zx6r 2001 j2 mikuni carbs emulsion tubes - ZX6R Forum
post #1 of 6 Old 12-15-2016, 10:09 AM Thread Starter
scoot33's Avatar
I Ride: zx6 j2
does any one know how to remove the emulsion tubes on a set of mikuni 36mm j2 zx6r 2001 carbs if they can be removed ?
zx6r j2 mods done ,,
scoot33 is offline
post #2 of 6 Old 12-15-2016, 12:52 PM
Technically the emulsion tube is the part under the main jet---unscrew the main jet and unscrew the main jet holder..it is also brass....or do not unscrew the main jet- it will unscrew either way 7mm hex head I think
post #3 of 6 Old 12-15-2016, 03:00 PM Thread Starter
scoot33's Avatar
I Ride: zx6 j2
yeh i have took them bits of ,there is still a brass part left in the hole so im a bit baffled now ,,the tubes are worn and was wondering to change them but not sure if they are pressed in then,, as i have never done them before,i have some old spare 36mm carbs ,i will have a look tomorrow to see how the hell the tubes come out completely,mine are pretty oval so was going to get new ones as its cold and crap weather but bit stuck ,
scoot33 is offline
post #4 of 6 Old 12-16-2016, 11:02 AM Thread Starter
scoot33's Avatar
I Ride: zx6 j2
well i have worked out how to get them out ,easy when you know ,but found a way so all sorted
scoot33 is offline
post #5 of 6 Old 12-16-2016, 12:40 PM
you are talking the pressed in needle jet? Were you able to source new ones then?
post #6 of 6 Old 12-16-2016, 01:55 PM Thread Starter
scoot33's Avatar
I Ride: zx6 j2
mmmm not looking to good so far ,i will phone kawy as this is a wearable part and i havent had any luck finding any thing glad i done it on spare carbs to be honest
scoot33 is offline
ZX6R Carbs on my kit car, problems :-( dmrider The ZX6R 1 08-31-2014 05:47 AM
2001 to 2009 zx6r tail light swap rgarcia1983 The ZX6R 1 05-05-2014 05:14 AM
1996 ZX6R with mikuni carbs BSloss13 Mechanical and Technical 1 03-24-2014 07:40 PM
2001 zx6r need all plastics Sephone420 Classifieds 9 01-01-2009 09:54 PM
