Battery or stator? - ZX6R Forum
post #1 of 19 Old 03-07-2017, 09:42 PM Thread Starter
zeroflln's Avatar
I Ride: 2003 zx6r and 2015 Ninja 300
Battery or stator?
Ok new problem on the 03 zx6r. It has 29500 miles. Testing the battery when off gives me a reading of 12.4. When under load it drops to 9.5 when the bike starts. Once running it will idle 10 to 15 minutes then the headlights will go out then gauges will dim. Eventually the battery dies and I need a jump. When running the battery holds a charge at 11.5 to 11.8 and doesn't act like it's dropping any so I'm thinking the stator is good? I see mixed reviews everywhere. They say the stator should be good if you can't see the volts dropping while it's running. So I'm thinking maybe just the battery?
zeroflln is offline
post #2 of 19 Old 03-07-2017, 09:44 PM Thread Starter
zeroflln's Avatar
Also if anyone knows of a stock headlight assembly for an 03 let me know bc all I can find are used one's with broken or missing parts. Looked for new but they run well over 200 bucks.
zeroflln is offline
post #3 of 19 Old 03-07-2017, 09:53 PM Thread Starter
zeroflln's Avatar
The halos the previous owner put in was a shit job. I want stocks again bc I'm sure their wiring job might be at fault possibly. The low beam runs fine but the high flickers and the seal job sucks so it gets condensation.
zeroflln is offline
post #4 of 19 Old 03-07-2017, 09:54 PM
The voltage with the bike running needs to be about 14volts. Your charging system is definitely fucked.
post #5 of 19 Old 03-07-2017, 10:01 PM Thread Starter
zeroflln's Avatar
So stator then? Rectifier? And battery? Should I replace everything?
zeroflln is offline
post #6 of 19 Old 03-07-2017, 10:09 PM Thread Starter
zeroflln's Avatar
Is caltric a good stator brand?
zeroflln is offline
post #7 of 19 Old 03-07-2017, 10:23 PM
That would be the lazy and expensive route.
U can test each with a multimeter and determine which is actually faulty. Itll save u money.
post #8 of 19 Old 03-07-2017, 10:28 PM Thread Starter
zeroflln's Avatar
I'm not good with a multimeter outside of YouTube lol got any steps to take? The caltric stator is only $52.99 it's an oem replacement. I can pull the battery from my good ninja and swap them to see if that's the problem.
zeroflln is offline
post #9 of 19 Old 03-07-2017, 10:32 PM
The battery isnt the problem. Its either the stator or voltage regulator. I dunno shit about Caltric brand stators.
All the testing is in the manual. All u gotta do is check a couple wires. I can post the instructions if u wanna try it.
post #10 of 19 Old 03-07-2017, 10:34 PM Thread Starter
zeroflln's Avatar
I found a vid on how to test my stator. Is the gasket on the cover reusable if I crack it open to test it in the morning?
zeroflln is offline
post #11 of 19 Old 03-07-2017, 10:35 PM Thread Starter
zeroflln's Avatar
I'll try anything to make her run right.
zeroflln is offline
post #12 of 19 Old 03-07-2017, 10:36 PM Thread Starter
zeroflln's Avatar
As long as it tells me what to set my multimeter on I'll be able to do it.
zeroflln is offline
post #13 of 19 Old 03-07-2017, 10:37 PM Thread Starter
zeroflln's Avatar
Electrical + me = supernoob
zeroflln is offline
post #14 of 19 Old 03-08-2017, 02:10 AM
You don't need to remove the stator cover to do the testing. You do all the testing via the plugs at the regulator/rectifier.
I am attaching the testing procedure from the service manual:
File Type: pdf Charging System Inspection - ZX636B1_B2.pdf (227.8 KB, 11 views)
post #15 of 19 Old 03-08-2017, 04:56 AM Thread Starter
zeroflln's Avatar
Thanks strider and what do you recommend as far as an auxiliary fuel source? Or do you think I could just prop the tank and still get to the connector? I have small hands so I think I might be able to.
zeroflln is offline
2nd time being stuck! Battery? Stator? HELP!! Zx6Nate Mechanical and Technical 63 10-21-2016 10:19 AM
2013 ZX636R Replacement Battery Help Needed I Am Snags Mechanical and Technical 7 05-06-2016 10:59 AM
Battery drainage problem philippe Mechanical and Technical 2 03-09-2014 08:47 AM
Battery? Stator? Something else? mrmcbizzie Mechanical and Technical 21 08-08-2013 05:05 AM
Battery or Stator? MonsterZX Mechanical and Technical 10 08-16-2012 10:21 AM
