G1 Loud rattle/rubbing noise Cam chain tensioner? - ZX6R Forum
 5Likes
  • 1 Post By Mishy
  • 3 Post By Mishy
  • 1 Post By Scorpi0
post #1 of 10 Old 03-04-2017, 11:03 AM Thread Starter
I Ride: ZX6R G1
I picked up a zx6r G1 today. it runs ok except for a loud rattle especially noticeable when the throttle is closed at higher than 2-3k rpm. It certainly seems to be coming from the cam chain side of the engine, and my research suggests its a common issue with the zx6r.
I will be whipping the fairings off tomorrow or next week, weather permitting, but it would be great if someone could impart a little wisdom for me. I am quite mechanically competent so not concerned that i couldn't work it out. However advice never hurts, i also could be barking up the wrong tree, might be something completely different.
Even better would be if someone is local to me in Sussex, England and could have a listen! I can dream.
Thanks in advance
Mishy is offline
post #2 of 10 Old 03-05-2017, 08:40 AM Thread Starter
I Ride: ZX6R G1
I think i may be correct. I whipped mine out today and it looks different to the ones displayed on ebay as for the G model. I will order a new one and fit it next week, hopefully that will fix the problem without having to dis assemble the whole engine
Mishy is offline
post #3 of 10 Old 03-05-2017, 01:39 PM
It may have had an aftermarket tensioner like the APE installed. Can you post photos of what was on the bike?
post #4 of 10 Old 03-05-2017, 04:07 PM Thread Starter
I Ride: ZX6R G1
See the attached photo. its not an APE, its definitely a standard item for something, but not from a ZX6R that i am aware of.
This is the trouble with buying second hand! If a replacement fixes the issue we are golden though. If someone could identify that tensioner that would be helpful.
Mishy is offline
post #5 of 10 Old 03-06-2017, 12:46 AM
That actually look like the correct OEM cam chain tensioner: Kawasaki Motorcycle Parts 1998 ZX600-G1 Ninja ZX-6R CAMSHAFT(S)-TENSIONER Diagram
It still may have gone bad though.
post #6 of 10 Old 03-06-2017, 11:06 AM Thread Starter
I Ride: ZX6R G1
Kawasaki ZX6R G 98-99 Cam Chain Tensioner | eBay
^^ that is what the tensioner arm should look like. I dont think this one is long enough, it offers no resistance when i push it in towards the chain. I would expect it to at least try to push itself back somewhat as it should now be at full extension. I will report back when i have fitted the replacement, should be here by Thursday. Thanks!
Mishy is offline
post #7 of 10 Old 03-07-2017, 09:39 AM Thread Starter
I Ride: ZX6R G1
Soo see attached photo of one from my bike verses my replacement from a zx6r G1. There is about a 10mm difference in length... Im going to sound a bit British here, but I am so, BLOODY BODGERS!
I will fit it tomorrow weather permitting and let you guys know how it goes. i think this might be the culprit however
Scorpi0 likes this.
Mishy is offline
post #8 of 10 Old 03-09-2017, 08:42 AM Thread Starter
I Ride: ZX6R G1
A question to any one who may know, does the flat ratchet side face downwards or upwards? The service manual shows an arrow where there isn't one...
Mishy is offline
post #9 of 10 Old 03-19-2017, 11:18 AM Thread Starter
I Ride: ZX6R G1
Just to complete this off, I fitted the cam chain tensioner and the rattle is gone. Simple fix, happy days
Scorpi0, RJ2112 and Strider like this.
Mishy is offline
post #10 of 10 Old 03-19-2017, 07:42 PM
Nice
Mishy likes this.
how to install a Manual Cam Chain Tensioner zx6r 07 jstunna The ZX6R 13 03-29-2016 09:23 AM
brodas !! no more noise, i reset my cam shaft tensioner ! renzovc16 The ZX6R 5 05-30-2015 07:25 PM
Sorry to start a new thread! 1999 ZX6 cam chain noise! Rickmanalex Mechanical and Technical 7 10-18-2014 11:05 AM
cam chain tensioner for a 04 kawi 636 zx racer The ZX6R 24 05-10-2013 12:46 PM
03-636 cam chain tensioner, can i manually adjust gaillarry The ZX6R 1 07-29-2009 08:20 PM
