Bad throttle response/no pull when hitting the throttle? - ZX6R Forum
post #1 of 8 Old 06-19-2014, 03:06 PM Thread Starter
hey guys,
So my bike's been running like money UNtil this past week. Im Gettin real sluggish response when i rip on the throttle. I mean like i open this son of a gun up, get on it ya know, and my rpms are NOT matching what im doing with the throttle. Even when i get in the power-band im not gettin the same pull.
Now, idk if its cause im running rich/lean mixture, or if its the clutch/clutch cable, throttle bodies, need a new air filter? etc? Not quite sure and its really botherin me ill be honest. So, i thought id ask for some advice..
P.S. also been running kinda hot? like cruising 75mph at 190F temp. Literally just put some new engine ice in there two weeks ago, i do ride kinda hard, rarely get up into 5th-6th gear, average temp is anywhere from 75-85 degrees where i live. Kinda bothers me too cause i should be operating between 175-180F
2008, no PC or fuel controller, just two brothers exhaust, everything else stock with some accessories.
I will add, if it helps, when I'm stopped then go to take off in first gear, i hit the throttle and my rpms lag (don't match what I'm doing with the throttle) and all of sudden ill get a quick shot of power, like a little blip/burst, kinda trying to say the bike like all of sudden jerks and takes off just for a sec.
TH3WOLF is offline
post #2 of 8 Old 06-19-2014, 03:37 PM
TYGUY's Avatar
I Ride: Time capsule 03 ZX6R
im thinking air or fuel... have you checked anything like the air filter or the fuel strainer? running hot kinda sounds like air intake obstruction. clutch shouldn't be doing what you're describing.
TYGUY is offline
post #3 of 8 Old 06-19-2014, 04:39 PM
zx racer's Avatar
I Ride: 04 ZX-636
When the last time the bike had any maitence done to it like spark plug change, airfilter, oil change, coolant flush? Slipon exhaust wouldnt cause it to run hot could be thermostat isnt workin properly are coolant needs to be changed or low check the basics and report back.
zx racer is offline
post #4 of 8 Old 06-20-2014, 01:27 PM
Super Moderator
EvilTwin's Avatar
As far as the 07-08 models go 190 is running cool. That model runs hotter than all the other ZX6Rs, my 07 pretty much never went below 190 in the summer.
It sounds like you've got a fuel delivery issue. Hows the idle, does it lope at all or want to idle lower than normal?
EvilTwin is offline
post #5 of 8 Old 06-20-2014, 04:16 PM
Agent007's Avatar
I Ride: 2001 ZX-6R
slipping clutch?
Agent007 is offline
post #6 of 8 Old 06-20-2014, 04:58 PM
Oldhead's Avatar
I Ride: 05 zx6r
190 is not hot and did you just change plugs?
Oldhead is offline
post #7 of 8 Old 06-20-2014, 05:52 PM Thread Starter
Thanks for the replies..
Changed coolant 2 tweeks ago (engine ice), havent checked my plugs or air filter but i plan on doing that this weekend. idle is around 1200, when i start it up and let it warm in the mornings once it gets to around 144-145 you hear it start to do a "chugga chugga chugga chugga.. chugga chugga chugga chugga" different tempo if ya get that.
Agent007, slipping clutch was a thought but i do want to lean toward an air/fuel problem here because i can kinda even feel the combustion (sounds stupid i know) through the throttle and somethin aint workin the way its supposed to.
PS, other threads ive looked at regarding clutch slippage people have said if it was slipping i would definitely know, so maybe i can rule that out. Till then suggestions are much appreciated, thanks again.
TH3WOLF is offline
post #8 of 8 Old 06-21-2014, 06:03 AM
Question
i been having the same problem . my 07 zx6r is running hot. hot days im around 200 around town. also i am getting the same noise/misfires. i changed my thermostat and haven't noticed a significant difference. also put a new set of spark plugs in. I been really worried about this since its my first bike. i keep reading around that this temperature isn't too much of an issue since these bikes tend to run hot. (still alarming though) any help and suggestions are greatly appreciated.
lonerider is offline
2013 ZX6R 636 Choppy Throttle Issues! Stevieg The ZX6R 30 04-04-2017 10:09 PM
