1999 zx6r won't start after being stood - ZX6R Forum
 4Likes
  • 1 Post By Speedtripl3
  • 1 Post By Strider
  • 1 Post By RJ2112
  • 1 Post By scoot33
post #1 of 11 Old 02-12-2017, 03:17 PM Thread Starter
First - apologies for my first post being a question, rather than a contribution.
Bought a ninja 600 which has been laid up for 2 years. Before being put away she ran fine, and in fact passed her MOT test without a single advisory.
I can't get the damn thing started. Fully charged battery, pull in clutch, in neutral, engine turns strongly, sounds like it's about to "catch" but then doesn't.
Repeat this a few times with 3-5 seconds of starter at a time and every time I let go of the starter switch I hear a glugging or small gushing sound and fuel comes out from under the tank/carbs and drips down on the floor.
Thinking it may be the carbs floats I began disassembly to remove the carbs to try and fix. In doing so I discovered that a fucking mouse had chewed HTC lead 2 clean off. Could this be causing my starting issues, or is this an additional sodding bastard problem to the potential stuck floats?
Also, there are a pair of yellow wires which run up past the fuse box (and clip to the plastic).. these have been chewed through too. What are they and will they affect the starting of the bike?
Any help is appreciated.
I will not stop until the mouse that did this is brought to justice.
scoot33 likes this.
Speedtripl3 is offline
post #2 of 11 Old 02-12-2017, 05:58 PM
Hello and welcome!
I would recommend reconnecting all the chewed wires, then try to start it again and see what happens. If it still has issues, proceed with the carb checks/cleaning.
Speedtripl3 likes this.
Strider is online now
post #3 of 11 Old 02-13-2017, 12:46 AM
Repair the wires, and inspect the airbox. Also the exhaust..... critters love nooks and crannies.
post #4 of 11 Old 02-13-2017, 12:30 PM
scoot33's Avatar
I Ride: zx6 j2
lol was it danger mouse ,sounds like he fucked your bike for you nicely lil bastards ,,thats not going to help the starting up thats for sure ,might be worth running some fresh fuel in,can you see where fuel is coming from ,but watch your spark as it my go kaboom with the fuel every where ,i would isolate that lead and then see how you get on ,maybe a gentle tap on float bowls as he may be a bit suck from being parked up,
zx6r j2 mods done ,,
scoot33 is offline
post #5 of 11 Old 02-13-2017, 01:14 PM
Old bike.. been sitting.
Carbs are definitely going to need a cleaning.
Check the airbox and exhaust as mentioned
get some fresh gas and check that the check the plugs are good to go
Let her rip.
PowerGroove is offline
post #6 of 11 Old 02-14-2017, 11:24 AM Thread Starter
Any one know what this pair of yellow wires are for?
https://s10.postimg.org/cl41xfwcp/20170214_191051.jpg
Bastard cunt mouse has chewed them up so much I can't see what they connected to. They run up to the rear of the bike past the fuse box.
Sent from my SM-G930F using Tapatalk
post #7 of 11 Old 02-18-2017, 12:54 PM
scoot33's Avatar
I Ride: zx6 j2
i will have a look on my bike for you bud on sunday ,
scoot33 is offline
post #8 of 11 Old 02-18-2017, 12:57 PM Thread Starter
Appreciate that mate. Got her MOT'd today - all good apart from idling like shit. (Not idling without choke). Any ideas before I swap the carbs out for some others I bought? Lol
post #9 of 11 Old 02-19-2017, 02:01 PM
scoot33's Avatar
I Ride: zx6 j2
bud can you put up another picture as when i look at it it shuts me out ,i usually strip the carbs down and clean out all holes set the float levels and needle levels a turn mixture screw out 3 turns ,then if all seals and sliders and diaphragms are good then it should be running sweet
scoot33 is offline
post #10 of 11 Old 02-19-2017, 02:03 PM Thread Starter
I swapped the carbs out tidy. Took a total of 2 hours, start to finish which I was pleased with. It runs like an absolutely dream now. I plan on selling the old ones as spares (in need of a good clean). Thanks for your help.
post #11 of 11 Old 02-19-2017, 02:06 PM
scoot33's Avatar
I Ride: zx6 j2
can you trace the wires to the block?and tell me the other colours at multiplug as i have a manual but when i click on the picture it doesnt come up for some reason it disappears as soon as i click on it
scoot33 is offline
G1-2 hugger fit j1-2 salami Mechanical and Technical 2 06-21-2016 01:36 PM
1998 ZX6R won`t start up - turns over and runs when warm, just won`t start craynerd The ZX6R 0 02-21-2015 03:38 PM
1999 zxr6 loud start up. Eddie Sierra The ZX6R 13 12-03-2012 08:46 PM
