Nissin Brake Calipers - ZX6R Forum
post #1 of 8 Old 03-09-2017, 01:37 PM Thread Starter
staningrimsb's Avatar
I Ride: Kawasaki ZX6-R (2000)
Hey Guys,
I have bought a set of Nissin brake calipers off good old Ebay and the guy that was stripping the bike said he had no idea what they originally came off as they were always on his Ninja.
I no it's normally the 1200 Bandit calipers that fit direct so will this be the rebuild kit for them as I might as well do that before they go on my bike,
Suzuki GSF 1200 Bandit Nissin front brake caliper seal rebuild kit T ST 1996 | eBay
Cheers for any info guys,
Stan.
staningrimsb is offline
post #2 of 8 Old 03-09-2017, 02:06 PM
What year was his ninja.
Mine's an 06,, has the 08 Kawi nissin calipers.
post #3 of 8 Old 03-09-2017, 11:18 PM Thread Starter
It was a 2000 J1 exactly the same as mine, so I presume they are from a 1996 to 2000 bandit but the seller didn't know he said he bought the bike with them already on.
I have been in touch with Powerhouse though who say if I can take a photo and measure the size of the pistons they will be able to identify them for me so I get the right kit :-)
post #4 of 8 Old 03-10-2017, 03:49 AM
Post up your findings. I'm sure it will be of help to someone down the road.
post #5 of 8 Old 03-10-2017, 04:50 AM Thread Starter
Certainly will going to send the info to them when I get home.
post #6 of 8 Old 03-10-2017, 10:56 AM
scoot33's Avatar
I Ride: zx6 j2
the nissin 4 pots can very in sizes on bore size,might be worth measuring pistons to get you sorted,they fit them on a few bikes like gsxr 600 400 750 the older type and also bandit as you know ,,,,i am looking to get some for my track bike but been looking at prices they are silly money,,,,,but been doing some research the triumph sprint runs the nissin 4 pots but they are badged as triumph and they go at a good £50 the pair ,and also they run braided lines as stock which are a shit load cheaper, between £14 to £25 a front pair,i just need to get the length,they run the nissin front brake master cylinder as well same as the g/j series
zx6r j2 mods done ,,
scoot33 is offline
post #7 of 8 Old 03-10-2017, 02:09 PM
I could measure my Tiger's calipers. thought they were 110 mm between the bolts.
Check the speed triple forum the started using them off of the Yamaha Monoblock Calipers from 07 R6
05 S3 Brake Upgrade
post #8 of 8 Old 03-11-2017, 12:14 PM
scoot33's Avatar
I Ride: zx6 j2
think its the 1050 sprint pre radial thin up to 2006 they are 90mm spacings ,witch is the same as the old forks like on the ninjas indy,,the old school that didnt stop lol,,i fitted 06 forks to mine with anf fitted r1 mono blocks with zx12r 320mm discs ,fuck me i can stop on a nats g string lol
scoot33 is offline
WTB: 07 Cluster and/or Nissin Calipers eyZeX Want to Buy 3 03-06-2017 01:19 AM
05-06 brake master fix inc part list skidooboy Mechanical and Technical 16 06-30-2015 10:39 PM
07-12 Nissin Calipers - Track Brake Pads Ebster1085 Racing 21 05-10-2014 05:31 AM
07+ Nissin Calipers Ebster1085 Racing 8 04-10-2014 07:27 AM
07-08 zx6r nissin calipers mr jdm Classifieds 0 04-24-2012 11:00 PM
