Plug & Play Gear Indicator - Page 2 - ZX6R Forum
 6Likes
post #16 of 25 Old 04-10-2017, 10:28 PM
Originally Posted by novak View Post
Day 55 since ordering... Still waiting for it to arrive. Ebay says to allow until April 20th. If it doesn't arrive I'll just get my money back. I'll update when I receive it.
So if your LUCKY it won't show.
Good luck.
post #17 of 25 Old 04-11-2017, 04:53 AM Thread Starter
novak's Avatar
Originally Posted by Indy View Post
Update..
I finally installed it.. (The eBay POS) Was going to deal with the euro tune later as they use one of the two wires used in the jumper.
WELL,, the lower left segment does not work. So the 2 looks ODD..
Bright side, the only time I see 2 is when it does the count down as my bike apparently doesn't have a second gear according to the indicator.
WHICH in the instructions say is already setup for our bikes.
Sent the seller a email, 48 hours later nothing. It was my first negitive review in over 5 years.
SO it was a risk, I lost.. Big POS. Don't do it..
First time is a learning experience. Second time is a mistake.
Better to learn from others learning experience's.
Why don't you open a claim with ebay? If it's not working properly then you should be able to get your money back.
novak is offline
post #18 of 25 Old 04-11-2017, 05:09 AM
I will give it a try.. Nothing to loose.
post #19 of 25 Old 05-20-2017, 05:16 PM Thread Starter
novak's Avatar
The gear indicator showed up. I'm trying to install it but I'm a little unsure. I attached some pictures below. See where it is circled, I unplugged that and plugged the gear indicator in and it lit right up and went zero through 6 then back to zero. Did I plug it into the right place and what is it that I unplugged? I unplugged the gear indicator and plugged whatever it is back in for the time being until I can clarify. Any help is appreciated, thanks.
Name:	gear indicator.jpg
ID:	64081   Click image for larger version
Name:	gear indicator 2.jpg
ID:	64089   Click image for larger version
Name:	gear indicator 3.jpg
novak is offline
post #20 of 25 Old 05-20-2017, 07:18 PM
If memory serves, thats the self test.
It was my first hint, it sucked. If all digits displayed properly your doing good so far.
Second was when I started shifting and the gears didn't track.
Check the piece of paper they sent, or should have.
post #21 of 25 Old 05-20-2017, 08:49 PM Thread Starter
novak's Avatar
What I'm wondering though is whether or not that is the right connector that I plugged it into? The part I unlplugged had wires going to it. So I unplugged it, and then plugged in the gear indicator and it turned on and it went 0 through 6 and back to zero. But I unplugged the gear indicator and put the original plug (which had wires going to it) back in because I was unsure if this was correct. Any idea?
novak is offline
post #22 of 25 Old 05-21-2017, 09:01 AM
Yep,,, it's the correct one..
Those wires were for the 10hp euro tune fix. Fools ECU to think it's NOT in the USA if I understood that hack.
SO if the indicator works. Take a picture of your old plug you pulled out. Take that jumper out and install it on your new connector that feeds the gear display.
It was using 2 wires, leaving 2 open spots, your just moving the jumper you uninstalled and moving it.
post #23 of 25 Old 05-21-2017, 09:31 AM Thread Starter
novak's Avatar
I didn't think the 03/04 zx6r's were capable of the jumper mod? I've owned this bike for two years and the previous owner never told me he did that to it. Everywhere I look online they say the jumper mod can only be done on the 05 and up model. So is that actually what I unplugged?
novak is offline
post #24 of 25 Old 05-21-2017, 09:51 AM Thread Starter
novak's Avatar
All of the install guides for the plug and play gear indicators say that the black 4-pole diagnostic connector normally has a "dummy" female plug without wires attached to it and that sometimes there are two of these connectors on some bikes.
I'm only seeing one of these connectors and it has a plug with wires going to it, and I googled pictures of other 03/04 zx6rs under the seat and they look the same. Any advice?
novak is offline
post #25 of 25 Old 05-21-2017, 10:21 AM
DOES the gear indicator work..
DO you get an error code, bike not running OK?
Check the wire colors, look at the schematics. Figure out what the plug goes to.
2014 gear indicator fluctuates. Geeker Mechanical and Technical 3 06-16-2014 04:47 AM
Gear Indicator Being Funny Venge Mechanical and Technical 11 04-09-2014 05:55 AM
Gear Indicator Display Project for Kawasaki 2003-2004 ZX-6R Adjerry91 Mechanical and Technical 8 02-15-2013 09:01 AM
Morimoto mini Bi-Xenon projectors performance compared to plug & play kit *VIDEO* THUG The ZX6R 35 04-02-2012 10:31 AM
Gear Indicator??? bod The ZX6R 8 04-19-2009 08:29 PM
