04 Electrical Issue - Page 3 - ZX6R Forum
 7Likes
post #31 of 34 Old 03-05-2017, 02:43 PM Thread Starter
Mango,
Did you ever at any point in this process actually use a meter, and find out what's going on?
The shop manual has detailed instructions on exactly this issue........
I have been using a meter throughout this entire process, even double checked it today on the battery with all the new components. The bike is up to spec with all the correct outputs with the new battery. I guess it took replacing all three components to get the darn system charging again. Appreciate all the help guys!
Mango is offline
post #32 of 34 Old 03-05-2017, 02:53 PM
With the bike off, the battery should read something over 12 VDC.... roughly 12.3 or .4.
At idle, you should see slightly more or the same.
At anything over 3K or so, you should be seeing 14+ VDC. With all of the lights on, I would expect that to drop slightly, to somewhere around 12.8 or so.... should never go to less than 12, or you are discharging the battery.......
post #33 of 34 Old 03-05-2017, 03:16 PM Thread Starter
Yup! The meter reads pretty much what you just had posted, thanks for the double check on the numbers
Mango is offline
post #34 of 34 Old 03-05-2017, 05:49 PM
No matter what, you should never see more than 14.6 VDC.... the regulator is meant to limit the voltage so the battery doesn't fry.
High Beam Blowout, or Other Possible Electrical Issue? Jperez Mechanical and Technical 8 07-17-2015 12:26 AM
Electrical Issue! Help me Name this Connector! code 3 Mechanical and Technical 4 11-07-2014 12:53 PM
Electrical issue? Headlights flickering, irregular idle Mikezx6 Mechanical and Technical 7 06-09-2014 12:10 PM
Turn Signal Issue 09ZX6R (Electrical problems...ugh) Knapman The ZX6R 0 03-26-2014 03:17 PM
Electrical Issue Ey3l45h Mechanical and Technical 9 11-22-2013 11:40 AM
