Main Relay Assy. connector repair - ZX6R Forum
post #1 of 4 Old 03-10-2017, 05:05 PM Thread Starter
Need to replace an electrical contact in the middle connector of the wiring harness that connects to the main relay assembly of an 07. Does anyone have a part number/source for replacement electrical contacts and know how to remove a contact from its shell. Contact is conductor for main power to the ECU. Thank you.
JDBrad is offline
post #2 of 4 Old 03-10-2017, 05:57 PM
post #3 of 4 Old 03-10-2017, 06:12 PM
Hello Brad.. First welcome to the forum.
Second, say HI in the new members section. It's great to hear about past rides and your present one. Pictures are a must.
The first link should work for the connectors. This is for the extractors.
https://www.corsa-technic.com/catego...category_id=88
Get them all, you will use them sooner or later. They slide over the wire, down to the pin and over the catch that holds the pin into the connector.
Might get a couple of pin's also. They aren't hard to damage and won't stay in place if you do.
post #4 of 4 Old 03-11-2017, 07:43 AM Thread Starter
Great resource! Thank you.
JDBrad is offline
WTB main starter relay connector for 06 5hift Want to Buy 0 02-09-2015 03:53 PM
LED Turn Signal Relay Fix drbyers Mechanical and Technical 4 10-03-2014 07:14 AM
L.E.D. turn signal relay brimmer555 The ZX6R 10 12-18-2012 05:02 PM
Lap timer as Manual fan switch - Guide Finished <-- Magoogle Mechanical and Technical 19 08-12-2012 06:34 PM
No Headlights, Relay box issues?? Soothingaloe Mechanical and Technical 6 01-03-2011 02:49 PM
