99 Petcock Brass Fitting Broke/Fell Off - ZX6R Forum
  • 1 Post By scoot33
post #1 of 9 Old 03-09-2017, 02:13 PM Thread Starter
mharrison's Avatar
I Ride: 1999 zx6r
I have a 99 ZX6R that I just acquired. When checking things out to see about getting her running, I noticed the fuel line was crumbling. When I went to remove it, the brass fitting/nipple for the main fuel line pulled right out of the petcock body. I have identified the fitting in this picture, but it's not this aftermarket style petcock. It is the one with the long plastic handle. Is this just press fit in there? Is there any way to repair this? I'd like to keep a stock petcock with the long plastic handle. All the replacements I'm finding have the small metal handle as in the picture.
mharrison is offline
post #2 of 9 Old 03-09-2017, 05:05 PM
My guess is you are going to have to replace the body of the valve.
I expect that the aluminum of the valve body corroded away from the brass..... cathodic element.
This probably means that the hole in the body is now misshaped and too large for the brass nipple.
If you have to do a redneck fix, you could drill out the hole and install a larger nipple....
post #3 of 9 Old 03-09-2017, 05:27 PM
Maybe glue it back in with some JB Weld.
post #4 of 9 Old 03-09-2017, 09:19 PM Thread Starter
mharrison's Avatar
I Ride: 1999 zx6r
That's what I was afraid of. I guess I'll buy one of the ones I don't like until I can find a new OEM one.
post #5 of 9 Old 03-10-2017, 11:00 AM
scoot33's Avatar
I Ride: zx6 j2
do you use ebay?will fine used one maybe ?mine fell off as well ,i was trying to remove fuel pipe so i was pulling and twisting then i pulled out the brass tube ,i just tapped mine back in with a bit of wood as it was a nice snug fit ,,no leaks with mine so far all good
mharrison likes this.
zx6r j2 mods done ,,
scoot33 is offline
post #6 of 9 Old 03-10-2017, 11:56 AM Thread Starter
mharrison's Avatar
I Ride: 1999 zx6r
I plan to keep an eye on eBay, but the ones I've seen so far look pretty rough. If I'm buying a used one, I want one that is in really good shape.
post #7 of 9 Old 03-10-2017, 12:28 PM
jimundascores's Avatar
Post should be moved to NSFW with all this talk about cocks and nipples.
jimundascores is offline
post #8 of 9 Old 03-11-2017, 12:15 PM
scoot33's Avatar
I Ride: zx6 j2
jim you perv lol,,,
scoot33 is offline
post #9 of 9 Old 03-11-2017, 12:18 PM
scoot33's Avatar
I Ride: zx6 j2
mh ,the g is the same as well not sure if you knew ,,ebay would be the best bet as i can imagine a new oem aint fkn cheap ,have you tried pushing it back in ?mine is fine no leaks and no a team fire balls lol
scoot33 is offline
petcock zx6r fuel
Scorpion exhaust fitting Mbeats The ZX6R 2 05-27-2014 07:13 AM
Fiberglass track bodywork fitting & painting Rickthefix The Build Thread 12 01-11-2014 08:37 AM
G & J model fuel selector / petcock write up: whocanitBnow Mechanical and Technical 7 10-18-2012 02:23 PM
97 zx6r leaking petcock nayotte Mechanical and Technical 23 06-09-2012 04:16 PM
Scorpion Exhaust fitting help (ZX6R C1H) ZX6R_C1H The ZX6R 4 06-20-2009 02:32 AM
