Leak need your advise - ZX6R Forum
  • 2 Post By Indy
  • 1 Post By aodrn
post #1 of 9 Old 03-09-2017, 03:38 PM Thread Starter
Hi Kawi bro's I bought this bike last month and did the oil change and notice that leak. 2008 zx6r 20 000km on it
https://vid.me/s63R
What do you suggest?
sebiostyle is offline
post #2 of 9 Old 03-09-2017, 03:56 PM
Did you try torquing the nuts down.
If yes, get new 11060-1203 GASKET,EXHAUST PIPE
Install the 4 of them, torque. Get bike hot, let cool down.
Torque again, repeat total of 3 times. Last time they should be good. If not do one more time.
RJ2112 and sebiostyle like this.
Indy is online now
post #3 of 9 Old 03-09-2017, 05:50 PM
You may also want to see if it has had the valve cover gasket replaced under warranty. They had an issue on that year model.
post #4 of 9 Old 03-09-2017, 06:07 PM Thread Starter
Do you think its normal to have oil leak from that place?
I noticed on the left side there is more oil deposit and on the inside of the fairing also what do you think?
ID:	58130   Click image for larger version
post #5 of 9 Old 03-09-2017, 06:24 PM
I Ride: 2014 Kawasaki ZX-6R
Like @Strider said, there's a known issue with the valve cover gasket that is replaced under warranty. Check with your dealer . . . if not do it yourself, it's pretty easy.
Martillo y Mantequilla #99
post #6 of 9 Old 03-09-2017, 07:39 PM
aodrn's Avatar
I Ride: 2007 ZX6R
Looks like its draining down from the valve cover and becomes more visible once it hits the exhaust. I just had the dealership replace my valve cover gasket for free. It's not a full on recall. Its a technical service bulletin or something. Basically you have to have the dealership say that it is leaking. Then Kawi will pay for the fix.
aodrn is offline
post #7 of 9 Old 03-10-2017, 06:20 AM Thread Starter
Thanks for the tips guys I'll try to have it for free
post #8 of 9 Old 03-10-2017, 06:23 AM
capitalcrew's Avatar
Does that go for 07 as well guys?
capitalcrew is offline
post #9 of 9 Old 03-10-2017, 06:56 AM
aodrn's Avatar
I Ride: 2007 ZX6R
2007-2008
capitalcrew likes this.
aodrn is offline
Need Help Stopping A Leak CodeMonkey The ZX6R 3 08-04-2016 10:37 PM
Oil leak from throttle body area near head Munchy Mechanical and Technical 11 06-28-2013 11:36 AM
07 left side oil leak gcxandrew The ZX6R 29 11-17-2012 08:24 PM
Mysterious Oil Leak... advice needed? WhiteTrash Mechanical and Technical 19 07-18-2012 11:58 AM
Tiny leak in tire... Iconmoto528 The ZX6R 6 07-24-2011 06:43 PM
