Battery or stator? - Page 2 - ZX6R Forum
post #16 of 19 Old 03-08-2017, 07:46 AM
Originally Posted by zeroflln View Post
Thanks strider and what do you recommend as far as an auxiliary fuel source? Or do you think I could just prop the tank and still get to the connector? I have small hands so I think I might be able to.
You may not even need to move the tank depending on where your regulator/rectifier is located. But if you need the tank out of the way, you can just prop the tank up. I usually use a couple bungee cords to hold the tank up/back.
Edit: I just looked at the service manual for your year model, and it looks like the regulator/rectifier leads/plugs are under the fuel tank. So you will need to at least prop the tank up. Here is a diagram:
File Type: pdf Regulator-Rectifier Leads - ZX636B1_B2.pdf (93.6 KB, 3 views)
post #17 of 19 Old 03-10-2017, 12:16 AM Thread Starter
zeroflln's Avatar
I Ride: 2003 zx6r and 2015 Ninja 300
Tested everything had a electrician guy from work give me a hand. Stator, rectifier, and fuses all checked out. I replaced the battery and the past few days has been fine. The battery the previous owner had on it was a wal- mart battery. $20 dollar batteries prolly ain't worth a crap. I put a $100 battery in it now.
RJ2112 and Strider like this.
zeroflln is offline
post #18 of 19 Old 03-10-2017, 02:58 AM
Hmmm
Didnt sound like the battery was the issue.
post #19 of 19 Old 03-10-2017, 03:24 AM Thread Starter
zeroflln's Avatar
When I had the old battery tested I was told that the cca was at 34 and that it wouldn't take a charge. The new battery has 120 cca and testing it while my bikes running shows the stator is actually charging it now. I didn't think it was the battery either though. Time will tell I guess.
zeroflln is offline
2nd time being stuck! Battery? Stator? HELP!! Zx6Nate Mechanical and Technical 63 10-21-2016 10:19 AM
2013 ZX636R Replacement Battery Help Needed I Am Snags Mechanical and Technical 7 05-06-2016 10:59 AM
Battery drainage problem philippe Mechanical and Technical 2 03-09-2014 08:47 AM
Battery? Stator? Something else? mrmcbizzie Mechanical and Technical 21 08-08-2013 05:05 AM
Battery or Stator? MonsterZX Mechanical and Technical 10 08-16-2012 10:21 AM
