Idle Adjustment Needed or Normal? - ZX6R Forum
post #1 of 4 Old 04-24-2016, 05:56 AM Thread Starter
RoidRageFool's Avatar
Hey everyone,
When I brought the new to me 13 zx6r home, it stalled out multiple times. I accompanied that with the low Idle setting, and it was fixed. On a cold start idle sits right around 1900. When the bike it warm and riding, idle is between 900 and 1100 typically, which does not seem to be an issue.
I was riding the other day, and felt as if my bike was almost pulling while I was trying to brake coming into the stop light and a low speed. Usually I have the clutch pulled so there isn't an issue. (Best way to describe this).
I am not sure If this a problem or if this is usual. This never happened on my R6's before, so I am confused to the next issue.
If I am in 1st gear, let off the throttle and don't pull the clutch, the bike will not stall out and will continue at a steady 5mph. If I am in second gear and let of the throttle without the clutch pulled, it will drop to 10mph and then it will be steady at 10. In 3rd gear it was 13mph. It will actually pull me up a slight grade in the road. Is this normal? I figured if I were to let off the throttle and not pull the clutch, that the bike would stall. But it doesn't seem to be that way. So, it this normal.
Thanks,
James
If you can't win an argument, correct their grammar instead.
Racefit: Not for everybody.....
RoidRageFool is offline
post #2 of 4 Old 04-24-2016, 07:33 AM
The engine wont stall unless u force the bike to get very slow....almost to a standstill. Unless u use the brake or decide to go up a pretty steep hill it will keep going.
Yours sounds normal.
Scorpi0 is online now
post #3 of 4 Old 04-24-2016, 07:44 AM
97grnrs's Avatar
the idle does best around 1400 rpm on most 600s
Check out some of my builds. http://www.zx-10r.net/forum/album.php?albumid=3114
current: 06 gsxr 1000 custom done by me.
97grnrs is offline
post #4 of 4 Old 04-24-2016, 08:43 AM Thread Starter
Thanks and thanks.
Help with Idle Wblueman Mechanical and Technical 12 06-30-2015 07:36 AM
Where did my math go wrong??? Valve Adjustment... dennisplus Mechanical and Technical 48 06-22-2015 11:50 AM
How To Videos: Valve Clearance Adjustment MistressOfMayhem Mechanical and Technical 13 09-19-2012 05:54 PM
Idle / bog / etc... mine_us_3 The ZX6R 21 05-29-2009 05:25 PM
Idle RPMs fluctuations, normal? Cap Walker The ZX6R 7 03-13-2009 01:39 PM
