Oil light and red warning light flashing after oil change - ZX6R Forum
 20Likes
post #1 of 17 Old 07-30-2013, 12:57 PM Thread Starter
Hey all,
Just got my 07 zx6r last week on Sunday, and the oil wasn't completely dirty but I wanted to do an oil change so I could have a starting point and keep track of the maintenance. Anyway,Iasked the dealership near me what oil they recommended and I used Kawasaki 20W-50. I drained the oil, changed the filter and put in about gallon of the oil. Started the bike and let it run for a few mins, then went for like an 8 mile ride. Now, when I turn the key on, the oil indicator and red light flash, but when I start the bike they shut off. then once I cut the engine off, they flash again. Before the oil change, the oil light and red light would flash for a couple seconds when the bike was turned on, then turn off. Now they just stay on unless the engine is running. I have tried " burping" the filter by unscrewing and screwing back, leaning the bike over as far as I could each side. in the sight glass, it appears there is enough oil ( between the lines) then I start the bike and it's way above the line. what should I do? any advice or input is greatly appreciated and thanks in advance.
justo1013 is offline
post #2 of 17 Old 07-30-2013, 01:00 PM
Light will always flash until the motor is running. The sensor reads for oil pressure... if it ain't runnin'.. it ain't gots no oil pressure.
Start it up... I betcha that little bugger stops flashing.
PowerGroove is offline
post #3 of 17 Old 07-30-2013, 01:08 PM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Thumbs up
Right.
06indigoink and justo1013 like this.
read only one page"
oldninjadude is offline
post #4 of 17 Old 07-30-2013, 01:09 PM
Originally Posted by justo1013 View Post
Hey all,
I'm thinking that you just didn't notice the light behavior prior to the oil change. This sounds perfectly normal, like PG said.
When the bike is running, the clutch assembly is spinning in the oil and splashing it against the cover and the sight glass, which is why the level appears to rise. It's not actually rising, it's just splashing.
justo1013 likes this.
beckzach05 is offline
post #5 of 17 Old 07-30-2013, 02:57 PM
Super Moderator
EvilTwin's Avatar
+1 truth
EvilTwin is offline
post #6 of 17 Old 07-30-2013, 06:15 PM
TheEvilTwin's Avatar
I Ride: ZX6, ZX10, BMW
At risk of turning this into an oil thread, verify this oil will be acceptable when your weather turns cold.
CCS 132 Proudly sponsored by Amsoil, DC-MOTO.net, Manassas Honda Kawasaki and MARRC
2014 #1 RCGT, #2 MWSB, 2014 Sportsman Award, 2013 Amateur of the Year, 2012 Cornerworker of the Year
Follow Motosylum Racing
R6- Bonnie the Pirate 6
R100rs- 66k and counting!
R1200 GS/A- The moose is loose!
KTM 400 XCW- Riding dirty!
TheEvilTwin is offline
post #7 of 17 Old 07-30-2013, 06:46 PM
jchilly92's Avatar
I Ride: 2002 ZX6R
put your bike upright and level, after its been cold for a while. see where the oil lays when its cold. if its still above the top line, loosen the drain plug so some oil can escape. Do this as needed.
Survived The Mayan Apocalypse
2002 ZX6R Emily
My Build: http://zx6r.com/build-thread/37297-j...r-project.html
-Black Hel SS Lines
-Speed Bleeders
-Chinese Double Bubble
-K&N Air/Oil Filter
-Chinese Shorty Levers
-NGK Iridium Spark Plugs
-Leo Vinici SS Slip-on
jchilly92 is offline
post #8 of 17 Old 07-30-2013, 07:01 PM
givuhcky22's Avatar
I Ride: 2015 636 Carbon Grey
as stated, when the bike is on, but the engine is not running, the lights will blink. thats what they do.
givuhcky22 is offline
post #9 of 17 Old 07-30-2013, 07:05 PM
trackdayhero's Avatar
Who told you 20W50? The book says 10W40, but like stated, the lights are working as advertised. Here's what the service manual says to use:
API SE, SF or SG
API SH, SJ or SL with JASO MA
Viscosity SAE10W-40
trackdayhero is offline
post #10 of 17 Old 07-30-2013, 07:16 PM
AlexZX6R's Avatar
Sounds legit. Normal. That light goes out as soon as the oil sensor is satisfied.
AlexZX6R is offline
post #11 of 17 Old 07-30-2013, 08:50 PM
I Ride: 07 ZX6R
Justo did all this answer your question?
gsxrdoug is offline
post #12 of 17 Old 07-30-2013, 09:27 PM
Also, you're holding the bike straight up and down (off the stand) to check the level in the sight glass right?
post #13 of 17 Old 07-30-2013, 11:51 PM
Jaamonliu's Avatar
I Ride: 2007 Zx6r
I have a 07 and it does the same thing, its normal. I went to one of the dealership and asked the tech support peeps and they told me I dont have to worry about anything, blinking is normal when the engine is off but if it still blinks or stays on when the engine is on, then you got a problem buddy~
Jaamonliu is offline
post #14 of 17 Old 07-31-2013, 05:17 AM Thread Starter
thanks everybody for the responses, really appreciate it. I feel much better now
post #15 of 17 Old 07-31-2013, 07:41 AM
groomlake's Avatar
I Ride: ZX-14R - Godzilla
Thank God this problem was solved!! The drama was overwhelming, if not oppressive to the point of paranoia. I hate paranoia, and when I'm paranoid, I see things that are not there. When I see things that are not there, I change my meds. When I change my meds I feel like Superman. When I feel like Superman, I am invincible. When I'm invincible, I drive my ZX at 150 mph to the nearest college sorority house and show the girls my cape and tights. When I show the girls my junk covers, I get arrested. Don't get arrested; check your owners manual...
Drive your bike like there's a drone watching you... You'll survive, get really old and have to give your wife Viagra for Women...
groomlake is offline
red light flashing with oil indicater before starting bike sammy beatz Mechanical and Technical 9 07-10-2013 01:01 PM
fi flashing and red light MsPrincess Mechanical and Technical 15 06-12-2012 09:43 AM
Red light flashing?? Azballa7 Mechanical and Technical 11 03-22-2012 08:51 PM
Red light flashing on new bike Step7f Mechanical and Technical 12 12-05-2011 02:13 PM
Stalled bike and red oil light came on ACD1055 United Kingdom 17 08-17-2011 10:18 AM
