Yoshimura RS-5 insert/baffle - what am I missing? - ZX6R Forum
post #1 of 29 Old 12-27-2013, 08:48 PM Thread Starter
trackdayhero's Avatar
So I put a full Yoshi RS5 system (race version) on both my '08s. They came with this insert to reduce the sound and it looks like it should just slip right in and lock in with a screw. It doesn't just slip in. I started to pound it in with a rubber mallet and the ring went about a quarter of the way in when I realized "how will I get it back out when I go to the track?" So I stopped pounding it in and tried to get it back out. I finally got it out by threading the screw into the ring from the inside, wrapping a heavy piece of wire around the screw, made a loop and started yanking on the loop with a 12 pound sledge and it finally popped back out. I gotta thing I'm doing something wrong. The instructions don't make any sense to me. Here are the 4 steps listed in the instructions:
1. Remove muffler from tailpipe
2. Insert the front insert into the tailpipe.
3. Reinstall the muffler.
4. Insert the rear insert into the end of the muffler and secure using the small allen head bolt.
Here's a picture of the insert and the instructions I found on the Internet:
Yoshimura Low Volume Insert Kit, RS5/RS8 (INS-09-K) - MotoWiki
And yes, I took the screw out before trying to insert it. I *think* it might be a very tight fit on purpose but I don't want to screw it up. I guess I'll just leave it out but I like being as quiet as possible on the street. I don't want people hearing what I am doing.
trackdayhero is offline
post #2 of 29 Old 12-27-2013, 08:53 PM
06ZX636R's Avatar
I Ride: 06 6R
TDH, something to think about, is it possible you need to remove the end cap to install the baffle? I have seen that in previous versions of the RS-5.
Winner ~ 6OTM February 2013
Cory's 636
Originally Posted by Youssef636
Lol I guess every now and then god must sacrifice the fate of a Moped rider just to help us two guys prove a point.
Originally Posted by mr5drums View Post
i can imagine you goin:
"oooooooOOOOOO shitshitshitshitshitshitshitshit....WHEEEEWWWWW"
06ZX636R is offline
post #3 of 29 Old 12-27-2013, 08:55 PM Thread Starter
I actually thought about that but the picture makes it look like it should slip right in the back and it seems to be that simple. The instructions are extremely poorly worded if that is the case.
post #4 of 29 Old 12-27-2013, 08:56 PM
06ZX636R's Avatar
I Ride: 06 6R
I'm going to PM you a link. Take a look at that.
Cory's 636
06ZX636R is offline
post #5 of 29 Old 12-27-2013, 09:01 PM Thread Starter
Yeah I saw that but it's a different type. I'll see what Yoshi has to say. They got right back to me on my last question.
post #6 of 29 Old 12-27-2013, 11:58 PM
laggy311's Avatar
I Ride: 2006 ZX6R, 1994 Honda V45 Magna, A Village Bicycle
Are you putting it in from the engine side (front)? Because that's clearly what it's saying. Is the main body of the insert the "front insert" then the dark ring goes on the outside once it's all the way through? In which case it's unfair to call the rear insert an insert. It's more of a cap.
The black cap end (rear) of the tube probably tapers down, because the rear exit of the muffler probably tapers down. Which would explain why it wasn't going in. Try taking off the exhaust can and slipping the tube in (minus the black part), angled end first. Make sense?
ffiber1211 likes this.
Easy answer bro....
Thug is native American
Part it out. Claim it stolen
laggy311 is offline
post #7 of 29 Old 12-28-2013, 03:45 AM
ffiber1211's Avatar
Went and looked at one, see next post.
Love&Prayers out to THUGnCARI
ffiber1211 is offline
post #8 of 29 Old 12-28-2013, 06:06 AM Thread Starter
Clearly that's what you would think by looking at the instructions but it's clear when looking at the muffler that's not going to happen. Here's a picture of the muffler. It still has a pipe in it in the picture but I took that pipe out and there is no way that insert is going in from that direction because if the angle, even without the ring on it. I think it's just a tight fit. The problem with that is I think the only way I would ever get it back out is to drill the rivets and remove the end cap and punch the ring back out from behind.
post #9 of 29 Old 12-28-2013, 06:09 AM Thread Starter
In fact maybe that's the only way to put it in as 06ZX636R suggested. Maybe it only fits in from behind the end cap. If that's the case they need to update the instructions to make it a little more clear.
post #10 of 29 Old 12-28-2013, 07:50 AM
06ZX636R's Avatar
I Ride: 06 6R
That's exactly what I was thinking.
Cory's 636
06ZX636R is offline
post #11 of 29 Old 12-28-2013, 10:00 AM
laggy311's Avatar
I'm so jealous of that exhaust, btw. So pretty.
Easy answer bro....
laggy311 is offline
post #12 of 29 Old 12-28-2013, 10:04 AM
laggy311's Avatar
Just weird. Are you using this for track? Couldn't you just keep the stock can, or would it not mate up to mid pipe properly?
Easy answer bro....
laggy311 is offline
post #13 of 29 Old 12-28-2013, 10:15 AM
laggy311's Avatar
http://youtu.be/dvvl9-krXAU
Easy answer bro....
laggy311 is offline
post #14 of 29 Old 12-28-2013, 11:08 AM
ffiber1211's Avatar
There is a free flow baffle in there now. Remove the rubber plug under exhaust tip to gain access to the screw. Remove screw and remove track baffle. Install restricted baffle in its place. Loctite and replace screw.
post #15 of 29 Old 12-29-2013, 02:53 AM
laggy311's Avatar
Gangster. Who knew?
Easy answer bro....
laggy311 is offline
abour yoshi rs5 remove end cap
does yoshimura rs5 exhaust have a removable insert
i need a yoshi baffel for zx10r
inserting baffle on yoshimura trc
yoshimura low volume insert grom
yoshimura rs 8 front baffle
yoshimura rs-5 baffle
yoshimura rs-5 remove
yoshimura rs5 baffle
yoshimura rs5 baffle removal
yoshimura rs5 remove baffle
yoshimura rs8 baffles inserts
Yoshimura Fend Elim for dummies GearHedgehog The ZX6R 7 04-27-2014 03:53 PM
FS: 09-11 yoshimura exhaust seagrave6 Classifieds 7 02-18-2012 10:43 PM
Missing the captain The ZX6R 1 12-15-2011 02:09 PM
09-10 Yoshimura TRC Carbon Fiber Full System $700 shipped snatfinder Classifieds 3 06-19-2011 08:16 AM
