*HELP: Engine dislocated slightly from Frame! - ZX6R Forum
 13Likes
post #1 of 19 Old 10-10-2016, 08:44 AM Thread Starter
ryanchau96's Avatar
I Ride: 2013 ZX-6R
Exclamation *HELP: Engine dislocated slightly from Frame!
Hi guys, I have a 2013 zx6r with 5000+ miles and I think I might got a slight problem
Background: I had frame sliders on until I low sided at 4500 miles, after the crash I bought the parts and a dealer fixed it.
After the bike is up and running, I took the old sliders out, and didn't put in a new slider and kept on riding (it was VERY silly of me) and forgot that there need to be bolts that secure the engine in the frame slider bolt screw.
Issue: I was trying to fit in new sliders days ago and I realize the engine is already pushed a little away from the frame (shown in picture) and the bolt isn't alined..
Question: Anyone had the same experience or know what should I do or how much would it cost for a dealer to fix it?
DIY isn't an option for me since I live at an apartment and I have no tool or jack to fix it....
Any helps would be deeply appreciated, thank you!
ID:	47049   Click image for larger version
ryanchau96 is offline
post #2 of 19 Old 10-10-2016, 09:33 AM
It's possible that the frame is bent if you rode it without either of the forward engine mounting bolts, but not guaranteed.
The simple answer, if you have no tools, is to take the bike to a qualified shop and ask them to fix it. I'm confident that most people could manage this if they had access to the proper tools and a place they can get away with working on the bike for an hour or two, but I've lived in an apartment before, and I can imagine what that's like. Anyway, here's what the shop you take the bike to will do:
0. Put the bike on a rear stand, or support it via the swingarm with jackstands.
1. Remove the lower fairings.
2. Support the engine from underneath with a floor jack. A scissor jack from almost any car will work, if you just can't get your hands on a floor jack. Be sure to put a block of wood on top of the jack so it doesn't damage the oil pan.
3. loosen the nuts on the ends of the rear engine mount bolts, but do not remove them completely.
4. Turn the heads of the rear engine mount bolts just a little - maybe ten degrees. This will loosen the engine mounts, allowing the engine to be loose within the frame.
5. Raise the jack under engine a little, install the forward engine mount bolts, and torque to spec.
6. Turn the rear engine mount bolts back until they're tight, tighten their nuts, and remove the jack under the engine.
7. Take the bike down off the rear stand and test ride.
If the frame is bent, no amount of raising the engine with the jack (step 5) will be enough to align the forward bolt holes. If that's case, consult a dealer or competent mechanic. The frames on these bikes are aluminum, and once they're bent, there's no truly safe way to bend it back into the proper shape.
Edit: The process I described assumes that your 2013 is similar to my 2005. Your mounts may be a little different from mine, and thus may not be exactly as I've described here. That said, the process is likely to be more or less the same.
MR2Aaron is offline
post #3 of 19 Old 10-10-2016, 11:58 AM Thread Starter
ryanchau96's Avatar
I Ride: 2013 ZX-6R
Ah ok! I'll take it to a kawasaki shop near by and see what they say. I'll make sure I keep this thread updated as well.
post #4 of 19 Old 10-10-2016, 02:19 PM
Simple fix. I wouldn't take it to a dealer...but it also helps to have some tools. I've ran into this a couple of times with other bikes. Actually just happened the other week when I took the broken sliders out of my cbr500 and put the bolts back in. Sometimes even just removing the bolts will allow the engine to drop a bit, just enough to put it out of alignment. All you need to do is push up on it. How you do it is up to you. The first time I had to do it, I ended up using a jack but the second time, it was only slightly misaligned and I was able to just push it up with one hand and start threading the bolt with the other hand. It was very tight so I had to use a wrench all the way from start to end but it worked fine.
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is offline
post #5 of 19 Old 10-10-2016, 04:36 PM
Gawernator's Avatar
Make sure you don't strip the threads. Line it up with a jack
Gawernator is offline
post #6 of 19 Old 10-10-2016, 07:15 PM
It would probably be a good idea to have a friend steady the bike for you as well while you are working on it so it doesn't tip over. I doubt that the frame is bent. You could probably sit on the ground next to the bike and push up on the engine with your feet (heals on ground and toes pushing up on engine) to lift it enough to get the bolts back in. As stated above, please have somebody hold onto the bike while you do this so it doesn't accidentally fall over on you.
ryanchau96 likes this.
post #7 of 19 Old 10-10-2016, 10:00 PM
I Ride: 2014 Kawasaki ZX-6R
If you were riding it around it wouldn't surprise me if the engine dropped a little. Use a jack to line them up like everyone else said and you should be good to go.
PainfullySlo and ryanchau96 like this.
Martillo y Mantequilla #99
post #8 of 19 Old 10-11-2016, 12:18 PM
Your life:
1st: Your a jack ass for riding with out the bolts
2nd: You now need a jack to fix your jack ass move
3rd: You realize how easy it was to fix your jack ass move with a jack and start working on your bike and become a jack of all trade with bikes
PinoyRider88 likes this.
Sabotage is offline
post #9 of 19 Old 10-12-2016, 08:29 PM Thread Starter
ryanchau96's Avatar
I Ride: 2013 ZX-6R
Originally Posted by Sabotage View Post
Your life:
thanks. really, story of my life
post #10 of 19 Old 10-12-2016, 08:52 PM
Sabotage clearly doesn't sugarcoat things lol...but honestly, I never understood the people that say they can't do it themselves because they don't have the tools needed. So you'd rather spend hundreds of dollars to take it to a dealer (most charge around 100-150 bucks an hour for labor rate depending where you are), instead of going to a store and buying a $10-$30 tool to fix it yourself, which you can use many more times for other things as well. The way I ended up with a small toolbox full of tools is by not following that logic. I bet I probably spent a few hundred bucks total on all my tools (Harbor Freight helps haha), and saved myself THOUSANDS in labor and parts in the last few years of being a bike owner. And I started out in an apartment as well. I had just a single garage and at one point I had my car, a little trailer, 2 bikes, a bicycle, a rack of storage shelves and a few other things all stuffed in that 1-stall garage!
RJ2112, Strider and Sabotage like this.
sbk1198 is offline
post #11 of 19 Old 10-12-2016, 09:03 PM Thread Starter
ryanchau96's Avatar
I Ride: 2013 ZX-6R
Yeaa.. but I'm known to make matter worse when it comes to DIY. I once tried to change the oil on my bike and still messed up badly: overfilled oil, over tightened the drain bolt, couldn't unbolt the oil filter cap because my tool wasn't good enough and made a huge mess.. ended up going to the dealer and have them changed the oil again that day.
So knowing the fact that I'll f up an oil change, I don't even want to imagine what would happen if I try to adjust the position of an engine
But I still want to learn how to do it myself though, I'll see how much the dealer quote me
pretty much im just VERY clueless when it comes to mechanical stuff and I don't want to mess up my bike more if there's a problem
post #12 of 19 Old 10-18-2016, 09:37 AM
I Ride: 2013 636
I agree with you LOL. I have a garage and tons of tools and I still manage to screw stuff up. Actually the main thing that is always getting me is snapping bolts off when taking them off..... for some reason I have the worst luck. Last week I tried to take off my swing arm spool bolt and snapped it right off. Apparently someone cross threaded it when they put it in....
Anyways regarding your problem. My engine looked exactly the same last week when I removed the bolt to install the frame slider on one side. New bolt wouldn't go in without cross threading like crazy since it was off SO I decided to take it to the shop to get it fixed instead of making it worse.
He said it was an easy fix, engine just dropped a bit. He loosened the other bolt and jacked up the motor until it aligned. I could have done that myself but im sick of stuff breaking on me hahahah. The swing arm slider bolt is the 6th bolt I have had to get drilled out from all my bikes I have owned, hopefully its an easy fix. I just don't get how I can break so many bolts just taking them off.....
2013 Black ZX6R w/ABS
2011 Triumph Street Triple R (SOLD)
chomorro is offline
post #13 of 19 Old 10-18-2016, 02:32 PM Thread Starter
ryanchau96's Avatar
I Ride: 2013 ZX-6R
The 13 is same a second 15, so you think I should jack up the engine with wood block in the middle while the bike is on a stand, lossen the rear engine mount bolt a bit and push/align the engine up with a jack?
post #14 of 19 Old 10-18-2016, 04:30 PM
Yes, that's exactly what I think you should do. Once you do that, you should be able to get the bolts back into the mounting holes.
I'd offer to help you if you happened to be local to me in Austin, Texas.
MR2Aaron is offline
post #15 of 19 Old 02-25-2017, 01:56 PM Thread Starter
ryanchau96's Avatar
I Ride: 2013 ZX-6R
So with the diagram i attached, for step 3 the nuts on the end of rear engine mounts bolt you meant 92210 on the bottom and for step 4 the head of the rear engine mount bolt you mean 92151?
engine , frame , sliders
FS: 13-14 R&G Racing Aero frame Sliders (LOWER) RedAndBlack Classifieds 5 07-15-2014 11:35 PM
07/08 engine 03/04 frame Witt Mechanical and Technical 0 05-05-2012 08:38 AM
FS: 2000 yzf 600r engine u531355 Classifieds 0 04-29-2012 09:34 PM
FS: 2002 ZX6R Frame (Dented) NOT Salvaged rcw5070 Classifieds 3 04-27-2012 11:56 AM
