Metallic rattling noise from the steering axis at 6K RPM? - ZX6R Forum
  • 1 Post By uKER
post #1 of 5 Old 03-07-2017, 08:10 PM Thread Starter
uKER's Avatar
I Ride: 2013 ZX-6R 636
Hi everyone.
Since a while ago my '13 is getting a metallic rattling noise from somewhere around the steering axis whenever I hit 6K RPM.
Once I'm over that point it stops, but it would give me some peace of mind to be able to eradicate it.
The noise is just as if there was a bolt with a free-moving metal washer vibrating.
I've read some people have had noise come out of the ignition switch, but no matter how I try to hold it with my hand, it won't stop, so I'm not sure it's that.
Any ideas what it might be?
Thanks in advance!
Straight lines show the bike.
Curves show the rider.
uKER is offline
post #2 of 5 Old 03-07-2017, 08:15 PM
Its your key rattling most likely. Put ur hand on it next time to see if it stops.
post #3 of 5 Old 03-08-2017, 12:34 AM
I Ride: 2013 zx6r 636
not really a metallic sound but:
visor meeting the brake reservoir?
chips is offline
post #4 of 5 Old 03-08-2017, 01:59 AM
It's most likely one of your levers, either the brake or clutch lever. My 250R used to do that, and it took me a bit to figure out what it was. The lever had some play in it (up and down), and it would rattle with higher RPM's.
post #5 of 5 Old 03-08-2017, 03:09 AM Thread Starter
uKER's Avatar
As I said, I've tried it before, but will give it another chance.
Hm, nah, it's really a metallic noise.
Yeah, the clutch lever on my Ninja 300 used to do that and it stopped if you rested your hand on it.
Will try it on this one and let you know.
Thanks everyone for the suggestions.
uKER is offline
Rattling Noise / Minor Vibration (09') srt10ram The ZX6R 4 09-02-2015 08:41 AM
Front Steering Squeek Noise ronsta86 Mechanical and Technical 4 12-04-2013 02:06 AM
rattling noise getting worse pogiboy509 Mechanical and Technical 0 06-23-2011 12:02 PM
still got that rattling noise pogiboy509 Mechanical and Technical 0 05-27-2011 08:49 AM
Rattling noise on 09 ZX6R Thrash1982 The ZX6R 14 07-28-2009 05:36 AM
