04 Electrical Issue - Page 2 - ZX6R Forum
 7Likes
post #16 of 34 Old 12-13-2016, 04:22 PM Thread Starter
Went to do the stator test to check the continuity and couldn't get the stator unplugged from the regulator plug. Upon looking at the plug I realized that the whiteish plastic around the plug was extremely brown almost black. Finally got the plug off to find that it look it it had exploded and it was extremely corroded. Looks like im purchasing a new regulator and stator.
Mango is offline
post #17 of 34 Old 12-13-2016, 08:06 PM
Why buy both?
post #18 of 34 Old 12-13-2016, 08:20 PM Thread Starter
Cause the stator plug over-heat / exploded inside the rectifier plug. So If I just got a new stator I would have be plugging in a new plug into a melted plug (or vise versa)
Mango is offline
post #19 of 34 Old 12-13-2016, 10:28 PM
Ahh ok....
Approved!
post #20 of 34 Old 12-14-2016, 11:24 AM
..... if there are no additional electrical loads on the bike (HID lighting being the #1 killer of electrical systems), when you replace the melted parts with new, go through every single pull apart electrical connector on the bike and inspect. When you have it apart, flood each one with dielectric grease to prevent corrosion in the future. The action of taking the connectors apart will scrape away the rust between the contacts. When you fill it with the grease, that will provide a barrier to oxygen so the corrosion cannot re-form. Pushing the contacts back in place will scrape away a little more of the grunge on the pins and make a good electrical contact.
post #21 of 34 Old 12-14-2016, 01:22 PM
laggy311's Avatar
I Ride: Dirty
Hard wire
@hellonearth good luck queer. I'll keep my dick crossed for you.
U guys should see me shredding my flute. No homo!
Free ball it. Then sell your used gear on ebay
laggy311 is offline
post #22 of 34 Old 03-04-2017, 09:57 AM Thread Starter
Finally got around to working on the bike, installed a new stator, stator gasket and rectifier. Plugged all the new components in and the bike ran great for the rest of the day. The next day rolled around and the bike started up instantly, but about 30 minutes into the ride the bike was dead. I am completely lost now with what is wrong. New Stator, new rectifier but the bike still isnt charging. Any ideas? :/
Mango is offline
post #23 of 34 Old 03-04-2017, 10:05 AM
laggy311's Avatar
I Ride: Dirty
Battery.
laggy311 is offline
post #24 of 34 Old 03-04-2017, 10:16 AM Thread Starter
I replaced the battery when I was intially trying to figure the issue out. A new battery didn't fix it so I returned the new one because I felt nothing was wrong with the old one. I then replaced the stator and rectifier but continued to use the old battery. I guess all three of these components were bad. Ill put in a new battery and come back with information.
Mango is offline
post #25 of 34 Old 03-04-2017, 10:43 AM
laggy311's Avatar
I Ride: Dirty
yeah dude. battery.
laggy311 is offline
post #26 of 34 Old 03-04-2017, 04:12 PM
You did 2 of the 3 main components in the charging system.
If the battery wasn't kept charged it will kill the battery.
IF you still have an issue which is possible but slim, you have a major drain on the charging system. The only thing what could do that would be aftermarket bit's that didn't get properly fused.
Doubt that's the case.
post #27 of 34 Old 03-05-2017, 12:37 AM
laggy311's Avatar
I Ride: Dirty
x2. Parasitic draw or short...
But the new battery being taken back "because you felt like it wasn't the battery" is silly. What we WANT the issue to be has nothing to do with the issue lol.
Indy likes this.
laggy311 is offline
post #28 of 34 Old 03-05-2017, 08:05 AM
I thought about the parasitic draw, but the time frame didn't seem right.
The short with no fuse would torch the offending wires.
Follow the smoke or look for the crispy black wire.
laggy311 likes this.
post #29 of 34 Old 03-05-2017, 11:34 AM
laggy311's Avatar
I Ride: Dirty
Agreed.
Like I said, "I'll take Bad Batteries for $400, Alex".
laggy311 is offline
post #30 of 34 Old 03-05-2017, 01:12 PM
Mango,
Did you ever at any point in this process actually use a meter, and find out what's going on?
The shop manual has detailed instructions on exactly this issue........
High Beam Blowout, or Other Possible Electrical Issue? Jperez Mechanical and Technical 8 07-17-2015 12:26 AM
Electrical Issue! Help me Name this Connector! code 3 Mechanical and Technical 4 11-07-2014 12:53 PM
Electrical issue? Headlights flickering, irregular idle Mikezx6 Mechanical and Technical 7 06-09-2014 12:10 PM
Turn Signal Issue 09ZX6R (Electrical problems...ugh) Knapman The ZX6R 0 03-26-2014 03:17 PM
Electrical Issue Ey3l45h Mechanical and Technical 9 11-22-2013 11:40 AM
