Alright, what's the trick here cuz I'm having a hell of a hard time with this. I've never had issues bleeding brakes before, always used a vacuum pump, like Mitty-Vac or similar with success, but this is the first time I've ever installed brand new lines. I've gone through about 4-5 reservoirs of fluid and brake still feels really soft/mushy, there is barely any resistance from the lever, although I see that the pads are being engaged on the rotor, just not very hard.
Is there a trick to doing this? I'm doing this on the R3 which also has a MC that doesn't have a bleeder bolt. So I figured it'd be even simpler to do since it's just one banjo on the caliper and only one caliper too :O
It shouldn't be impossible because it was plenty firm before with the stock lines. With steel braided lines I expect the feel to be even more firm but it's not even close to being the way it was before. I don't think the hardware is the issue, but more about how i'm bleeding it.
It's really difficult to get air out of the master cylinder without a bleeder. You could try pumping the brake and firmly tapping (light beating) the master cylinder with a screwdriver handle. That should help move the air bubbles up into he master cylinder reservoir.
I found the hand vacuum pump to suck.
Mine is a electric version. For me, the trick has always been to have a LONG line.
I make a P trap over the signals or mirror.
SO it's direct up from bleeder over mirror or signal, down then back up.
Suck fluid until the first up line is fluid. Then turn pump off. Pump master until few bubbles.
do other side, NO bubbles then back to first side.
I've tried that method of pumping the lever and then open and close the bleed valve. But unlike what the instructions there say "pump until the lever becomes hard"....that never happens. I can pump it all day and it's still soft. I don't get it. Almost seems as if there is a leak in the system then :O
I add about 6-8 inches of hose straight up off the bleeder on the caliper. Open the bleeder and wait.... and wait.... and wait. Eventually gravity will pull the new fluid through. Maybe pump the lever a few times as well... but with patients... it will get there.
If your still having trouble you can bleed it from the bottom up, get a syringe and attach it to your caliper bleed nipple with a piece of hose, then open the nipple and push the fluid in the syringe into the caliper, keep an eye on the master cylinder be careful not to overfill it and spill brake fluid everywhere. :bigthumb:
I guess time and patience were the key. I went back and took the MC off and set it at a lower level than the caliper, bleed everything again, but was still pretty mushy. Ended up doing the good old zip-tie trick, and left the lever zip-tied as close as I could to the handlebar and when I came back this morning, hard as a rock! Solid brakes now. All is well! Feels even better than before, which it should, since they're steel lines.
The rear caliper was easier because I pushed the fluid in with a syringe since I don't have a reservoir on the rear, just a clear tube.
