Carbs.... - ZX6R Forum
post #1 of 4 Old 03-06-2017, 01:41 PM Thread Starter
Carbs....
Can anyone tell me if I had Carbs from a J will they go on my G ?? I believe it's off a 2001 model going to my 99 model Weathers starting to get ready for bikes so need to fix it now I think problem with the carbs found a cheap set going .
Darrenmma is offline
post #2 of 4 Old 03-08-2017, 12:21 PM
scoot33's Avatar
I Ride: zx6 j2
they are jetted slightly different but will fit
zx6r j2 mods done ,,
scoot33 is offline
post #3 of 4 Old 03-08-2017, 01:28 PM Thread Starter
Hi -- will that affect the running of the bike .... currently don't run at all and I can only attribute it to fuel delivery so intentions to pick cheap set of replacement carbs
post #4 of 4 Old 03-09-2017, 12:56 PM
scoot33's Avatar
I Ride: zx6 j2
i cant imagine it will run to bad as the engines are both 600 so yeh should be fine there is much in the sizes
scoot33 is offline
Buying some second hand carbs labtec104 Mechanical and Technical 5 04-02-2016 03:06 AM
carbs sync please help messed up. dokez888 Mechanical and Technical 2 12-31-2014 10:02 AM
1980 GS550L carbs overflowing Rickthefix Mechanical and Technical 0 08-21-2014 06:09 PM
Bike running like crap! Cleaned Carbs TWICE! lukebolger Mechanical and Technical 3 02-18-2014 03:50 PM
