Titanium fasteners - ZX6R Forum
 4Likes
post #1 of 27 Old 08-06-2014, 07:27 AM Thread Starter
NatBrown's Avatar
Titanium fasteners
Anyone have any experience with the titanium bolts they sell on e-bay? Yes, I aware that Chinese stuff is generally "you get what you pay for". But they are so much cheaper than buying from Pro-Bolt or Yoyodyne.
4pcs Titanium TI for Ducati Front Brake Caliper Bolt M10 x 60mm Taper Head | eBay
ROCKBROS Titanium TI Ducati Front Brake Caliper Bolt M10 x 60mm Conical 4pcs | eBay
Also, does anyone know if the race spec caliper bolts that Pro-bolt sells will actually work with the stock calipers on an '07?
Pro-Bolt Titanium Front Brake Caliper Mounting Bolt Kit Race Spec
NatBrown is offline
post #2 of 27 Old 08-06-2014, 07:33 AM
Ey3l45h's Avatar
Gotta ask, have you done all the easy stuff to bring down weight?
Personally, if it's important and I don't want it to fail, I don't use eBay Chinese stuff.
Ey3
MasterTurkey likes this.
The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help.'
The only time a leader should use the word "I" is in the sentence "I have to shit"
'In individuals, insanity is rare; but in groups, parties, nations and epochs, it is the rule.' ~Some dude named Friedrich
'Never trust authority implicitly. People are fucking scumbags.' AvE
Ey3l45h is online now
post #3 of 27 Old 08-06-2014, 07:40 AM
Sandman's Avatar
I Ride: 16 WRX, 11 Fusion
Best bang for the buck in shedding weight is a lithium battery. The biggest potential weight loss is in a full exhaust (Ti if you can afford it).
Realistically, how much weight do you think you'll save by changing some aluminum bolts?? With all the money you'll spend on Ti bolts ..... just put money towards something better.
Sandman is offline
post #4 of 27 Old 08-06-2014, 07:45 AM
Ebster1085's Avatar
Personally, I say this is an astronomical waste of time and money. Are the few ounces you may shed really going to result in any difference? What is the point of this?
If you want to shed weight, as others stated, a cheaper, easier, and more fruitful place to start is with a small lightweight battery.
Track Bike: 2006 ZX6R
Daily: 2007 Speed Triple
A link to my build thread!
Ebster1085 is offline
post #5 of 27 Old 08-06-2014, 07:51 AM
SSGSXR ZX6R's Avatar
I Ride: 05' GSXR 1000 05' GSXR 600 04' ZX6RR
I used pro bolt titanium bolts on my old bike. Did EVERYTHING, engine, to subframe, calipers, ect.
Good for if you are that into dropping weight but better used on an actual AMA race bike. Only shed 23 lbs from the bolts which cost vs weight was a little outrageous. I think total i spent $800+ on bolts
A man without tattoos is invisible to the gods - Iban Proverb
SSGSXR ZX6R is offline
post #6 of 27 Old 08-06-2014, 08:01 AM
Ebster1085's Avatar
Agreed, and thats insane!
23 pounds does seem like a lot though. You sure about that??
post #7 of 27 Old 08-06-2014, 08:41 AM Thread Starter
NatBrown's Avatar
Really didn't want a discussion about weight savings. I've already got a full Ti Akro exhaust and a LiFe battery. Started looking because I need to replace one of the stock caliper bolts because the hex is rounding out. The Chinese Ti bolts are actually less expansive than the OEM bolts.
I wouldn't start trying to drop weight with Ti bolts on the sprung components anyway but on the unsprung parts of the bike it wouldn't be a bad idea to take some of the weight off. Particularly if it cost less than OEM fasteners.
Additionally, the drilled hex head bolts would be ideal. I hate those allen headed stock fasteners in that location.
NatBrown is offline
post #8 of 27 Old 08-06-2014, 08:44 AM
smokey11's Avatar
Whoa!!! Is that correct or a typo, you lost 23 lbs from just switching bolts? At $800 I'd say that is worth it if correct after doing everything else you can, exhaust, battery subframe etc. Lightweight battery only save 7-8 lbs but is a good place to start.
__________
Mods
smokey11 is online now
post #9 of 27 Old 08-06-2014, 08:47 AM
Sandman's Avatar
Even so, I'd still be wary with any aftermarket bolts.
There is a lot of engineering in these bikes to include the bolts. They're manufactured pretty specifically for the application. For example, some bolts are made to break, some bolts are made to bend. That's lost with aftermarket.
I mean, it's your bike, it's your money, it's your decision -- but *I* would replace what's messed up and then continue looking elsewhere.
Sandman is offline
post #10 of 27 Old 08-06-2014, 09:16 AM
Yeah during my build I kept having it scaled from what I did. If you remember I even modified the rear subframe (cut and bent) to still be able to use a race tail without any fasteners.
VS OEM
post #11 of 27 Old 08-06-2014, 09:44 AM
cwcb08's Avatar
I Ride: 2012 ZX600RCF - 2008 ZX600J8F - 2007 ZX600P7F
start by shortening the oem bolts and drilling out the centre
WERA Novice #188
2012 ZX600RCF Lime Green / Metallic Spark Black
2008 ZX600J8F - TrackBike - For Sale
2007 ZX600P7F - Track/Race - Ex Canadian Superbike Championship Bike
cwcb08 is offline
post #12 of 27 Old 08-06-2014, 09:51 AM
Ebster1085's Avatar
So your 23lbs of weight loss wasnt due strictly to swapping in titanium hardware. There was a lot more involved.
post #13 of 27 Old 08-06-2014, 10:00 AM
smokey11's Avatar
Yeah now I'm confused...
__________
Mods
post #14 of 27 Old 08-06-2014, 10:05 AM
No no no, it was ~23lbs just for the bolts, I was saying when I went through everything I had It scaled per what I did. Subframe then wheels then bolts then airbox and so forth.
Dry it was 387lbs all said and done (roughly GSXR600/750 weight) if I remember I'll have to go through my thread again.
post #15 of 27 Old 08-06-2014, 10:11 AM
MasterTurkey's Avatar
I Ride: 06 (Track) 636, RIP Carbon the 05 Beauty
I have some bolts like that on my daily (not my doing)... Ti and drilled for weight.
05 636 (Street) & 06 636 (Track)
http://zx6r.com/build-thread/37946-m...-06-636-a.html
"The most dangerous risk of all - The risk of spending your life not doing what you want on the bet that you can buy yourself the freedom to do it later."
MasterTurkey is offline
just titanium headers for a 06? twipz The ZX6R 13 10-17-2013 12:35 PM
FS: FS Leo Vince SBK Factory R Full Titanium Exhaust ZX6Ray Classifieds 19 01-08-2013 11:51 PM
ZX6R F1 F2 F3 (possibly G?) Akrapovic Full Race Titanium System Exhaust rafiKi Classifieds 0 09-20-2012 06:15 AM
titanium scrape plates for sale PRE-DRILLED!!! Dirtytoes Stunting 9 08-01-2011 07:45 AM
$300K Ecosse Titanium FE Ti XX :O ChiZx6r Motorcycle Talk 14 04-09-2011 05:46 PM
