New to this Forum but I'm pretty good at fixing things here's a quick DIY - ZX6R Forum
 4Likes
  • 1 Post By KFlo238
  • 2 Post By capitalcrew
  • 1 Post By Scorpi0
post #1 of 11 Old 03-18-2017, 12:06 PM Thread Starter
I Ride: 2000 Ninja 250 (Sold), 1983 Nighthawk 650 (Sold), 1992 ZX600D3
Talking New to this Forum but I'm pretty good at fixing things here's a quick DIY
Hi guys,
I'm new to this forum but I've been doing mechanical work for a long time. I recently put together a DIY on how to fix a distorted cylinder block and cylinder head from a blown head gasket. I would just like to share this information with you all to hopefully help those guys who are having this issue. Please let me know what you think.
Cheers,
Karl
KFlo238 is offline
post #2 of 11 Old 03-18-2017, 12:52 PM
Hello and welcome to the forum.
Assumed you checked the block with the ruler to confirm your spec's on the block?
Why not take a minute and say HI in the new members section. Tell us about your bike and past ride's etc.
How's the build going.
Indy is online now
post #3 of 11 Old 03-18-2017, 01:12 PM
I Ride: 2014 Kawasaki ZX-6R
Cool. Welcome.
Martillo y Mantequilla #99
post #4 of 11 Old 03-18-2017, 02:25 PM Thread Starter
Hello Indy,
Yes, I did use the machinist ruler to check the tolerance against the specs from the manual.
Roger that, I will go ahead and introduce myself on the new members section.
The build is pretty much done lol. I just have old videos that sat around and I finally got around to editing them.
Thanks for the feedback,
-Karl
KFlo238 is offline
post #5 of 11 Old 03-18-2017, 02:38 PM
The problem with what you're doing is that when you're finished you may have a flat mating surface but that doesn't mean it is parallel to the center plane of the head. Getting the head flat is easy, getting it straight isn't.
I'm glad it worked out for you, I just wouldn't recommend other people try it.
capitalcrew is offline
post #6 of 11 Old 03-18-2017, 03:07 PM
Do you mean the thickness of the jugs in relationship for all cylinders?
Besides a long caliper, could one level of the block and then confirm the top of the jugs are flat and level would that be a decent check.
You did bring up a valid point I hadn't thought of.
Indy is online now
post #7 of 11 Old 03-19-2017, 05:47 AM
Definitely a cool DIY but as was mentioned there is no guarantee that you will be able to keep the plane when using this method.
Personally for something that ignites gasoline, spins at 16,000RPMs and resides between my legs...I will let the pro's handle that kind of work.
PainfullySlo is offline
post #8 of 11 Old 03-19-2017, 05:58 PM
Imagine the cams in the head. They are parallel to the crankshaft correct? Now imagine when you sand the contact surface of the head the bottom of the head is no longer parallel to the cams, they won't be parallel to the crank either then. Jugs => [] [] <= head. You could end up with jugs => [] \] <= head.
Machine shops go through a lot of trouble to avoid this sort of thing.
WERA689 and PainfullySlo like this.
post #9 of 11 Old 03-19-2017, 07:38 PM
How good does one have to be to be considered a pro? Ive seen a lot of "pros" that didnt know what theybwere doing.
Indy likes this.
post #10 of 11 Old 03-20-2017, 06:07 AM
That would be why I do 99% of my own work, and that 1% that I cannot do myself (like machining because I don't have the equipment) I only send it to someone that I trust.
post #11 of 11 Old 03-20-2017, 06:20 AM
It's pretty easy to find a good machinist IMO. Machining is a hard thing to BS your way through so the bad shops get a bad rep pretty quick. Just ask around in the local "scene" and you'll know the right place to go pretty quickly.
Pretty Good Article on Visual Skills MistressOfMayhem Motorcycle Talk 8 03-19-2014 09:15 AM
Pretty good Helmet Deals -- Just a heads up ZZRJo Classifieds 0 03-28-2013 03:33 PM
Newbie needs some pretty quick advice.... davek The ZX6R 16 11-25-2011 09:09 AM
All good things must come to an end. HotIce The ZX6R 50 10-08-2011 02:02 PM
