Cam Chain Tensioner replacement? - ZX6R Forum
View Poll Results: Replace Stock tensioner
OEM 7 70.00%
APE 3 30.00%
Voters: 10. You may not vote on this poll
 32Likes
post #1 of 47 Old 01-05-2017, 07:22 PM Thread Starter
Bike has 22k on it.
So the valves need to be done and imagine the tensioner is due.
Replace the OEM spring and or stock tensioner (if it lasts another 21k I'm happy) For me the stock has the plus of being automatic.
Manual (Ape) plus it's bullet proof, the down side is I've got to pull the covers to adjust.
post #2 of 47 Old 01-05-2017, 07:50 PM
It is working good........keep it in and inspect it when you pull it out to remove cams for valve adjustment
see pm reply
Ey3l45h, Strider and ZedExMuse like this.
post #3 of 47 Old 01-05-2017, 09:29 PM
If it's working fine, then don't replace it.
post #4 of 47 Old 01-06-2017, 04:11 AM
The tensioner should last the life of the bike......don't fix what ain't broke......
Strider, ZedExMuse and Indy like this.
post #5 of 47 Old 01-06-2017, 04:12 AM Thread Starter
I Like it.. Ain't broke, nough said.
post #6 of 47 Old 01-06-2017, 07:47 AM
MFChop's Avatar
I Ride: 2015 ZX6-R & 2012 GSX1300R
All Im gonna say is a manual CCT quiets the bike valve train noise down a f*ck ton. For $60 well worth it IMO, really doesn't need "constant" adjustment like everyone thinks.
ZedExMuse likes this.
MFChop is offline
post #7 of 47 Old 01-06-2017, 09:58 AM
A cam chain should need even less adjustment than the final drive chain, TBH..... it is not exposed to the elements, rides in a constant oil bath, never faces a change in geometry. Nearly wear free. The light tension applied by the auto tensioner is meant to be just enough to ensure that there is no possibility of the chain jumping a tooth and changing the valve timing.
The guides are what will wear most, in this configuration.
The biggest issue with manual adjusters is the damage done by running them too tight. The accelerated wear on the guides is the potential damage. Sure, it's quieter as it is cutting away the guides.......
Strider, jd41 and ZedExMuse like this.
post #8 of 47 Old 01-06-2017, 11:07 AM
MFChop's Avatar
Well theres your answer learn what you're doing and you wont have any issues lol
MFChop is offline
post #9 of 47 Old 01-06-2017, 12:18 PM
Exactly. The problem is there's a lot more people who get that wrong, than right. All you have to do is pay attention to all the threads on chain maintenance..... that's even easier to see, and people F that up all the time.
The accelerated wear is not immediately apparent. It becomes a latent fault. I do not recall having a fault with a chain driven cam, in all the bikes I have owned. That's now been 6 or 7 bikes so equipped, with a minimum of 25K miles on any one of them. (as much as 53K on the highest mileage unit).
Cam chain noise doesn't really bother me..... a ticking motor doesn't, either. I don't expect reciprocating engines to be quiet, or vibration free. They are far less obnoxious in these regards than they were even 30 years ago, and much less maintenance intensive.
Non linear clutch springs for low effort levers, slipper clutches, EFI..... O ring chains, truly superb suspension action, great frames, wheels, lighting.....
So much better to leave them alone and just ride the things.....
post #10 of 47 Old 01-06-2017, 12:27 PM
OMSpooner's Avatar
I Ride: 13' 636 / 05' 636
not sure about newer models but you can actually adjust the OEM cct on the 03-04 and 05-06
just not in the traditional sense
OMSpooner is offline
post #11 of 47 Old 01-06-2017, 12:50 PM
Any one of the auto CCT can be re-set, and they will adjust themselves again. No need to replace.... simply pull the unit off, clean it, re-set the tensioner IAW the shop manual, and re-install.
Like any other analog, spring driven device, they are not perfectly linear.... at the extreme ends of their range the force they apply is not the same as it is mid range.
Once the cleaned unit is returned to it's location IAW the shop manual, as soon as you start the bike it will adjust itself. Quiet will be the word of the day.
post #12 of 47 Old 01-06-2017, 01:15 PM
OMSpooner's Avatar
post #13 of 47 Old 01-06-2017, 02:06 PM
What a hack............
And did you even pay attention to that gap created before he got the "click".....that was for sure more than .040", that is a shit ton extra preload on the chain and thus the chain guides
Too many dumbasses run their cam chain far too tight! and this is a prime example of one of them
RJ2112, Ey3l45h, Strider and 1 others like this.
post #14 of 47 Old 01-08-2017, 09:11 PM
OMSpooner's Avatar
If that makes you feel better lol. I adjusted the CCT on my 05 this way and haven't had any issues and that was in 2012
post #15 of 47 Old 01-09-2017, 10:09 AM
Did you also round off the bolt heads like the idiot in the video?
And just because you have not inspected the internals or noticed any issue does not mean there has been no negative consequence!
That is like saying if you close your eyes and can't see any danger there must not be any present.............
Strider, sbk1198 and Addhoc like this.
automatic cam chain tensioner help please Lance Mechanical and Technical 8 03-23-2015 12:19 PM
Kawi Tik and Cam Tensioner - could've been bad zpeedd3mon Mechanical and Technical 29 06-29-2012 07:06 AM
cam chain tensioner 100proof Mechanical and Technical 38 05-20-2012 04:24 PM
manual cam chain tensioner ZoomSplat Mechanical and Technical 97 05-06-2011 06:41 AM
Cam chain replacement kenny_636 The ZX6R 2 08-20-2009 05:41 AM
