Holding cams in place - ZX6R Forum
 4Likes
  • 2 Post By RJ2112
  • 1 Post By Elwood
  • 1 Post By Strider
post #1 of 9 Old 03-11-2017, 05:29 PM Thread Starter
OK so what's the secret for holding the cams in place while putting the carriage back on. Well while tightening it down.
Since a set of intakes and exhaust are being pushed down they want to rotate.
So with the chain and cam's in place, when I start getting the carriage down the cams want to rotate.
post #2 of 9 Old 03-11-2017, 06:32 PM
MotoCT's Avatar
I Ride: 2009 monster energy zx6r
The tightening sequence of the plates in the manual is key. I was sketched myself about the cams moving around, but when I followed the sequence it placed the cams just right. I went through the sequence incrementally and the third time around I torqued them to spec. First time around was finger tight, next was 52 in/lb, and last to 106 in/lb.
MotoCT is online now
post #3 of 9 Old 03-11-2017, 06:56 PM Thread Starter
Well I must be doing something wrong then.
I have tried several times and they rotate as I tighten them down.
post #4 of 9 Old 03-11-2017, 07:16 PM
It doesn't matter that they move..... If the cams are indexed on the timing chain correctly, they will end up where they are meant to be.
It won't be correct, until the tensioner takes out the slack on the timing chain. Well after you torque all the caps in place.
Strider and PainfullySlo like this.
post #5 of 9 Old 03-11-2017, 07:20 PM
Elwood's Avatar
I Ride: 05 ZX6R
They will rotate, you can't stop it. When you tighten the plate down you start to compress the valve springs. This causes the cams to rotate. You have to compensate for that as you're timing the cams. The exhaust cam kept moving on mine, plus you can't really see the timing mark on the 05-06 exhaust cam due to the frame. I had to line the exhaust cam so the alignment mark was just below the cylinder head edge. Once you think you have it right and tight, rotate the engine a minimum of 2 full turns by hand before you try to engage the starter.
PainfullySlo likes this.
Elwood is online now
post #6 of 9 Old 03-11-2017, 07:24 PM
Elwood's Avatar
I Ride: 05 ZX6R
BTW, next time make reference marks on each cam gear to chain and crank gear to chain. Takes all of the guess work out of timing the engine.
post #7 of 9 Old 03-11-2017, 07:48 PM Thread Starter
I did,,
Put the cam's in. Aligned with the marks before taking them out.
But as I tighten the carriage down the chain is loose enough to allow the cams to rotate from the marks made before starting.
post #8 of 9 Old 03-11-2017, 08:31 PM
Originally Posted by Indy View Post
I did,,
As mentioned by others above, this is normal. Once everything is tightened down, the cam chain tensioner has been installed, and the engine rotated a couple times, everything will fall into place properly.
Strider is online now
post #9 of 9 Old 03-12-2017, 05:26 AM
This.
Make sure you use assembly lube on the cam journals and that you rotate the engine by hand (in the correct direction) a few revolutions after you have buttoned everything up to allow the cam chain to align and the tensioner to spring to its normal location.
PainfullySlo is online now
Good Place to Find Replacement Fairings? code 3 Mechanical and Technical 5 12-16-2016 08:58 PM
98 holding in around 42mph 70kmph after faling derfske Mechanical and Technical 1 10-08-2016 03:50 PM
Tanning Room cams! raized1199 Videos 2 09-25-2009 05:41 PM
Race cams for 2002 zx6r 2002zx6r Racing 2 09-04-2009 06:25 PM
milled heads & cams wheelies247 The ZX6R 14 07-08-2009 08:25 AM
