Abnormal idle when cold...Very cold! - ZX6R Forum
 8Likes
post #1 of 21 Old 12-19-2016, 02:21 PM Thread Starter
MrZ
MrZ's Avatar
I Ride: my sexy Julia
Temp is below 10C, that means it's very cold outside!!! 0C is water freezing.
Bike acts like this, no FI light comes up or anything. Riding feels like it's overfueling and idle stops acting like this after some time.
Although there is no FI, this does not seem right. It should have higher idle but not like this. Any ideas?
MrZ is offline
post #2 of 21 Old 12-19-2016, 03:07 PM
Move somewhere warmer?
PowerGroove, Scorpi0 and scoot33 like this.
post #3 of 21 Old 12-19-2016, 03:27 PM
That is odd. I just started mine up the other day and it was about 38 degrees in the garage (about 4 C). Although the battery was almost dead and had to charge it up a bit, once it started it ran like it always does.
If you let it warm up and then restart it with the engine warm, does it still behave like that?
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is offline
post #4 of 21 Old 12-20-2016, 08:21 AM
What year is the bike? Mileage?
Edit: Oh, 2010...
Vacuum leak, maybe? Maybe a fuel pressure regulator is sticking when cold? I'd lift up the fuel tank and hunt for any cracked rubber or plastic parts as the first thing I checked.
Edit 2: Has it been modified at all - aftermarket exhaust or power commander or anything?
MR2Aaron is offline
post #5 of 21 Old 12-20-2016, 10:34 AM
scoot33's Avatar
I Ride: zx6 j2
never been involved with injection on a motorbike ,mine is carbed but if that was a car engine ,i would say that the cold sensor that controls the fuel starting when cold would be faulty
zx6r j2 mods done ,,
scoot33 is offline
post #6 of 21 Old 12-20-2016, 11:50 AM
I would definitely make sure the oil is the proper viscosity for those weather conditions.
PowerGroove likes this.
the prophet is offline
post #7 of 21 Old 12-20-2016, 01:34 PM Thread Starter
MrZ
MrZ's Avatar
Suppose only for the winter, because summer is hot as hell!!! Though can't do that!
It takes too much time to warm up, so i let it run a minute or two, while i'm closing the garage door and putting my helmet/gloves on, then i ride it keeping low revs until the reading comes up. I will try the restarting in the next days, maybe tommorow.
Edit: Oh, 2010...
I don't think it's a vacuum, unless there is a hole that i didn't notice.I took off the gas tank and airbox in order to change spark plugs some weeks ago. Same issue before, same issue now. Had a DNA air filter since i got it and a custom slip-on for 2 years i think.
Shouldn't this appear as a FI blinking on the dash? Have to do some research on this. Looking for air temp sensor? Coolant temp displays just fine on the gauge. Is there another for the cold start?
I use what kawi suggests and it is the same oil i had on every bike i've owned
MrZ is offline
post #8 of 21 Old 12-21-2016, 03:48 PM Thread Starter
MrZ
MrZ's Avatar
So, today i took the bike out again.
It was totally normal....Steady idle, just how it should be.
It is still cold outside, maybe even colder than yesterday.
I don't know what to think...
MrZ is offline
post #9 of 21 Old 12-21-2016, 10:38 PM
Maybe it just needed to fart
PowerGroove and sbk1198 like this.
post #10 of 21 Old 12-22-2016, 02:46 AM
OP, You may have had some condensation in your gas tank. Small amounts of water will play havoc with how the bike runs..... did you by chance leave the tank nearly empty before the cold snap?
post #11 of 21 Old 12-22-2016, 05:26 AM
I was just thinking of that. Had to have been something in the fuel, and that's most likely water.
sbk1198 is offline
post #12 of 21 Old 12-23-2016, 05:25 AM
Elduderino01's Avatar
I Ride: 2001 ZX-6R
My harley is fuel i njected and i always add stabalizer for the winter storage. Starts fine everytime. Fill the tank as full as you can with premium gas and add in the correct amount of stabalizer. Works well.
Elduderino01 is offline
post #13 of 21 Old 12-27-2016, 11:47 AM Thread Starter
MrZ
MrZ's Avatar
So, i had the abnormal idle and overfuelling shorta thing again today.It was not cold like the other days so i don't think it's because of the temperature anymore.
I do live in a high humidity area and the bike is parked outside. And i found out that my motorcycle cover isn't waterproof.... Gas tank was halfway full.
Could it be condensation?So much?
I don't do winter storage, i ride all year long. It may be parked for a week if it happens to rain all the time, but when it doesn't, i ride.
MrZ is offline
post #14 of 21 Old 12-27-2016, 11:53 AM
I would check to see if your filler neck drain line is actually clear. The dished out area 'below' the filler neck can allow water to pool, and some of it may eventually get slopped into the filler neck and then into your gas inside the tank. There is a small drain line at the lowest corner of the dished out area..... that one is meant to let any water that pools in that area to drain away.
Best to check and ensure it is clear of debris, or rust. It may take running a small stand of wire through the hole to ensure it is clear. If you have rust in that area, the drain is surely blocked.
MrZ likes this.
post #15 of 21 Old 12-30-2016, 02:09 PM Thread Starter
MrZ
MrZ's Avatar
I'm going to check this probably in the following week, since it's been cold again...Cold as "needing snow tires" cold...
MrZ is offline
How to fix common 2013+ issues (Stalling or cold start issues, hard shifting) RedAndBlack Mechanical and Technical 10 12-21-2016 10:06 AM
Low idle when engine's cold showaski Mechanical and Technical 10 09-14-2013 09:58 PM
question about cold start idle? 05magna636 Mechanical and Technical 3 09-13-2013 06:29 PM
Weird Idle at startup when cold juggaknot Mechanical and Technical 5 11-29-2012 02:30 PM
Cold Idle RPM? HotIce The ZX6R 11 03-13-2011 04:23 PM
