Wont turn over :( - Page 2 - ZX6R Forum
 13Likes
post #16 of 23 Old 02-28-2017, 02:54 AM
Did you not try again after it stalled? If you didn't, try again, but don't use any throttle. Let the ECU work out what fuelling it wants to use to start the bike - less is more where this is concerned - you don't wanna flood the engine. Hold the starter button down for no more than 3 seconds at a time, and leave a good 15-20 seconds between tries to avoid the starter overheating, they're not really designed for loads longer than that... you don't want to have to change your starter as well!
Joe Joog likes this.
Speedtripl3 is offline
post #17 of 23 Old 02-28-2017, 07:37 AM
Originally Posted by Joe Joog View Post
Got a new battery put it in. It was so close to turning over, I could smell fuel. Then I reved as I started it and it turnt over as soon as I let off the throttle it idled so low it stalled.. I still smelt fuel any suggestions?
How much throttle are u giving it when u try to start?
Turn up your idle screw one full turn (clockwise). Get some starter fluid. Spray it into the intake as u try to start it.
post #18 of 23 Old 02-28-2017, 08:45 AM
New battery is good....
But if it's been a while since you've started her up then splash some fresh gas in the tank. Sounds to me like she's just not really wanting to come out of her nap.
If the bike ran fine before you put it away then it should run fine after. Just might take some coaxing. If it starts and runs like shit... try fresh fuel.
PowerGroove is offline
post #19 of 23 Old 02-28-2017, 10:25 AM
commiehunter's Avatar
I Ride: ZX6R 636
I'd concur with Try Again.
Crank it and don't give it any throttle. This bike has an ECU that should figure out how much it needs.
Crank and give it a rest. Crank and give it a rest if no start. I'd give it a minute or three of this, on and off, before I bothered with adjusting idle, adjusting mixture screws, etc.
commiehunter is offline
post #20 of 23 Old 02-28-2017, 11:58 AM
laggy311's Avatar
I Ride: 2006 ZX6R, 1994 Honda V45 Magna, A Village Bicycle
Did you do anything to tank recently? Anything where you might have punched a red or blue vent line on reinstall?
All fuel injector connectors hooked up?
Battery negative to engine block lug is secure?
Check coil packs for high voltage and primary/secondary coil winding resistance.
Crankshaft position sensor.
Throttle position sensor.
Don't know how this would all go bad on a 2014....
@hellonearth good luck queer. I'll keep my dick crossed for you.
U guys should see me shredding my flute. No homo!
Free ball it. Then sell your used gear on ebay
laggy311 is offline
post #21 of 23 Old 03-01-2017, 03:15 AM Thread Starter
Joe Joog's Avatar
Cheers for all the tips guys. After not touching it yesterday I adjusted the idle and it turned on fine. Straight after work it turned over fine again. Thanks for all the troubleshooting guys appreciate it!
laggy311, Strider and Speedtripl3 like this.
Joe Joog is offline
post #22 of 23 Old 03-01-2017, 03:20 AM
Glad to hear it brother- happy riding!!
Sent from my SM-G930F using Tapatalk
post #23 of 23 Old 03-02-2017, 10:24 AM
laggy311's Avatar
Well done
laggy311 is offline
RSP Racing #29 - LRRS Round 1 Race Report PainfullySlo The ZX6R 9 04-29-2015 09:45 AM
2013 ZX6R Turn Signal Bulbs? IceBreakerG Mechanical and Technical 2 06-03-2014 10:59 AM
Enhanced Turn Signals: Idea? MistressOfMayhem Motorcycle Talk 10 07-19-2013 12:37 PM
Turn signal issues KCCOzxer Mechanical and Technical 11 03-07-2013 06:14 PM
Bike won't turn on Moth Mechanical and Technical 26 04-09-2012 07:06 AM
