*HELP* White smoke coming out of my exhaust! - ZX6R Forum
 6Likes
post #1 of 17 Old 01-21-2017, 01:45 AM Thread Starter
Dsmoto's Avatar
I Ride: 2005 Kawasaki ZX6R
Hey guys,
So I recently purchased a 2005 Kawasaki ZX636R with 18,000kms. I bought it before winter and rode it 3 times, then put it away for storage for 3 months. I went to start it up again and white smoke started coming out of my exhaust. When it started, no smoke came out until 30 seconds to a minute of warming it up. My bike is also low on coolant prior to storing it, so not much of a change. Additionally, my oil was not changed prior to storage, but it is a dark colour (Same colour that I left it prior to storing) but a milky consistency and sight glass is foggy as well (not white in colour also not brown either). Oil cap also had white bubbly residue on it. I will add pictures as well when I come home. I am thinking that the head gasket may be blown or water/coolant in the oil as well. Any ideas?
Dsmoto is offline
post #2 of 17 Old 01-21-2017, 01:57 AM
Change the oil. Inspect the coolant. If the antifreeze is free of oil, I would expect that everything's fine.
You may simply have condensation in the oil. This happens when the motor doesn't get to operating temperature so it can evaporate the water out of the oil. When it's cold it runs rich, and the rings aren't sealed... you get more blow by, putting more junk into the oil in the crankcase.
The engine needs to be at full normal temperature for at least 10-15 minutes to take care of this.
Gawernator and Dsmoto like this.
post #3 of 17 Old 01-21-2017, 01:23 PM
scoot33's Avatar
I Ride: zx6 j2
agree there rj my j goes shitty in the glass just condensation ,a nice ride should clear it out
zx6r j2 mods done ,,
scoot33 is offline
post #4 of 17 Old 01-21-2017, 02:44 PM
try above..
Check coolant, nice color or a milky oily top.
How long did the smoke last.
Indy is online now
post #5 of 17 Old 01-21-2017, 03:09 PM
DFx's Avatar
I Ride: 2005 Kawasaki 636, 2012 Kawasaki Ninja 250R, 1978 Yamaha IT400
I'd say blown head gasket.
2005 ZX-6R - Bazzaz ZFI TC w/ ZAFM, R6 Throttle Tube, K&N Race Air Filter, Akrapovic Titanium Full System, EBC HH Pads, Supersprox Rear Sprocket, RK X-Ring Gold Chain, ASV Levers, LED Headlight Bulbs
2012 Ninja 250R - Big Bore 282cc Kit, Fuel Injection Conversion, PC, Race clip ons, Wire Harness strip down, Leo Vince slip on w/ gutted cat stock headers, K&N Pod Filters, Kleen Air Mod, GSXR Rear Shock, Race Tech Emulators, Galfer Steel Braided brake lines, Track Only Bike
DFx is offline
post #6 of 17 Old 01-21-2017, 03:19 PM
Gawernator's Avatar
Safest bet would be to take an oil sample and see if there are contaminants. Probably lots of condensation, but if you have oil/coolant mixing likely the head gasket. Not too bad to fix.
http://www.gawerracing.com
Gawernator is offline
post #7 of 17 Old 01-21-2017, 04:08 PM Thread Starter
Dsmoto's Avatar
Will try that tomorrow! Hopefully that is the case or else the shop is quoting me 300-400$ for the head gasket
Dsmoto is offline
post #8 of 17 Old 01-21-2017, 04:12 PM Thread Starter
Dsmoto's Avatar
I only took the bike out for a 5 minute ride around the block. When the bike is warming up and in idle, that is when it blows a little bit of smoke. Although, if I rev the bike, quite a bit of smoke comes out; but it is odourless. Also, I see water coming out of the exhaust as well. (Bike was stored in a unheated garage with temperatures that reach below 0 degrees celcius. That's Canada for ya)
Dsmoto is offline
post #9 of 17 Old 01-21-2017, 04:14 PM Thread Starter
Dsmoto's Avatar
Hope not! I'm a broke college kid and insurance is 2700$ a year for the ZX6R
Dsmoto is offline
post #10 of 17 Old 01-21-2017, 05:00 PM
badgerninja's Avatar
I Ride: 1986 Nishiki, 2015 Yamaha R3
Put some antifreeze/ gasline moisture remover in the gas tank for a couple of fillups.
You do what you can for as long as you can, and when you finally can't, you do the next best thing. You back up but you don't give up.- Chuck Yeager
Originally Posted by Fishbowl
Go ride Badger for it's the only thing that'll make sense at times.
badgerninja is offline
post #11 of 17 Old 01-21-2017, 07:01 PM
It's not sounding good. If there going to do the head gasket have the valves done at the same time.
Indy is online now
post #12 of 17 Old 01-22-2017, 12:36 AM
There's a good chance that you have a lot of moisture in the muffler which has to evaporate as well. If it wasn't warmed all the way up multiple times, there's probably some ice in there....... again, run it for a longer period of time and see what happens.
Or find heated storage.......
post #13 of 17 Old 01-22-2017, 04:33 AM
scoot33's Avatar
I Ride: zx6 j2
before any headgasket removal ,i always check the oil cooler 1st saves a fuck load of work if its faulty
scoot33 is offline
post #14 of 17 Old 01-22-2017, 04:35 AM
Originally Posted by scoot33 View Post
before any headgasket removal ,always personally check the oil cooler 1st saves a fuck load of work if its faulty
On top of this sage advice..... the OP should pull the spark plugs and see what they say about the state of the motor before giving the thing to a shop.
Again, only after doing the extremely simple troubleshooting steps as outlined.....
scoot33 likes this.
post #15 of 17 Old 02-13-2017, 04:27 PM
Swaynie's Avatar
I Ride: ZX6R
These threads always make me laugh even on car forums. White smoke is condensation in the exhaust. It will take time to clear.
Swaynie is offline
coolant , exhaust , smoke , white , zx6r
Excessive Exhaust Temp WrstFlcka23 The ZX6R 2 06-14-2015 03:24 PM
White smoke after fresh rebuild. 06 zx6r F22C Mechanical and Technical 24 11-26-2014 03:19 PM
FS: or FT. 07 zx6r HR1 slip on Exhaust Dziggy2000 Classifieds 2 11-14-2014 06:39 PM
white smoke from exaust armyscout36 The ZX6R 12 04-07-2009 08:11 PM
