Quieting down an aftermarket exhaust - ZX6R Forum
  • 1 Post By RJ2112
  • 1 Post By jd41
  • 1 Post By smokey11
post #1 of 10 Old 03-04-2017, 10:31 AM Thread Starter
I Ride: 2014 Kawasaki ZX-6R
Lightbulb Quieting down an aftermarket exhaust
Local track has a 90db rule. As much as I want an Austin Racing or Racefit slip on, I know it won't pass.
I've considered closing the baffle further at the end to reduce db levels or wrapping the baffle with fiberglass.
Has anyone every modified or created a baffle to quiet down an aftermarket pipe?
Any input is appreciated. Thanks.
Martillo y Mantequilla #99
post #2 of 10 Old 03-04-2017, 10:36 AM
It takes a certain volume, to deaden enough sound.... the very short cannister size of most slip ons makes it near impossible to increase the attenuation they provide without restricting the airflow. You could try making a diffuser disc, like Supertrapp used to use......
sbk1198 likes this.
post #3 of 10 Old 03-04-2017, 11:35 AM
^Yep, what he said.
You can't have a short simple can that's also quiet. The quiet ones are usually the big long ones that most people don't like cuz they don't look cool enough, because there's a lot more volume to reduce the noise. But you can't have both.
If I was you, since I know the track you're talking about is Laguna, I would probably just have 2 different cans. One big quiet ugly can for Laguna, and another one for everything else.
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is online now
post #4 of 10 Old 03-04-2017, 11:38 AM Thread Starter
^Yep, what he said.
Yeah. That's probably the only way. I really like the weight loss and shock access of having the link pipe or getting a small aftermarket can but it's borderline not going to pass sound.
post #5 of 10 Old 03-04-2017, 11:43 AM Thread Starter
I might try getting a custom baffle. There's a guy around here that is always at track days and makes them
ROGUE RACING ZX-10R Jay Murray Decibel Killer Inserts
They direct sound away from the db meter and look like this
Felixthecat likes this.
post #6 of 10 Old 03-04-2017, 01:15 PM
Ah yes, I think it was PG that mentioned the re-direction of sound tactic some people do at laguna. My understanding is there is one spot only where they measure sound which naturally is on the right side of the bike, so re-directing the exhaust should help reduce the reading by a few dB for sure.
post #7 of 10 Old 03-04-2017, 01:59 PM
Felixthecat's Avatar
I Ride: 2012 ZX6R
Believe his name is jay Murray I wa going to mention him too lol
Edit: should probably read the full post it included his name in it lol
2012 Ninja ZX6R
Felixthecat is offline
post #8 of 10 Old 03-04-2017, 03:15 PM
smokey11's Avatar
Could always just short shift at the testing tower... I know that's what some do to get around it. I am in the same boat as you and just ended up running two different cans.
jd41 likes this.
smokey11 is offline
post #9 of 10 Old 03-05-2017, 04:09 PM Thread Starter
I've gotten some info from different manufacturers when it comes to expected db levels
Stock Exhaust at Idle 84 db, at 5000 rpm 88 db, 91 db @ 7000 rpm
- Arrow Gp2 Exhaust: 96dBa @ 7000rpm with the baffle fitted and reaches around 99dBa @ 7000rpm with the baffle removed.
- Austin Racing Exhaust: 103 to 120db
-Graves Slip-on at Idle with insert 90 db at 5000 rpm 103 db
Graves Slip-on without sound insert 96 db at 5000 rpm 106.5 db
- Scorpion power cone with db killer fitted 92 db @ 7000 rpm
Scorpion power cone with no db killer fitted 95.1 db @ 7000 rpm
- Scorpion RP-1 GP with db killer fitted measured 99.8 db @ 6750 rpm
Scorpion RP-1 GP with no db killer fitted measured 102 db @ 6750 rpm
- Serket taper with db killer fitted measured 92 db @ 6750 rpm
Serket taper with no db killer fitted measured 94.5 db @ 6750 rpm
post #10 of 10 Old 03-09-2017, 09:46 PM Thread Starter
I really like the Competition werkes gp exhaust bu it is crazy loud! 116db w/o baffle and around 106 with.
Question concerning stock exhaust and aftermarket bodywork. TheSeaward Racing 14 01-17-2016 03:39 PM
aftermarket exhaust 05/06 Joshmega United Kingdom 5 08-25-2015 01:18 PM
WTB: Full Aftermarket Exhaust for 08 ZZR600 Navjag Want to Buy 0 03-18-2014 12:50 AM
From Aftermarket Exhaust back to stock JokersZX6R Mechanical and Technical 7 01-27-2014 07:02 PM
Wtb 07/08 aftermarket slip on exhaust ZeeExSixR Classifieds 0 09-13-2012 12:25 PM
