Stripped Camshaft Cap Bolt - ZX6R Forum
 4Likes
  • 1 Post By capitalcrew
  • 1 Post By riverszzr
  • 2 Post By ChandlerO
post #1 of 10 Old 03-27-2017, 08:54 AM Thread Starter
2009-2012 Zx6r: I was in the middle of my valve adjustment and I already did my measurements so it was time to remove the camshaft and chain to put new shims in. There are 20 bolts total which all removed just fine (in the order that that manual explains since the camshaft is under pressure) except the very top right cam cap bolt. It's completely stripped. Here are the things I've tried:
Allen key
Star key (Torx)
Dremel or rotary tool
Flat head
Heat Gun
Chisel it loose
sockets
impact gun extension
I can't really use a drill or impact gun since the frame is in the way. At this point I am currently waiting on the JB Weld and bolt to dry to break it loose. Should I use a impact gun extension for force or should I do it slowly with a socket attachment? It's only 106in lb (I think I'll check later) so I don't understand why it's so stuck! I've put all the cam caps back on the engine to relieve the pressure so I can just focus on that bolt. I'm basically At the point where if this doesn't work then I'll have to drop the engine to re-thread it and Heli Coil it. Any suggestions?
ID:	60114   Click image for larger version
ChandlerO is offline
post #2 of 10 Old 03-27-2017, 09:11 AM
ely
ely's Avatar
I Ride: 09 ZX6R
Craftsman makes a set of nut extracters they have saved my ass a time or two if the jb don't work give them a shot
ely is offline
post #3 of 10 Old 03-27-2017, 09:17 AM
capitalcrew's Avatar
Weld a nut to it.
Scorpi0 likes this.
capitalcrew is online now
post #4 of 10 Old 03-27-2017, 09:41 AM
If you can clamp on a set of vice grips, and turn that to break the bolt free, you may be able to get the leverage you need.
I too would try and use an extractor, before I would do any welding......running current through the block may come back to haunt you if you don't unplug the ECU, etc.
Destructive stuff is less appealing, because of the chance of dumping some metal filings into the top end of the motor.
If you have to cut the head off the bolt, then pull the cap, then use a vise grip to rotate the exposed shaft to get it out of the block -- you would be adding some filings at that point....
post #5 of 10 Old 03-27-2017, 10:12 AM Thread Starter
It was originally a Allen key nut and not a bolt will those still grip on?
post #6 of 10 Old 03-27-2017, 10:57 AM
Elwood's Avatar
I Ride: 05 ZX6R
https://m.lowes.com/pd/IRWIN-BOLT-GR...e-000067bbdf98
Hammer it on if you have too. I've had great luck with these.
Elwood is offline
post #7 of 10 Old 03-27-2017, 11:50 AM
A chisel and hammer should get it to spin the 1/8th turn you need for it to break loose, then almost anything will spin it out
good to see you covered everything up you could
otherwise just pull the engine out and drill---you have already surely spent as much time as that would take with zero results to show for it.
PainfullySlo likes this.
post #8 of 10 Old 03-27-2017, 03:50 PM
+1 on the vice grips if you can get them to clamp on there (it looks like there's enough of the bolt to grab on to).
post #9 of 10 Old 04-05-2017, 08:57 PM
I Ride: 2014 Kawasaki ZX-6R
@ChandlerO was it fixed?
Martillo y Mantequilla #99
post #10 of 10 Old 04-05-2017, 09:24 PM Thread Starter
Got the bugger out!
I hit it with a chisel at the bottom of the nut the did a few hard hits to break it loose. I was very happy that day lol
Strider and PainfullySlo like this.
valve adjustment
almost stripped oil drain bolt hole Rickthefix Mechanical and Technical 6 04-22-2015 07:35 AM
Messed up threads on for starter clutch cap bolt nickjpass Mechanical and Technical 7 07-14-2014 06:14 AM
05 zx6r - Throttle Body Clamp - Stripped Hex Bolt wtray07 Mechanical and Technical 1 04-15-2014 02:20 PM
Stripped caliper bolt! 05Zx6rRyda Mechanical and Technical 12 04-04-2013 02:46 PM
