Spark plugs - ZX6R Forum
 5Likes
  • 1 Post By jerryg951
  • 1 Post By NitrusReigns
  • 3 Post By riverszzr
post #1 of 11 Old 05-24-2014, 06:36 PM Thread Starter
I Ride: 2005 ninja636
Spark plugs
So I replaced my spark plugs with the original equipment 05 636, I think they were br6e plugs. Anyways my bike doesn't seem to run the same . I have a power commander and K&N and m4 exhaust wi hollowed exhaust pipe. It doesn't have the power it used to and i have to play with the idle roger it to stay running . I only changed plugs and it was running great before but the plugs had 25k on them so I thought I was doing something good for myself. Apparently not. ,! Do I have to change my map cus the plugs?
Sethboy716 is offline
post #2 of 11 Old 05-24-2014, 06:37 PM Thread Starter
Not idle roger! Lol I have to turn the idle up when I strt it cold and then turn it down when it warms up. Didn't have to do any of this before. .... Any ideas?
post #3 of 11 Old 05-24-2014, 07:10 PM
jerryg951's Avatar
I Ride: 09 zx6r
Did you gap them right and put everything back together right almost sounds like a vacuum or intake leak I would take it apart and double check everything
AlexZX6R likes this.
jerryg951 is offline
post #4 of 11 Old 05-24-2014, 09:23 PM
AlexZX6R's Avatar
I think so too. Air leak.
AlexZX6R is offline
post #5 of 11 Old 05-26-2014, 05:05 AM Thread Starter
Well it's not a vacuum leak ,,,, checked all around . I didn't gap the plugs tho. Being a car mechanic, I guess I should've checked but car spark plugs have been coming pre gapped for like over a decade now lol! So I didn't even think of it but your right small engine plugs like mowers and equipment your supposed to check gap on, and br6e prolly do go into small engines,,,,, I'll have to check, I did however go into my map and change the 0% throttle fueling settings to 0 .... They were at 10s on the map but it smoothed right put when I did that,,, my big problem is that it has less throttle response than it did when I first installed the PCV,, soooooo..... Thx for the ideas...
post #6 of 11 Old 05-26-2014, 05:40 AM
Ebster1085's Avatar
Can you verify what plugs you used? You should be using CR9EK plugs or if you want to "upgrade" to iridium use CR9EIX plugs. If you went with the CR6 series that heat range may not be optimal for the bike.
Track Bike: 2006 ZX6R
Daily: 2007 Speed Triple
A link to my build thread!
Ebster1085 is offline
post #7 of 11 Old 05-26-2014, 06:51 AM
corkoli's Avatar
I Ride: Kawasaki ZX6R '09
Replace old plugs and test. Fiddly and annoying, i know
corkoli is offline
post #8 of 11 Old 05-26-2014, 06:55 AM
NitrusReigns's Avatar
Yup, this would tell you whether it's the plugs or whether something else got messed up
jerryg951 likes this.
NitrusReigns is offline
post #9 of 11 Old 05-26-2014, 07:13 AM
You don't have your facts correct.
A B series spark plug is a 14mm, no way no how you shoved a 14mm plug in a 10mm hole
The plugs that came stock are CR9E, so recheck what plugs you installed, if you truly went to a CR6E. I think you know where there problem originates from
And spark plugs have came pre-gapped for as long as plugs have been made, but you still need to check the gap and make sure it is correct for your application.....on all vehicles.
NitrusReigns, Ebster1085 and Raven like this.
post #10 of 11 Old 05-26-2014, 07:37 AM
Raven's Avatar
I Ride: 07' ZX6R
All it takes it a slight bump on the electrode to throw the gap off on the plugs. As River said ALWAYS double, triple check the gaps before putting them in. Kinda like cutting wood, measure twice, cut once kinda thing. Not to mention checking that you have the right series plug in first place.
" It's not about how fast you can ride, but how you ride fast. "
Raven is offline
post #11 of 11 Old 05-26-2014, 03:46 PM Thread Starter
I pulled the old plugs out of the garbage and made sure they are the same and they are cr9e. So I went onto the PCV thing and I changed maps to find one Thad idle better and I found one that the 0% throttle settings were all zeros and it idles great now! So I went back into my map and changed the settings to all zeros for the 0% throttle range and it idles beautiful now.... But I think the map has everything to do with it because now it also is like a dog getting on the throttle and letting the clutch out at a stand still in 1st gear... I think I need to tweak my map more or find a different one all together ..... Hs anyone eve r heard that ? Someone who had to change maps after replacing spark plugs to get it to run correctly.
Spark Plugs, what do you run? GTR Racer Mechanical and Technical 49 11-30-2013 11:14 PM
Noticed this while changing spark plugs. dep Mechanical and Technical 24 03-28-2013 02:15 PM
spark plugs question Cap Walker The ZX6R 22 02-24-2013 03:28 PM
New coils or different spark plugs??? Slice3054 Motorcycle Talk 4 12-23-2012 08:37 AM
Trouble accessing spark plugs for removal Wardjp Mechanical and Technical 27 12-07-2012 02:29 PM
