Fork compatibility - ZX6R Forum
  • 1 Post By Strider
  • 1 Post By Felixthecat
post #1 of 4 Old 03-09-2017, 07:50 PM Thread Starter
Fork compatibility
I understand the '13+ BPF is quite superior to the '09-12 ZX6R. A contact has a cherry set of '13+ forks that I'd like to put on my '09. I'd like to know if there are any compatibility problems with front fender, possible diff front brakes (abs), fork barrel diameter, clip on differences, etc.
Derekdlf is offline
post #2 of 4 Old 03-09-2017, 08:48 PM
I don't see why they would be superior, but I have heard that they are much softer OEM vs the 2009-12 OEM. The 2009-12 are actually better for the track, where the 2013+ were geared a little more toward the street.
sbk1198 likes this.
post #3 of 4 Old 03-09-2017, 08:53 PM
I believe diameters are the same so they should fit in the triples, but I'm not sure if the axle is the same. I know the 13-17 don't have a nut, because the axle threads directly into the opposing fork leg, whereas on the previous models it threads into a nut on the other side. So the new ones only use 2 pinch bolts on the right side fork. I just don't know if the axles are compatible.
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is offline
post #4 of 4 Old 03-09-2017, 09:11 PM
Felixthecat's Avatar
I Ride: 2012 ZX6R
Clip ons are different by 1mm soooo idk if they are perfect fits in the triples. Brakes on the 13 and up are bigger and calipers are different too.
sbk1198 likes this.
2012 Ninja ZX6R
Felixthecat is offline
Fork oil is fork oil...... RJ2112 Mechanical and Technical 8 07-19-2015 06:49 AM
03-04 zx6r fork help ! Jnelson50 The ZX6R 4 03-24-2015 11:30 AM
2005 ZX6R Fork Oil Chang - W/ Tips From Dave Moss tmolnar21 Mechanical and Technical 18 01-24-2014 02:03 PM
Fork Spring Compatibility? AP Guy Mechanical and Technical 0 03-13-2013 10:49 AM
How to: Fork Seal Change for 1995-1997 ZX6R/Conventional Forks AgentOrange Guides 0 07-28-2012 01:03 AM
