyone!
post #13 of 15 Old 06-17-2013, 08:35 PM
Dragone's Avatar
hahaha, thanks for the experience and the post up. Congrats on the fix.
Stable rides: I love stable rides
Dragone is offline
post #14 of 15 Old 08-19-2013, 06:51 AM
sanco1988's Avatar
I Ride: 2007 zx6r
I had the same problem what I did was took my injectors out and cllen theme good and drained my fule out off the tank runs like a champ now you might have bad gass in it
sanco1988 is offline
post #15 of 15 Old 08-22-2013, 09:34 AM
MrMulisha's Avatar
I Ride: 2008 Kawasaki ZX6R
I just recently resolved this issue on my 08 zx6r.
I replaced my cam chain tensioner, and my fuel pump
MrMulisha is offline
