99-02 Fairing Swap - Ram Air & Headlight ?s - ZX6R Forum
post #1 of 3 Old 03-15-2017, 02:26 PM Thread Starter
mharrison's Avatar
I Ride: 1999 zx6r
So I'm swapping over to the 02 zx6r fairing set with the dual headlights. I have a few questions that most of you probably know the answer to, but here we go. (Yes I searched.)
Ram Air
Is the entire ram air assembly necessary? Does it support part of the fairing? Does the bike run like $4i+ without it?
Headlight
When swapping the headlights I know I have to do some wiring and that's no problem. But, can I run a dual element bulb in both sides, or will this be too much for the charging system? Will the internal reflectors make the light pattern worthless?
mharrison is offline
post #2 of 3 Old 03-15-2017, 03:46 PM
Predator6R's Avatar
I Ride: 2002 ZX-6R Fighter
My bike is in fighter mode and it doesn't have the ram air setup on it. Runs like a champ, but the ram air systems are the same between the 98-02 models so it should be plug and play. If you don't want to run it like that you might have to rejet the carbs and make sure you keep the breather hose for the carbs somewhere on the bike.
As for the headlight you should be able to get away with it. Both models run an H4 bulb which has 2 filaments. All you'd have to do is buy another connector, splice into the corresponding wires, and boom you'll have another running light. That should do the trick
Predator6R is offline
post #3 of 3 Old 03-16-2017, 12:43 PM
scoot33's Avatar
I Ride: zx6 j2
the ram system is different on the nose cone part,the rubber pipes coming out the frame are the same but plastic nose cone parts on the g and j are different,, as for running without ram predator would be the the one to talk to on that as i still have ram system on my zx6r
zx6r j2 mods done ,,
scoot33 is offline
09-12 ZX6R Fairing parts AnfarnoCorin Classifieds 9 05-24-2017 08:27 AM
Ram air duct?!?!? JDGzx6r The ZX6R 3 04-23-2012 09:38 PM
Looking for 05-06 Ram air and Nose brandonb85 Classifieds 1 04-04-2012 02:59 PM
05 636 right side ram air tube? rainman Mechanical and Technical 14 02-07-2012 05:07 PM
99 upper fairing swap davionist87 The ZX6R 15 03-30-2009 10:04 PM
