Wont turn over :( - ZX6R Forum
 13Likes
post #1 of 23 Old 02-27-2017, 12:03 AM Thread Starter
Joe Joog's Avatar
Wont turn over :(
Hey Guys
Got a 2014 ZX6R. Never had an issue with it, had it since new. Went to jump on Sunday morning, the battery wont turn over- charged it over night tested it with a battery tester, said its fine. Put it back in, still wont turn over. Any suggestions I live well out of town so a bit of an issue taking it to a mechanic.. I checked the killswitch, connections/ plugs and fuses under the seat they are fine. Any suggestions would go a long way!
Cheers in advance.
Joe Joog is offline
post #2 of 23 Old 02-27-2017, 03:54 AM
Edit - Duplicate reply
Speedtripl3 is offline
post #3 of 23 Old 02-27-2017, 03:59 AM
Originally Posted by Joe Joog View Post
Hey Guys
Cheers in advance.
Can you hear the solenoid click to engage the starter when you press the starter button? If you can then I would imagine something is physically stopping the engine from turning (Did this myself a few weeks ago by being too liberal with carb cleaner, created a hydrolock in cyl 1).
When did it last run?
post #4 of 23 Old 02-27-2017, 07:24 AM
In gear and kickstand down?
PainfullySlo is offline
post #5 of 23 Old 02-27-2017, 07:26 AM
Would still turn over though wouldn't it? I thought that was an ignition cut-out?
Sent from my SM-G930F using Tapatalk
post #6 of 23 Old 02-27-2017, 09:50 AM
Make sure the bike is in neutral and the green light is on.
laggy311 likes this.
post #7 of 23 Old 02-27-2017, 09:53 AM
No, it disables the starter circuit =)
post #8 of 23 Old 02-27-2017, 01:13 PM Thread Starter
Joe Joog's Avatar
It ran fine a week ago. Sounds stupid but all I can hear is a machine gun sound if that makes sense but it won't turn over.. the sound is coming from underneath the seat.
I tried the kickstand neutral in gear etc all of that stuff. I got a printout of the kawasaki trouble shooting and it says plugs after the battery.. seem right?
Joe Joog is offline
post #9 of 23 Old 02-27-2017, 01:19 PM
A sound like that coming from under your seat could be the starter relay. Can you remove the seat and see if there are any relays visible?
post #10 of 23 Old 02-27-2017, 03:22 PM Thread Starter
Joe Joog's Avatar
Couldn't see anything mate.. alot of tight spaces etc. There is a whole bunch of plugs towards the pillion seat and I checked to see if they were all fine.
Joe Joog is offline
post #11 of 23 Old 02-27-2017, 03:43 PM
commiehunter's Avatar
I Ride: ZX6R 636
Honestly, to me, the 'machine gun sound' sounds like dead battery. It sounds like the starter is trying but doesn't have the juice to turn it over.
Now, I know you said you had the battery on a tester, but putting out 12.5v on no load does not always equal 12.5v under full load. It could be the battery is dropping voltage when you put an amp draw on it, and it just doesn't have the juice.
If you're pressing the starter button and getting 'something' that's tied to the button, then your kickstand switch/neutral switch/kill switch/clutch switch are working properly, AFAIK.
PainfullySlo and arsftarmy like this.
commiehunter is offline
post #12 of 23 Old 02-27-2017, 04:23 PM
Hook up some jumper cables to it and try to start it.
PainfullySlo likes this.
post #13 of 23 Old 02-27-2017, 07:11 PM Thread Starter
Joe Joog's Avatar
Cheers guys I ordered a replacement battery and will let you guys know how it goes. Thanks for the help not to too bike savy minus cleaning the chain and a basic service.
Joe Joog is offline
post #14 of 23 Old 02-28-2017, 12:46 AM
Good luck man. Fingers crossed for you! It'll feel extra good when you get her running after all this
post #15 of 23 Old 02-28-2017, 02:26 AM Thread Starter
Joe Joog's Avatar
Got a new battery put it in. It was so close to turning over, I could smell fuel. Then I reved as I started it and it turnt over as soon as I let off the throttle it idled so low it stalled.. I still smelt fuel any suggestions?
Joe Joog is offline
RSP Racing #29 - LRRS Round 1 Race Report PainfullySlo The ZX6R 9 04-29-2015 09:45 AM
2013 ZX6R Turn Signal Bulbs? IceBreakerG Mechanical and Technical 2 06-03-2014 10:59 AM
Enhanced Turn Signals: Idea? MistressOfMayhem Motorcycle Talk 10 07-19-2013 12:37 PM
Turn signal issues KCCOzxer Mechanical and Technical 11 03-07-2013 06:14 PM
Bike won't turn on Moth Mechanical and Technical 26 04-09-2012 07:06 AM
