Is Engine Temperture Normal? - ZX6R Forum
 9Likes
post #1 of 35 Old 10-17-2013, 10:21 AM Thread Starter
FreestylRoam's Avatar
I Ride: Proud Owner of a Kawasaki Ninja ZX-6R 2005 C1
My Kawasaki Ninja 636 2005 runs around 208 degrees in F at idle is that normal or should it be lower?? because its get somewhere around 220F when driving?? any advice.. Answers etc??
FreestylRoam is offline
post #2 of 35 Old 10-17-2013, 10:26 AM
Ebster1085's Avatar
Your initial comment about 208 degrees farenheit at idle sounds percfectly normal. If my bike is idling and just sitting still for an extended period of time, it regularly is over 200 degrees.
Now if you are running at 220 while you are driving, I would say that is more abnormal. Your engine temp should be lower while you ride simply due to the air circulating through the radiator. When I am at the track with the bike pinned at the top of the power band for 20 minute sessions, I run around 185 degrees and that is HARD riding.
Track Bike: 2006 ZX6R
Daily: 2007 Speed Triple
A link to my build thread!
Ebster1085 is offline
post #3 of 35 Old 10-17-2013, 10:36 AM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Mine can be 150ish to 200+ish depending on traffic.
No traffic open road, It almost never gets above 165ish.
Stuck in traffic on a hot day, 220 sounds about right.
read only one page"
oldninjadude is offline
post #4 of 35 Old 10-17-2013, 10:38 AM
Jperez's Avatar
I Ride: 2012 ZX6R
Outside temp and climate will affect engine temp as well while idling or riding.
Hotter outside temp means hotter engine temp and vice versa.
Ebster1085 likes this.
Jperez is offline
post #5 of 35 Old 10-17-2013, 10:39 AM Thread Starter
oooh ok I was just worried because it ususally sits around 185 idle when its chill in the morning and I live in GA and winter sort of never comes and yesterday it was a 185 idle but today in the morning its like 65 degree outsite and the temps were at 208.. and I kinda flipped out because its usually around 215 when riding.... but then again I could be because I did a change of oil and filter and the oil I used this time was Castrol Synthetic and not mobil........
post #6 of 35 Old 10-17-2013, 10:43 AM
I doubt your oil has anything to do with it.
Have you checked the coolant?
read only one page"
post #7 of 35 Old 10-17-2013, 10:53 AM Thread Starter
Just Checked and Yeah It Was The Coolant....
post #8 of 35 Old 10-17-2013, 10:56 AM
Grim's Avatar
I Ride: 2006 ZX6R
That is an average idle Temp, depending where you are it can be higher or lower.
Even though the ZX6r is a liquid cool bike it still likes to have air flowing over it, they designed the bike for the track and to always be moving, constantly having air cooling the motor down, not stop and go traffic so you are going to see higher temp levels in traffic. Nothing to bee worried about though.
Grim is offline
post #9 of 35 Old 10-17-2013, 11:11 AM
If he is not stuck in traffic & seeing temps constantly in the 208-220 range?
Thats not normal.
FieldDay, Ebster1085 and groomlake like this.
read only one page"
post #10 of 35 Old 10-17-2013, 11:28 AM Thread Starter
Replaced The Coolant and cleaned the system out and put new fresh antifreeze.. Followed one of the guides on how to fully clean a cooling system in the forums after water was coming out clear put anti freeze and etc. now running back 185F idle and 208 Driving
post #11 of 35 Old 10-17-2013, 11:31 AM
Ebster1085's Avatar
Still dont quite understand how your temps are higher while riding. What is the air temp? How fast are you riding? What RPM do you typically cruise at?
post #12 of 35 Old 10-17-2013, 11:40 AM
lance22me's Avatar
I Ride: 2008 ZX6R SE, 2014 Street Triple R
When the weather is COLD (MN October) I run from about 175 degrees up to about 205. When the weather is HOT (85 degrees and warmer) I run at about 225 most of the time.
When it is VERY hot and I'm in stand-still traffic, my engine temp can be in the 230's.
At 240 your engine temp light will start flashing, and at 250 it stops displaying the temperature. At that point you need to pull over and end the ride.
Minn - uh - SOOO - tuh
lance22me is offline
post #13 of 35 Old 10-17-2013, 11:59 AM Thread Starter
I Cruise around the city at 6K RPM with around 45MPH in 6th gear lol ....
My Tranny Was rebuilt cause I screwed it up when I was learning my first 2 weeks were basically h---
Running Custom Gear ratios hydraulic clutch, not cable
post #14 of 35 Old 10-17-2013, 12:09 PM
tails636's Avatar
I Ride: 06 Black 636
I never ever have my bike cruising in 6th gear unless I'm on the freeway. Especially if I'm riding around city, hardly ever take it past 4th. The bike is built to run at high rpms so you're not gonna hurt it by running it that way. However, I too am still baffled at how your engine temp is higher while riding rather than idle. Mine spikes when I come to a stop or a light for a couple minutes, but the second I start riding again it drops
2006 ZX6R (636)*Yoshimura RS-5 Slip on*Power Commander*Vortex -1/+2 Front and Rear Sprockets*EK 520 Gold Chain*Bohemian Racing Gold Rearsets*Integrated Tail Light*Smoked Flush Mount Front Signals*Hotbodies Blacked Out Windscreen*Frame Sliders*8000K HIDs*Adjustable Lowering Links (currently lowered 1 1/4")*Tank Pad*Stomp Grips
tails636 is offline
post #15 of 35 Old 10-17-2013, 12:22 PM
Grim's Avatar
I Ride: 2006 ZX6R
Don't do this....
You can very easily do 45MPH in 4th gear without damaging your trans. Running 45MPH in 6th gear is forcing your engine to work harder and suck more fuel.
In the city you should hardly ever get out of 3rd gear. It's an inline not a V-twin, you can go up to 10,000 RPM without even phasing the motor or trans. You are the opposite of the guy i hear riding at 50MPH in 2nd gear saying to myself "change gears you ass" I would be telling you to downshift as i hear your engine struggling.
groomlake likes this.
Grim is offline
cooling , engine temp , machanical , technical
FS: Running '04 ZX6RR engine Steel Classifieds 1 06-24-2013 03:42 PM
normal engine sound 6ixxer The ZX6R 22 03-21-2012 09:53 PM
Will engine ice freeze Kazoo6942 Mechanical and Technical 7 01-12-2012 12:01 PM
2011 zx6r engine noise (normal?) Dcook0 Mechanical and Technical 16 09-26-2011 11:53 PM
