Messed Up the Throttle / Idle - ZX6R Forum
  • 1 Post By jd41
  • 1 Post By PainfullySlo
post #1 of 8 Old 03-20-2017, 08:24 AM Thread Starter
RoidRageFool's Avatar
Hey guys,
I switched to the R6 Throttle on my 2013 zx6r and have a small issue. When i turn the bars to the left or to the right, the RPMs start to raise, and not by a little. How do I go about adjusting the cables. I have not clue?
Thanks
Racefit: Not for everybody.....
RoidRageFool is offline
post #2 of 8 Old 03-20-2017, 09:00 AM
I Ride: 2014 Kawasaki ZX-6R
Sounds like the throttle is too tight. You can loosen the throttle cables right above the throttle assembly
PainfullySlo likes this.
Martillo y Mantequilla #99
jd41 is online now
post #3 of 8 Old 03-20-2017, 09:06 AM
Make sure the cables aren't hung up or pinched somewhere. If anything tugs on the cables when you turn the bars, then it will cause the issue you are having. Make sure the cables are routed correctly and aren't hanging up on anything (e.g. the spot where the fuel tank bracket holds them down, etc).
Strider is online now
post #4 of 8 Old 03-20-2017, 09:28 AM
I love this forum. Answered in the first response =)
PowerGroove likes this.
PainfullySlo is online now
post #5 of 8 Old 03-20-2017, 09:56 AM Thread Starter
Thanks guys,
I was searching the internet and everyone was saying to check the routing of the cables. I started to make some adjustments that messed up the idle which made me frustrated. Got everything pretty close.
Thanks for the videos and quick reply. Should get this taken care of real fast.
post #6 of 8 Old 03-20-2017, 03:06 PM Thread Starter
So I Did get it all fixed. There is no free play with the throttle though. Is this what most guys were shooting for when they switch to the R6 throttle tube. I know it is a shorter turn but after installing, it is turn and go, zero free play. I don't care, I am just wondering.
post #7 of 8 Old 03-20-2017, 03:09 PM
The stock throttle tube is 1/4 turn.
R6 throttle tube (1/6 turn) has just barely enough slack available to mount with the stock cables.
I went with the R1 (1/5 turn) throttle tube to have slightly more room for adjustment.
jd41 is online now
post #8 of 8 Old 03-20-2017, 04:25 PM
Maybe I am crazy but I still use the OEM tube. I actually prefer to have more modulation of the throttle.
Idle Adjustment Needed or Normal? RoidRageFool Mechanical and Technical 3 04-24-2016 08:43 AM
Bad throttle response/no pull when hitting the throttle? TH3WOLF Mechanical and Technical 7 06-21-2014 06:03 AM
Hanging rpms when idle is adjusted??? venomracer Mechanical and Technical 17 02-27-2014 07:31 PM
Secondary throttle plates removed, running issues rxlucky7 The ZX6R 4 01-11-2014 08:04 PM
Wont idle consistantly sethg1981 Mechanical and Technical 4 10-17-2011 06:44 AM
