Throttle Body Synch - ZX6R Forum
 26Likes
post #1 of 49 Old 05-30-2014, 08:36 PM Thread Starter
Throttle Body Synch
I just finished making a manometer to synch the throttle bodies on my 2009 ZX-6R (and the carbs on TBK's 2004).
Parts I used:
  • 2 x 20' Sections of Clear Tubing
  • 2 x F connectors
  • 4 Vacuum Restrictors
  • 2 x Gutter Guards (stacked for mounting everything onto)
  • 50 or so Zip Ties
  • 1 x Bottle of 2-Cycle Engine Oil (Blue)
Construction Steps:
1. Cut a small length of tubing and use it to join the F connectors.
2. Mount the joined F connectors to the bottom of the gutter guard using zip ties.
3. Cut one of the 20' tubes into four equal lengths, and connect them to the F connectors.
4. Attach the four tubes to the gutter guard, using Zip ties every few inches.
5. Put the end of one of the tubes into the 2-cycle oil container, plug two of the other tubes, and then suck on the fourth tube to draw the oil into the system.
6. Remove the tube from the 2-cycle oil and let all the oil in the system settle down to the bottom of the tubes.
7. Put a vacuum restrictor (metal end first) in the open end of each of the four tubes.
8. Cut the other 20' tube into four equal lengths and attach them to the other ends of the vacuum restrictors.
Final Assembly:
Name:	Manometer - Parts.JPG
ID:	28256   Click image for larger version
Name:	Manometer - Assembled.JPG
636MOBIN, MeanGrnZX6RR and TBK like this.
post #2 of 49 Old 05-30-2014, 08:37 PM Thread Starter
Ey3l45h likes this.
post #3 of 49 Old 05-30-2014, 08:57 PM
Ey3l45h's Avatar
Originally Posted by Strider View Post
Ooooooh any way we could get a vid/pics when you use it?
Ey3
The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help.'
The only time a leader should use the word "I" is in the sentence "I have to shit"
'In individuals, insanity is rare; but in groups, parties, nations and epochs, it is the rule.' ~Some dude named Friedrich
'Never trust authority implicitly. People are fucking scumbags.' AvE
Ey3l45h is online now
post #4 of 49 Old 05-30-2014, 09:01 PM Thread Starter
Ey3
Yes, I plan on posting photos and explanation at least!
AlexZX6R, Ey3l45h and jerryg951 like this.
post #5 of 49 Old 05-30-2014, 09:49 PM
jerryg951's Avatar
I Ride: 09 zx6r
Thanks strider I need to do this soon and all the videos I've seen seem like they aren't in depth enough for me to risk throwing them way out of balance
joshgilvin34 and Ey3l45h like this.
jerryg951 is offline
post #6 of 49 Old 05-31-2014, 05:11 AM
NatBrown's Avatar
Very nice job.
NatBrown is offline
post #7 of 49 Old 05-31-2014, 05:16 AM
joshgilvin34's Avatar
I Ride: 2011 ZX6R
How many miles are on your 09? I have an 11 and I'm thinking I'm getting close to having to do this. And I don't have a clue on how to do it.
Hotbodies MotoGP Growler Exhaust
PC5
K&N Air filter
custom led integrated tail light
Driven block off plates
Pine box link pipe
Core moto stainless steel brake lines
joshgilvin34 is offline
post #8 of 49 Old 05-31-2014, 06:24 AM
jerryg951's Avatar
I Ride: 09 zx6r
I have 21k on my 09
post #9 of 49 Old 05-31-2014, 02:18 PM Thread Starter
I have just over 50,000 miles on mine. I recently did a valve adjustment, so I knew it needed the throttle bodies synched. I just finished synching them (they were quite a bit out of adjustment), so in a little while I will update post #2 above with photos/video and a write up.
TBK likes this.
post #10 of 49 Old 05-31-2014, 05:02 PM
TBK
TBK's Avatar
I Ride: '12 ZX6R & '04 ZZR600
We also adjusted the carbs on my 2004 ZZR-600. The setup worked beautifully and my bike idles and cruises much smoother. I was amazed just how easy it was on my bike to get them all synched up.
~TBK
2012 ZX6R
'13 mirror swap - ASV Lever - CoreMoto SS brake lines - M4 GP Titanium
2004 ZZR600
Delkevic Mini 8" (Deaf by choice) - CoreMoto SS brake lines - Dunlop Q3
K&N Air Filter - NGK-CR9EK Plugs - 520 Vortex chain conversion
Modified front fender - Powerbronze Double Bubble
TBK is offline
post #11 of 49 Old 05-31-2014, 05:05 PM
I Ride: 2011 ZX6R
Is this the first time you adjusted the valves and did this throttle body sync in the 50,000 miles?
PC5
K&N Air filter
Pine box link pipe
post #12 of 49 Old 05-31-2014, 06:07 PM
636MOBIN's Avatar
I Ride: 2003 ZX6r
I just finished making a manometer to synch the throttle bodies on my 2009 ZX-6R.
Parts I used:
2 x F connectors
50 or so Zip Ties
Did you take those picks your self ? That shit looks an like ad quality photo
Final Assembly:
Why do those pics look so professional ?
"SLOW IS SMOOTH AND SMOOTH IS FAST"
636MOBIN is offline
post #13 of 49 Old 05-31-2014, 07:07 PM
ConradM's Avatar
He probably used a light box for the first pic... You could make a simple one with construction paper and a cardboard box.
ConradM is offline
post #14 of 49 Old 05-31-2014, 07:59 PM
636MOBIN's Avatar
I Ride: 2003 ZX6r
Learn something new everyday.
636MOBIN is offline
post #15 of 49 Old 05-31-2014, 09:59 PM
636MOBIN's Avatar
I Ride: 2003 ZX6r
Is there a reason you use oil instead of colored water ? Does it affect the way it works at all, I need (more like want) to make one of and this ones pretty dam nice
636MOBIN is offline
05 636 vaccum balance
12 zx6r throttle body flaps
2006 zx6r throttle body
2012 zx6r throttle body
2014 zx6r throttle body
how sync throttle bodies on zx6r
how to sync throttle bodies 2006 zx6r 636
how to sync throttle bodies for 2006 kawasaki zx 6r
how to synch the thottle bodys 2005 kawasaki 636
sync throttle bodies on 2006 zx6r
throttle body sync 2004 zx6r
zx6r throttle body sync
sub throttle actuator code? bike shop says to replace entire throttle body? icrdiblebulk Mechanical and Technical 3 05-12-2014 07:47 PM
05 zx6r - Throttle Body Clamp - Stripped Hex Bolt wtray07 Mechanical and Technical 1 04-15-2014 02:20 PM
Any ideas on throttle body vacuum lines??? t15zx6r Mechanical and Technical 8 03-20-2013 08:35 AM
Need Help...Throttle body sync related....Thanks! Anonymouszx6 Mechanical and Technical 1 03-17-2012 08:19 PM
Throttle body rideordie Mechanical and Technical 15 01-02-2012 03:02 PM
