Hey, brand new to riding, have a couple questions - ZX6R Forum
 12Likes
  • 1 Post By Strider
  • 3 Post By jd41
  • 1 Post By Scorpi0
  • 1 Post By PinoyRider88
  • 1 Post By RedAndBlack
  • 4 Post By Sanctuary
post #1 of 14 Old 01-17-2017, 10:05 PM Thread Starter
I have rode dirt bikes for the past 3 years and have been wanting to get a street bike. So I went and passed the MSF course and then began looking for a bike. I found a good deal and bought it, its a 2013 ZX 636. It had 1200 miles when I bought it and iv'e put on around 600 since then. The previous owner already had a two brothers slip on exhaust on the bike.
The problem i'm having is the bike is spuddering only in first gear and only when I give it a lot of gas on the start. Also the exhaust is popping at various times when decelerating. I asked the previous owner if he ever tuned the bike when he put the exhaust on and he said no, so i'm wondering what I need to do to stop this. I'm pretty sure its something to do with the computer not knowing how much gas it exactly needs to give because he just slipped the exhaust on. Am I right? Oh yea and its happening around 4,000 rpm. Thanks for the help and I can provide a video of it happening if you need me to.
byron979 is offline
post #2 of 14 Old 01-17-2017, 10:37 PM
Hello and welcome!
You need to install some block of plates to reduce/eliminate that popping which is caused by installing the aftermarket exhaust. The block off plates eliminate the PAIR valve, which is what is actually causing the popping sounds.
Here are the ones I used on my bike: https://www.revzilla.com/motorcycle/...00-versys-1000
byron979 likes this.
post #3 of 14 Old 01-17-2017, 10:37 PM
I Ride: 2014 Kawasaki ZX-6R
I'm guessing the following two things.
1. "Sputtering" may be caused by the ECU (some 13 models have faulty ECU's that start with a low idle then die) or needing to adjust (raise) the idle speed.
2. A slip on exhaust does not require a remap. The popping noise is caused by PAIR valve that reintroduces air to burn off any remaining fuel for cleaner emissions. A simple fix is to install block off plates.
Martillo y Mantequilla #99
post #4 of 14 Old 01-17-2017, 11:29 PM
JD41 is on the money. Your sputtering could be the bad ECU a lot of the '13 models had. If u know anyone with a 2013 or newer model, ask them to let u borrow their ECU for a day or two for testing purposes.
The popping on deceleration is normal. The bike will always do that. U just wont hear it with the original exhaust.
post #5 of 14 Old 01-18-2017, 08:18 AM
PinoyRider88's Avatar
I Ride: '13 ZX-6R
@jd41 is spot on with the response. I am only chiming in because I had a 2013 with a Two Bros Black Carbon Series for 19XXX miles.
The sputtering you are hearing is 100% normal. Since it is a "shorty" can and has shorter tubing you hear a lot more of the sputtering caused by the unburnt fuel. I bought my 2013 ZX-6R brand new with 1 mi on it with a two bros exhaust. I didn't get a servo buddy or block off plates and have had 0 issues. I recently went with a hindle exhaust only because it is a high mount exhaust and really want some sexy woodcraft rearsets. The two bros exhaust or any shorty exhaust I am pretty doesn't allow for the rearsets due to the L-bracket. Though I believe some people on here have gotten Vortex to work with the two bros.
As far as the sputtering when giving her the beans, what TCS mode are you in? If you are in 3 that is the rain mode and will interrupt power delivery with cold tires. Additionally, are you allowing the bike to warm up fully? Typically around 140-141deg it will be sufficiently warm, and you will here the IDLE decrease in noise.
Lastly, as far as the ECU, check the warranty as previously stated. I know I had starting issues with my ECU and when they warrantied it out around 4k, she started right back up.
2013 ZX-6R
PinoyRider88 is offline
post #6 of 14 Old 01-18-2017, 09:10 AM
This is likely the cause of the spudder but even on option 2 or 1 you may get TCS kicking in on cold tires in first gear. It's completely normal. I wrote up a thread in which details some issues with the 2013 including this:
How to fix common 2013+ issues (Stalling or cold start issues, hard shifting)
And can confirm, block off plates will stop that popping on deceleration, but once again, completely normal.
RedAndBlack is offline
post #7 of 14 Old 01-18-2017, 01:48 PM Thread Starter
I think it is the traction control. I usually put it on 2, but today I turned it off completely and no sputtering whatsoever. As far as the warranty ill have to check if the previous owner got it serviced. He barely rode it and it only had 1200 miles on it though. Thanks for all the help guys.
byron979 is offline
post #8 of 14 Old 01-18-2017, 01:57 PM
Sanctuary's Avatar
I Ride: 2013 ZX6R, 2013 Triumph Street Triple, 2017 Triumph Street Triple RS (on order)
Keep it on 1, that's what I do. 2 seems to intervene quite a bit - but 1 saves me when my tyres are cold. Did wonder why you'd need traction control on a 600 when I bought the bike but after hearing people say they couldn't catch me on cold tyres I realise it's been helping me out occasionally... Still lets you slide the rear a bit too!
As for popping noises with after-market cans - I love it. You couldn't pay me to add block-offs to my Arrow. It's half the fun on deceleration!
As you eat another's words
Malnourished, you starve.
Sanctuary is offline
post #9 of 14 Old 01-18-2017, 03:52 PM
I Ride: '13 ZX-6R
ARROW EXHAUST? Is it the full competition TI or just a can?
2013 ZX-6R
post #10 of 14 Old 01-18-2017, 05:45 PM
Sanctuary's Avatar
Just a can with a Pinebox link pipe...fell in love with Arrow with my Triumph. Got one coming for the new RS too
post #11 of 14 Old 01-18-2017, 06:51 PM
I Ride: '13 ZX-6R
The exhaust is strong with this one
2013 ZX-6R
post #12 of 14 Old 01-19-2017, 08:18 AM
commiehunter's Avatar
I Ride: ZX6R 636
That's what I always thought. I hear a lot of people want to get rid of it, but I love it.
commiehunter is offline
post #13 of 14 Old 01-19-2017, 10:38 AM
Why would you be telling a new rider to use traction control setting # 1?
And if 2 is intervening for you too much, you might want to reconsider your riding style. I run track at level 2 and it hardly ever kicks on for me.
THINK before you post. The consequences of your advice can get somebody hurt.
post #14 of 14 Old 01-19-2017, 10:45 PM
racerboy88's Avatar
I Ride: 03 YZF-R1, 04 ZX6R 636
Welcome to the forum
Fueled by rice
03 Yamaha YZF-R1 se
04 Kawasaki Orange ZX6R
02 R1-stolen
95 ZX6R-sold
racerboy88 is offline
M.O.M's Thoughts On Riding: For Beginners & Street Riders MistressOfMayhem Motorcycle Talk 97 03-13-2016 12:58 AM
trying to fix my f3 couple of questions tmsjns Mechanical and Technical 3 12-03-2014 01:12 PM
Another view - Couple getting it on riding on motorcycle trev0006 Motorcycle Talk 2 09-21-2012 11:29 AM
Hey hey hey! BlueNinja6 New Users 26 01-22-2012 02:43 PM
HEY THERE! I am new to this forum, but not new to riding! Heres my bike! Nightmare The ZX6R 19 02-12-2009 11:20 PM
