immobilizer problem. - ZX6R Forum
post #1 of 3 Old 03-20-2017, 11:36 AM Thread Starter
hi guys. first off, my bike is not stolen. it is one of two or three like this in iceland. mine had the misfortune to highside under the owner at 250 kph but by miracle he came out standing butnot the bike. the bike had less than 7000 km on the clock when this happened. after the crash the insurance company refused to pay sue to the driving style at the time of accident so to make a long story short the bike went from one owner to the other and when i bought it without a registration two years ago there were no nody parts with it, no gauges, subframe, lights and so on and so forth. frame was okay as well as e gine ans fueltank in usable condition. i bought from usa a subframe, exhaust, muffler, ecu said to be for none immobilizer, rear wheel and caliper, rear swingarm and bolts and clocks. one former ownerwanted to remove the ignition cylinder, but instead remove the top yoke and drill out the two headless screws he decided to use a grinder cutter through the yoke around the ignition cylinder. needless to say this did not go well. but now to my problem. the antenna around the ignition key does not look pretty, you can see the coil wires damaged as they are. i just got a service manual from you guys so i can check the fault codes. but o read on your site somewhere that to disable or cheat the immobilizer system i need to find some blue wire and put 12 volts to it through a 100 ohm resistor ??
can anyone point out to me some help or solution to this
SiggiK is offline
post #2 of 3 Old 03-20-2017, 06:46 PM
Hello and welcome!
post #3 of 3 Old 03-20-2017, 10:28 PM
So umm...
What year is it?
Help Diagnosing 2009 ZX-6R Starting/Shutting Off Problem ticaaal70 Mechanical and Technical 4 04-10-2014 12:31 AM
Battery drainage problem philippe Mechanical and Technical 2 03-09-2014 08:47 AM
ongoing problem with my '13 636 ch1ckenstrip The ZX6R 16 02-15-2014 08:27 PM
Electrical problem doing me crust in Haggis Mechanical and Technical 0 10-14-2013 06:57 AM
Problem with rear tire sliding Rotem46 Racing 17 06-01-2013 02:06 PM
