05-06 ZX-6RR Shock Linkage Explained - ZX6R Forum
  • 1 Post By MotoHead8
post #1 of 8 Old 01-09-2017, 10:59 AM Thread Starter
MotoHead8's Avatar
I Ride: '05 ZX6R CCS#427 Am
All of this information is out there but it's scattered across the interwebs so I figured I'd put it all in one place. I've seen a lot of people looking to switch to this lately and paying a fortune ($80-100) for the "special" RR linkage. On Partzilla when you click on a part# it automatically pulls up a list of all the bikes that part belongs to. In the instance of the Unitrak and dogbones for the RR linkage, it is...
39111-0008 ROD-TIE,SUSPENSION
2004 ZX1000-C1 Ninja ZX-10R REAR SUSPENSION
2005 ZX1000-C2 Ninja ZX-10R REAR SUSPENSION
2005 ZX600-N1 Ninja ZX-6RR REAR SUSPENSION
2006 ZX600N6F Ninja ZX-6RR REAR SUSPENSION
39007-0006 ARM-SUSP,UNI TRAK
2005 ZR750-K1 Z750S REAR SUSPENSION
2005 ZX600-J4 ZZR600 REAR SUSPENSION
2006 ZR750K6F Z750S REAR SUSPENSION
2006 ZX1000D6F Ninja ZX-10R REAR SUSPENSION
2006 ZX1000D6F Ninja ZX-10R (European) SUSPENSION
2006 ZX600J6F ZZR600 REAR SUSPENSION
2007 ZR750L7F Z750 (Australian) SUSPENSION
2007 ZR750L7F Z750 (European) SUSPENSION
2007 ZX1000D7F Ninja ZX-10R REAR SUSPENSION
2007 ZX1000D7F Ninja ZX-10R (European) SUSPENSION
2007 ZX1000D7FA Ninja ZX-10R REAR SUSPENSION
2007 ZX600J7F ZZR600 REAR SUSPENSION
2007 ZX600P7F Ninja ZX-6R REAR SUSPENSION
2007 ZX600P7F Ninja ZX-6R (European) SUSPENSION
2008 ZR750L8F Z750 (Australian) SUSPENSION
2008 ZR750L8F Z750 (European) SUSPENSION
2008 ZX1000E8F Ninja ZX-10R REAR SUSPENSION
2008 ZX600J8F ZZR600 REAR SUSPENSION
2008 ZX600P8F Ninja ZX-6R REAR SUSPENSION
2008 ZX600P8F Ninja ZX-6R (European) SUSPENSION
2008 ZX600P8FA Ninja ZX-6R REAR SUSPENSION
2009 ZR750L9F Z750 (European) SUSPENSION
2009 ZX1000E9F Ninja ZX-10R REAR SUSPENSION
2009 ZX1000E9FA Ninja ZX-10R REAR SUSPENSION
2009 ZX600R9F Ninja ZX-6R REAR SUSPENSION
2009 ZX600R9FA Ninja ZX-6R Monster Energy REAR SUSPENSION
2010 ZR750LAF Z750 (European) SUSPENSION
2010 ZR750LAS Z750 (European) SUSPENSION
2010 ZX1000FAF Ninja ZX-10R REAR SUSPENSION
2010 ZX1000FAFA Ninja ZX-10R REAR SUSPENSION
2010 ZX600RAF Ninja ZX-6R REAR SUSPENSION
2010 ZX600RAFA Ninja ZX-6R REAR SUSPENSION
2011 ZX600RBF Ninja ZX-6R REAR SUSPENSION
2012 ZX600RCF Ninja ZX-6R SUSPENSION-SHOCK ABSORBER
If you're using the 6RR shock then you'll need the 11mm spacer to compensate for the shorter eye to eye (130mm). Note, this spacer is exclusive the the 6RR and usually has to be special ordered. A stack of washers from Home Depot does the same thing.
**However, if you're still on the 6R shock (135mm) you can skip this part and keep the 6R spacer (6mm).**
92026-0079 SPACER,16.5X26X11
2005 ZX600-N1 Ninja ZX-6RR FRAME FITTINGS (FRONT)
2006 ZX600N6F Ninja ZX-6RR FRAME FITTINGS (FRONT)
**When swapping make sure all your bushings and bearings are cleaned, lubed, operate freely, and that you tighten everything to factory torque specs.**
I pieced together a RR linkage off of ebay for under $25 shipped, $9.80 for a 07-08 zx6r unitrak and $15.00 for 04-05 zx10r dogbones. Because I have an aftermarket shock with adjustable ride height I didn't need the spacer. Happy parts hunting
MotoHead8 is offline
post #2 of 8 Old 01-09-2017, 11:16 AM
Site Admin
WERA689's Avatar
Thread moved to Mechanical & Technical.
WERA689 is offline
post #3 of 8 Old 01-09-2017, 01:15 PM Thread Starter
MotoHead8's Avatar
Thank you.
WERA689 likes this.
post #4 of 8 Old 01-09-2017, 01:23 PM
So...... You do not explain why or if there is some magical advantage to using the RR linkage instead of the R?
Is the knuckle configuration different between the two that there is some benefit in geometry/travel with the RR over the R?
39007-0045 for the R model and 39007-0006 for the RR model for the knuckle itself....
IS there a width difference as well at the shock mount?
post #5 of 8 Old 01-10-2017, 07:55 AM Thread Starter
MotoHead8's Avatar
**Consult you local suspension professional before making suspension or geometry changes to your bike. I'm not one.**
Bushing at the knuckle is the same width.
post #6 of 8 Old 01-10-2017, 08:43 AM
So why would one want the RR knuckle instead of the R then? or the linkage arms?
wasn't that the point of your post
Or is this just information that for 99.9% of the users will be useless?
post #7 of 8 Old 01-10-2017, 01:03 PM Thread Starter
MotoHead8's Avatar
Again, consult your suspension professional. They'll be able to explain.
No it wasn't.
Possibly. I've actually calculated it's more like 99.991%. RR parts are hard to come by, this makes it much easier.
post #8 of 8 Old 01-10-2017, 03:45 PM
I am well versed in suspension knowledge and without some factual measurements of how changing the knuckle to a different ratio one....... I highly suggest not to!
Again--why post up information that would seem to lean towards.......... Hey look what I found, this is the cats meow for your rear suspension on the R or RR............ or atleast that is how I interpret your opening post
But since you follow up with zero fact, zero measurements, zero anything........... I can't understand the post or thread at all unless it was just intended for RR only users to be able to find a new knuckle...........but why would they need a new knuckle?
So again....you lost me with this seemingly meaningless pointless thread with no relevant substantive information.
OHLINS 46PRXS rear shock with linkage Evil Cupcake Classifieds 3 11-11-2014 07:50 PM
zx6r 2010 r9f shock linkage? young rider Mechanical and Technical 6 04-11-2014 01:51 AM
FS: 2004 ZX6R Rear Shock with Linkage CBRaceRR Classifieds 2 03-18-2014 01:48 PM
New 2009-2012 Kawasaki ZX6R Complete Rear Suspension / Shock Linkage (UK) Brands6R Classifieds 1 07-08-2013 01:45 AM
shock linkage wendle Mechanical and Technical 24 03-18-2013 04:45 PM
