idle problem?? - ZX6R Forum
  • 1 Post By Scorpi0
post #1 of 8 Old 03-20-2017, 12:05 PM Thread Starter
Inkk's Avatar
I Ride: 05 kawasaki zx636
idle problem??
So I installed a pc3 ignition module on my 05 zx6r. It would idle irractically and then die. Talked to someone from dynojet and he told me to cut the black/white wire to the ground. Now it runs fine but it idles irractic still but not as bad as before I'll try and post a video later. But if I rev the bike it won't die. Is it because I don't have an ignition map and it's messing up my ignition timing or what. Thanx in advance
Inkk is offline
post #2 of 8 Old 03-20-2017, 01:50 PM
Have you checked the throttle bodies to make sure they are balanced?
post #3 of 8 Old 03-20-2017, 02:32 PM Thread Starter
Inkk's Avatar
No I'll check that but if I take the ignition module off the bike runs as it should
Inkk is offline
post #4 of 8 Old 03-20-2017, 11:55 PM
Well theres your problem!
Load a map on it...see what happens. Shouldve tried that before cutting any wires.
Indy likes this.
Scorpi0 is online now
post #5 of 8 Old 03-21-2017, 04:43 AM Thread Starter
Inkk's Avatar
Where do I find an ignition map though I've looked everywhere and dynojet doesn't provide them on there site. And only reason I cut that wire is cause I read some threads online that were talking about it and fixed their problem so when the dynojet guy told me that I didn't hesitate and it worked.... Kinda lol
Inkk is offline
post #6 of 8 Old 03-21-2017, 07:32 AM
Here you go: Power Commander Motorcycle Fuel Injection Tuning Module
post #7 of 8 Old 03-21-2017, 04:35 PM Thread Starter
Inkk's Avatar
Isn't that for power commander? I need map for ignition module
Inkk is offline
post #8 of 8 Old 03-21-2017, 09:08 PM
Ah, I don't think you are going to find a "map" for that. You will probably need to have it tuned at an authorized shop. You can set it all to zeros for now, if it isn't already that way.
What is your purpose for installing the ignition module?
95 zx6r idle and pre 5000 rpm problem Quarde Mechanical and Technical 0 05-23-2016 03:41 PM
2013 ZX6R stalling issues zx6rmatthew Mechanical and Technical 8 07-24-2014 08:01 PM
idle help please zixxersixxer The ZX6R 3 03-09-2013 03:00 PM
Mechanical trouble - uneven idle, choking, engine hesitation 100proof Mechanical and Technical 3 05-10-2012 02:04 PM
Idle / bog / etc... mine_us_3 The ZX6R 21 05-29-2009 05:25 PM
