Throttle Body Synch - Page 3 - ZX6R Forum
 26Likes
post #31 of 49 Old 09-30-2014, 02:02 PM
trackdayhero's Avatar
The service manual explains how to do it. You should be able to find the service manual on this site. I also made a home made one last year and have some photos during the sync:
Home made throttle body sync tool
I have since bought some vacuum gauges.
trackdayhero is online now
post #32 of 49 Old 09-30-2014, 02:06 PM
Bennett636's Avatar
I Ride: 2005 Kawasaki ZX-6R 636
Throttle Body Synch
The manual explains it very well. I did mine last week. I have a motionpro sync pro.
What gauges did you buy tdh?
Wrecked/Sold: 2005 Kawasaki zx-6r 636, 15k mi, k&n air filter, muzzy titanium slip-on, jumper mod, servo eliminator, core moto trans blue SS brake lines, michelin pilot power 2ct front and back, gloss black powder coated rear sets.
The new: 2005 zx-6r 636, Magma Red, 21k mi, full muzzys exhaust, PCIII, k&n air filter, laggy a servo eliminator, jumper mod, core moto trans red brake lines, gloss black powder coated rear sets.
Bennett636 is offline
post #33 of 49 Old 09-30-2014, 02:13 PM
boomlouder's Avatar
I Ride: 09 zx6r, 05 GSXR-600
I'm on a budget so will prob build manometer unless I can find vacuum gauges at reasonable price
boomlouder is offline
post #34 of 49 Old 09-30-2014, 02:46 PM
NatBrown's Avatar
The Motion Pro one is the bomb. Tried a number of home made ones over the years and they all sucked compared to the Motion Pro one.
Bennett636 likes this.
NatBrown is offline
post #35 of 49 Old 09-30-2014, 05:37 PM
Bennett636's Avatar
It definitely makes it easy. And I like the fact that you can sync the actual gauges to make sure they are accurate when doin the sync
post #36 of 49 Old 10-04-2014, 12:39 PM
boomlouder's Avatar
Where do you get the tool for precise tachometer
post #37 of 49 Old 10-04-2014, 01:13 PM
Bennett636's Avatar
You don't need that. Just use the tach on the bike. When you adjust cyl 2&3 the idle will go down. Just turn the idle back up and then adjust 1&4
post #38 of 49 Old 10-05-2014, 08:44 AM
boomlouder's Avatar
I'm the guy who wants to do things as accurate as possible if I can. So I do need it just as I decided to use vacuum gauges to set my throttle bodies
post #39 of 49 Old 10-05-2014, 08:51 AM
NatBrown's Avatar
If you want it as accurate as possible you won't use vacuum gauges. You will get much more accurate balance by using on of the Motion Pro style manometers. I've had a set of vacuum gauges and they sucked for doing this work. Very hard to match needles on separate gauges up. Much, much easier to get the liquid in the tubes to the same height.
NatBrown is offline
post #40 of 49 Old 10-05-2014, 08:58 AM
boomlouder's Avatar
I just feel a little better with gauges I calibrate and set machinery off gauges all the time at work. To each their own
post #41 of 49 Old 10-05-2014, 09:33 AM
Dragone's Avatar
I am an analog nut as well.
Stable rides: I love stable rides
Dragone is offline
post #42 of 49 Old 10-05-2014, 09:34 AM
boomlouder's Avatar
Oooo. Where did you get that kit?
post #43 of 49 Old 10-05-2014, 09:39 AM
Dragone's Avatar
ebay.....lol Been using it for a few yrs now. Me likey
Dragone is offline
post #44 of 49 Old 10-05-2014, 09:40 AM
boomlouder's Avatar
I need to find it for sure
post #45 of 49 Old 03-12-2017, 12:20 PM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
Attempted to do a sync on mine today but god it was way off!!!
Anyway, service manual refers to 1-2 / 3-4 equalizing screw
All i could find was this, which is spring loaded and if you push it down, i think it moves the primary butterflies.
Is this the one?
MrZ is online now
05 636 vaccum balance
12 zx6r throttle body flaps
2006 zx6r throttle body
2012 zx6r throttle body
2014 zx6r throttle body
how sync throttle bodies on zx6r
how to sync throttle bodies 2006 zx6r 636
how to sync throttle bodies for 2006 kawasaki zx 6r
how to synch the thottle bodys 2005 kawasaki 636
sync throttle bodies on 2006 zx6r
throttle body sync 2004 zx6r
zx6r throttle body sync
sub throttle actuator code? bike shop says to replace entire throttle body? icrdiblebulk Mechanical and Technical 3 05-12-2014 07:47 PM
05 zx6r - Throttle Body Clamp - Stripped Hex Bolt wtray07 Mechanical and Technical 1 04-15-2014 02:20 PM
Any ideas on throttle body vacuum lines??? t15zx6r Mechanical and Technical 8 03-20-2013 08:35 AM
Need Help...Throttle body sync related....Thanks! Anonymouszx6 Mechanical and Technical 1 03-17-2012 08:19 PM
Throttle body rideordie Mechanical and Technical 15 01-02-2012 03:02 PM
