Plug & Play Gear Indicator - ZX6R Forum
 6Likes
post #1 of 25 Old 02-14-2017, 05:29 PM Thread Starter
novak's Avatar
I was looking for a gear indicator for my 03 zx6r and I found this fairly cheap one on ebay:
FOR Kawasaki Zx6r Ninja 03 2004 2005 2006 2007 2008 Plug & Play Gear Indicator | eBay
It says it plugs into the diagnostics connector. Does anyone have any experience using one of these, if so, has it worked pretty good or no?
novak is offline
post #2 of 25 Old 02-14-2017, 07:37 PM
I have one for my Tiger, bought it from a forum member it's a name brand and worked great.
If this does the same should be good.
Only down side is the sun can make it real hard to read the display.
Might be worth the risk.
post #3 of 25 Old 02-14-2017, 08:19 PM
I'm not sure about the Chinese one from eBay, but if you want to go the name brand route and know for sure that it will work, I would recommend the one from HealTech: Kawasaki ZX-6R ZX6R 2003-2008 Healtech Gipro DS Series Gear Indicator
jd41 likes this.
post #4 of 25 Old 02-15-2017, 04:41 AM Thread Starter
novak's Avatar
Thanks for the advice!
novak is offline
post #5 of 25 Old 02-15-2017, 05:31 AM
That is what I have on my Tiger.. huge price difference.
post #6 of 25 Old 02-15-2017, 05:41 AM Thread Starter
novak's Avatar
I found two videos on youtube of the Chinese ebay gear indicator. The price is so low I think I'll take the risk and try it out haha.
novak is offline
post #7 of 25 Old 02-15-2017, 09:47 AM
Be sure to come back and update the thread and let us know how it goes!
novak likes this.
post #8 of 25 Old 02-15-2017, 10:08 AM
I Ride: 2014 Kawasaki ZX-6R
I'm done buying Chinese stuff from ebay. I've ordered rotors, spools, display gauge covers and all have been bad quality. I would go with Healtech.
https://www.healtech-electronics.com/products/gpx/
https://www.healtech-electronics.com/products/gpds/
From their site:
"Beware!
Some of our GIpro X-type units are offered by some Chinese companies. They use various brandings and logos, including HealTech, Kawasaki, etc. The product looks similar but the quality of the components and assembly is poor, the function/performance is lacking, the reliability is weak and warranty is not backed up. Since the unit connects to the bike's wiring system, due to poor design and assembly it may damage the ECU.
Always be sure to purchase an original GIpro X-type unit from an authorized HealTech distributor or dealer. If you have any doubts when you receive a product, please contact the distributor in your country before doing the installation."
Martillo y Mantequilla #99
post #9 of 25 Old 02-15-2017, 10:12 AM Thread Starter
novak's Avatar
Will do! I just ordered it. It will probably take a month to get here from China in the mail.
novak is offline
post #10 of 25 Old 02-15-2017, 10:20 AM Thread Starter
novak's Avatar
From their site:
"Beware!
Of course Healtech is going to have that disclaimer warning about cheaper units, they want you to buy their product instead!
I'm going to give the eBay one a try and I will update on how it is once I receive it.
novak is offline
post #11 of 25 Old 02-15-2017, 12:27 PM
upland117's Avatar
I Ride: 03 zx6r
I have an 03 and also wanted a gear indicator. I also didn't like the tach as I found it a bit hard to see. I got the instrument adaptor from member extr400 that lets you put on a 07+ instrument cluster, which have gear indicators. It works great and the program on the adaptor also lets you adjust your speedo depending on the sprockets your running. I think he sells them for about $70, but then you'll have to find a used 07+ cluster.
FYI in case your Chinese indicator does not work out. Cheers
Life's better on two wheels
upland117 is offline
post #12 of 25 Old 02-15-2017, 12:39 PM Thread Starter
novak's Avatar
Thanks for the info. Maybe I will look into that if the eBay gear indicator doesn't work out.
novak is offline
post #13 of 25 Old 04-10-2017, 03:25 PM
Update..
I finally installed it.. (The eBay POS) Was going to deal with the euro tune later as they use one of the two wires used in the jumper.
WELL,, the lower left segment does not work. So the 2 looks ODD..
Bright side, the only time I see 2 is when it does the count down as my bike apparently doesn't have a second gear according to the indicator.
WHICH in the instructions say is already setup for our bikes.
Sent the seller a email, 48 hours later nothing. It was my first negitive review in over 5 years.
SO it was a risk, I lost.. Big POS. Don't do it..
First time is a learning experience. Second time is a mistake.
Better to learn from others learning experience's.
Scorpi0 likes this.
post #14 of 25 Old 04-10-2017, 03:45 PM
Fuck that. Im never eating chinese food again.
post #15 of 25 Old 04-10-2017, 07:26 PM Thread Starter
novak's Avatar
Day 55 since ordering... Still waiting for it to arrive. Ebay says to allow until April 20th. If it doesn't arrive I'll just get my money back. I'll update when I receive it.
novak is offline
2014 gear indicator fluctuates. Geeker Mechanical and Technical 3 06-16-2014 04:47 AM
Gear Indicator Being Funny Venge Mechanical and Technical 11 04-09-2014 05:55 AM
Gear Indicator Display Project for Kawasaki 2003-2004 ZX-6R Adjerry91 Mechanical and Technical 8 02-15-2013 09:01 AM
Morimoto mini Bi-Xenon projectors performance compared to plug & play kit *VIDEO* THUG The ZX6R 35 04-02-2012 10:31 AM
Gear Indicator??? bod The ZX6R 8 04-19-2009 08:29 PM
